DDM Tuning HID question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CdotK, Nov 6, 2013.
  1. CdotK
    CdotK Member
    376
    46
    Has anyone used the DDM H11 HID kit, if so do you have the ground shadow issue with them or do they sit correctly in the housing?
    I am thinking of geting them over the Morimoto HID kit to save some money.
    Thank you
  2. CdotK
    CdotK Member
    376
    46
    wow.. no one... interesting!
  3. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    I have the DDM 35w HID's in all 3 of my lights (low, high, fog) Not sure what the ground shadow is but no issues what so ever that I notice. I like the clean cutoff with the projectors.
  4. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Make sure to get a relay kit if you do
    Turn off signatures in Tapatalk Tapatalk
  5. CdotK
    CdotK Member
    376
    46
    this...Use this relay harness to connect HIDs to cars with very small gauge wiring that cannot supply the initial surge current required to light the bulbs reliably
    Its listed as "HID Harness"
    thanks
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Precisely. I have the 55 watt kit and I've used it for around 5000 miles now around 75% night time and I have experienced no ground shadows or melting or disfigure I had some flickering and when I installed the relay harness It been awesome.
  7. CdotK
    CdotK Member
    376
    46
    Sweet thanks!!
    What color are you running?
  8. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    If you get 35 watt it'll be 5000k and if 55watt 6000 k
  9. CdotK
    CdotK Member
    376
    46
    Yeah i was going to go 55 watt 6000k.... Are they really blue?
  10. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    No more of a cool white my profile pic has em
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I would highly recommend store pick up if you're close by otherwise I takes about a month because they are usually back ordered and if keep bothering them maybe they will ship it from la otherwise it comes from china which takes for ever
  12. CdotK
    CdotK Member
    376
    46
    are they in SD or LA?
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    They have multiple locations
    Vista, ca
    Sd, ca
    Huntington Beach, ca
  14. CdotK
    CdotK Member
    376
    46
    oh nice i got a friend out there in SD... ill call them. thanks for the info!
    Priusmpg likes this.
  15. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    Tampa, FL
    I have two sets in my camry and 2 sets in my prius 35w flavor, no harness. Sorry not sure about this shadow thing you're talking about. The HIDs have been in the prius over a year with no issues.
  16. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Is the ground return wire on the same side of the bulb as the plug, or is the ground return wire on the opposite side of the plug? Or, when installed, the plug is at the bottom, or 6 o'clock position, is the ground return wire also in the 6 o'clock position (no ground shadow), or is it in the 12 o'clock position (potential ground shadows)?
  17. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Here is my few shots from my 35w 6k DDM....using stock relay & wiring, this my 3rd sets on my cars, no problems.
    20130508_015712.jpg Aiming across the street
    20130515_020954.jpg Front of the garage
    20130522_015049.jpg Driving local in SF
    IMG_6072.JPG Driving on Bayshore blvd
  18. CdotK
    CdotK Member
    376
    46
    Thanks for the pic... They look good to me. I'll update once I install mine
    Thanks everyone
  19. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    headlight is h11. What is the fog light bulb size?
  20. xliderider
    8,140
    3,277
    Honolulu, HI
    H11 as well, but please don't put HIDs in your non projector foglights. The reflector based foglights don't have the physical cutoff shield that is in projectors to prevent glare to oncoming drivers.
    SCH-I535
