Disable Vehicle Proximity Notification System DIY
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ICEMAN 316, Oct 26, 2013.
  1. ICEMAN 316
    ICEMAN 316 Junior Member
    So Cal
    2013 Prius Plug-in
    So I found an easier way to disable the Vehicle Proximity Notification System than reaching down from the Driver Side of the engine bay. I unbolted the driver side fender lining and just reached in and unplugged it. Super easy just a couple of push pins and a small bolt. When you open the fender lining up you will see the back of the speaker and a white wire harness. Just unclip it and you're done. I circled the wire harness you need to disconnect in the picture. By the way in the picture I already disconnected the harness. The whole process took about 5 mins. Hope this helps you guys out. :)
    This is the view when you open up the fender lining. Unplug the white wire harness I circled in this pic. (In this picture I already unplugged the wire harness)
    Front view of the speaker. Sorry I couldn't focus on my camera phone. It was to dark. :(
    52,230
    wouldn't it be great if someone came up with a kit that had a plug that fit in between the two you pull apart and wiring and oem switch for the dash.:love:
    ICEMAN 316 likes this.
  3. ICEMAN 316
    So Cal
    2013 Prius Plug-in
    It would be cool if that kit would have different sound files we could play!!(y)
  4. bisco
    52,230
    right on!:LOL:
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Even better, figure out where the opposite end of those wires are.
  6. bisco
    52,230
    that would be great, if they are under the dashboard.
  7. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I was thinking they eventually connect to the drive system, since the noise only activates when the car is in gear. But there should be intermediate stops along the way. A good schematic is required to trace them.
  8. Prius I.T. Pro
    Prius I.T. Pro New Member
    McKinney, TX
    I just unplugged my speaker and it was right where the picture points it to be. I love it, I can drive more stealthy. Its annoying however to hear all of the other people driving when you're trying to test the stealthiness of your car. Almost have to go to the middle of nowhere to actually see if you can hear anything, the loudest part of my car tho where the tires and the whining of my electric motor.
  9. bisco
    52,230
    that's true. about the only place i can hear the vpns is in my garage. i was trying to pull out of a paking space this morning at church, and a guy standing directly in front of me, looking the other way, never heard it. i had to beep to get his attention.
  10. ICEMAN 316
    So Cal
    2013 Prius Plug-in
    Glad it worked out! This one is so much easier than sticking your had in from the engine bay (y)
  11. priusincc
    priusincc Member
    332
    NV
    I disconnected mine the hard way from above, but it's easier to do it like above because of the plug detent. Mine even had a plug holder on the harness to secure the disconnected plug.
    It was interesting that the dealer noted the fact that the VPNS was disabled on the work order for the first service/oil change.
  12. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    They document to cover their butt, in case you run someone over. ;)
    SCH-I535
  13. Prius I.T. Pro
    McKinney, TX
    I love sneaking into the garage, with my car, the only way my wife knows im home is when I open the garage door, so now to change the garage door tot he silent motor. Getting stealthier one piece at a time.
    bps likes this.
  14. Dillona
    Dillona Junior Member
    Thanks for the info and photos.
    My 2010 does not have the VPNS system but I am planning to purchase the next gen Prius when it comes out. At that time, I will evaluate the VPNS sound and if it is the same as current models, I will disconnect it. Has anyone asked their dealer to disconnect it? My preference would be to have a driver-controlled switch that I would leave off most of the time but would be able to switch it on to play a Chrysler turbine car sound for special occasions.
  15. bisco
    52,230
    rubber belt drive.;)
    Prius I.T. Pro likes this.
  16. OregonPrius07
    OregonPrius07 Junior Member
    Does anyone know if they moved the speaker on the 2014 Prius? I opened the panel and couldn't find the speaker. The sound is driving me crazy on warm open window days.
  17. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Take a look behind the grill next to the passenger side horn.
    Did Toyota Move the Location of the VPNS in 2014? | PriusChat
  18. Andrew X
    Andrew X New Member
    Oakland ca
    2021 Prius PHV
    I hate the high pitched noise coming from the VPNS. Does any one know if the speaker on the 2021 Prius Prime is located in the same place? Also, do you have to remove the wheel to do this?
    Thanks.
