MPG suddenly dropped this week.
Discussion in 'Gen 3 Prius Fuel Economy' started by Grren4ever, Oct 14, 2013.
  1. bwilson4web
    16,387
    Possible solutions:
    1. engine block heater - tested, I have one in the 2003 Prius and it saves about 3 minutes in the early warm-up.
    2. run space heater in cabin - tested, long extension cord and small space heater to warm the cabin. I've seen reports but no interest, yet.
    3. plug-in to use built-in electric heater - experimental, the earlier Prius have a set of cabin, electric heating elements. No one has yet 'hacked' a 12V plug-in solution that lights them off and a fan to 'pre-heat' the cabin. There may be simpler solutions such as a 12V plug-in power source and running the car in "ACC" mode to operate the 12V electrical systems. It won't do anything for the engine but it could solve the cabin problem very nicely.
    So do you feel like hacking a solution?
  2. Grren4ever
    Grren4ever Active Member
    347
    167
    I truly appreciate everyone's response to the post. I'm approaching the first month of ownership and the car's instantaneous mileage is looking normal and even better than I expected. I am at awe at how little gas this thing uses! Very satisfied with the purchase. I'll be a Toyota fan for a very long time (previously was a subaru fan and contemplated for the longest time wether I should get a 3rd gen prius or a 2013 impreza hatch). Glad I choose the Prius :)
  3. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Everyone has missed the biggest reason for
    mileage drop - winter gas. That's a 10% hit alone.
  4. Steve terry
    Steve terry Member
    217
    Oklahoma
    Right now the weather is cool in the morning 38 to 45 degrees and and 70 to 75 degrees in evening. I drive the same route and distance each day. I noticed that the mpg were low 36 to 38. When cool and when warmer I got 46 to 49
