balancing beads
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by edwardob, Jul 3, 2013.
  1. edwardob
    edwardob Member
    227
    33
    ireland
    webpage does'nt mention dyna anywhere???!!!!!
    quote from webpage
    "Welcome to balancing beads. The weights are actually perfectly round beads that give you a custom balance every time you pull away from the curb. There are a couple ways you can balance your car's tires with beads. The commercial way is to buy balancing beads in a kit. Of course this is "Tools-On-The-Cheap" so I have a cheaper alternative: high density air-soft BBs!! The reason I use these BBs is simple; they're perfectly round, will not corrode (and go out of round which cause them not to be able to roll) and of course, they're cheap. If you buy one of these bottles of beads, you can balance 2 sets of tires (8 tires) for under $15. "
    not sure what your problem....it clearly states ... high density air-soft BBs!!
    can't really do more for you....all i know is what i read on that webpage
    AircoledTech.com's "Tools-On-The-Cheap" Wheel balancing With
    Beads
  2. gliderman
    gliderman Active Member
    751
    225
    Google is your friend. If you cant Google, try Yahoo, Bing, or do a search on search engines and pick from the hundreds listed.
  3. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Gliderman
    I got it, I talked to Nath and he said I can buy bb beads from Walmart it cheaper and try out, he had been using that for last 3-5 years with all good result and no balance what so ever :), I will try it:)
    V/r
    Khoi nguyen
  4. edwardob
    edwardob Member
    227
    33
    ireland
    welcome to the club
  5. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    edward
    I am going to install beads this weekend, however when I read your post, you put 120 grams=4.232 ounces is it too much? does it suppose to be 3.5 ounce is the max? please let me know or should I put in 4.232 like you.
    V/r
    Khoi Nguyen
  6. edwardob
    edwardob Member
    227
    33
    ireland
    mmmm ..whatever he recommended should be fine.....i was over enthusiastic...but no problems
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    edwardob
    good to hear, how you car run so far with beads, any update? any problem?
    V/r
    Khoi nguyen
  8. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    UPDATE:)
    Just install 3.5 ounces BEADS each for both front tires, oh boy!!!!!!!!!!!:) so beautiful, hit highway 80 MPH and absolutely no VIBRATION AT ALL, I am so impress and love it, will try to do the back tires tomorrow:), damn feel so GOOOOOOOOOOOOOOOOOOOOOOOOOOOOOD :)
    V/r
    Khoi nguyen
  9. edwardob
    edwardob Member
    227
    33
    ireland
    welcome to the club......
    just remember not use liguid or canister punture repair that pump into valve .......they will clog your beads
  10. Den49
    Den49 Member
    498
    272
    Maryland
    I used a set of balancing rings that were filled with beads back in the 70's on a 1976 Nova. They worked. The reason I stopped using them and I think why they are not used today is that they cannot compensate beyond a small amount of imbalance and dynamic wheel/tire balancers are much better today than years ago when wheels and tires were "static balanced". In other words, most tires/wheels still need to be balanced with lead weights because more weight is needed than contained in the beads and once a good quality tire/wheel is properly balanced it will usually stay balanced. The beads will compensate for minor imbalance. Below is a picture of a balance ring that is partially filled with beads.
  11. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Dynamic balancing also balances in two planes instead of one like the rings and static balancing do.
  12. edwardob
    edwardob Member
    227
    33
    ireland
    this is not ring!..no comparrision
    this is beads which move around all the tyre as needed...
    and those who use them swear by them.......come back to the tread when you've tried them!
  13. Den49
    Den49 Member
    498
    272
    Maryland
    Same principle. Same result.
  14. edwardob
    edwardob Member
    227
    33
    ireland
    not same....
    beads are floating inside tyre/wheel going to where the are needed....
    anyway the proof is in the eating....and they work....GREAT!!!
    SEE ALSO kknguyen1168 above...
    enjoy your lead weights amigo
  15. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi guys
    same or not the same!!! what the point???? the main point it work and people like me want to try the old or new thing, it is knowledge, and the most important is saving the MONEY:), I am a sucker for WISDOM:), I want and always want to learn new things or old things:). I am not trying to convince anyone to do it or try to do what I am doing, that is up to each person, but fact is fact, and it is working and I like it:)
    V/r
    Khoi nguyen
    edwardob likes this.
  16. edwardob
    edwardob Member
    227
    33
    ireland
    No problem...using 3 months.....changed to winter tyres...recently....also with beads...no issue........any speed....up to 5km per hour there's a "beads in a bottle sound "....... after that silence...
    there grea
    biggest critic are always those who have'nt tried something or tested it out..
    the earth was flat.......sun went around the earth...iphone wont sell....
    we're just here to help.....beads...water.....lead weights....slime.....
    TRY whatever you like
    this tread is to help those who want to try beads.....
    for us who TRIED beads. they are GREEEEEEAAAAAATTTTTTT!
    maybe we have reinvented the wheel..........
    oops...remember galileo was under house arrest for saying the earth was a sphere
  17. Slick26
    Slick26 Junior Member
    40
    Twin Cities, MN
    I use Ride-On for my motorcycle tires and l like it more because it will seal tire punctures as well. Beads won't.
  18. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Slick26
    Good to hear that you like it:), If you like it then I love it:)
    V/r
  19. edwardob
    edwardob Member
    227
    33
    ireland
    enjoy your slime
    the balancing bead guru of all wisdom wrote once
    " Ever removed a Slimed tire??. . . Yuck!!"
    but hee !enjoy your slime...choices are available! this is a !"pay for weights free zone "
    i used slime once or twice in the past myself and its good.....but bbs are cheaper
    only putting weights on will upset this tread
    any other ideas out there?
  20. Slick26
    40
    Twin Cities, MN
    Only speaking about my motorcycle tires, it hasn't been a problem removing them and putting new ones on. The Ride-On system is water soluble, so even if you do make a mess, which I haven't experienced yet, it's relatively easy to clean up.
    I don't know about car tires, as I haven't used Ride-On for mine yet.
    Also, I know a lot of truck drivers who use Ride-On in their truck tires, as a balancer and as a plug for punctures, and most swear by it.
