How to protect Prius front from rock and bug strikes?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Robert Holt, Nov 20, 2013.
  1. xliderider
    xliderider Senior Member
    8,134
    3,273
    Honolulu, HI
    Seems like the frame might interfere with the lowbeam headlights? Have you tested the headlights at night?
    SCH-I535
    Robert Holt likes this.
  2. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    I see a driving light/fog light set at the top of those frame posts! :)
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Good idea, Mike!
    If I mount a camera on top of each post, we would have a 3-D view of what the Prius sees when rolling down the road! Kind of a bush version of a bug-eyed Sprite.
    Agree! Especially if we drive a "figure 8" type of loop in Alaska and Canada where the return route is Anchorage to Tok on the Glenn Highway, Tok to Dawson (Yukon ) on the Taylor Highway, Dawson to Carmacks on the Klondike Highway, Carmacks to Watson Lake on the Campbell Highway, and then Watson Lake to roughly Kamloops, (British Columbia) on the Cassiar Highway. That return route includes hundreds of miles of gravel road plus logging trucks, etc., so rock strikes could be a real problem.
    Spider-Man also reports heavy bug strikes in Anchorage area , but the Clear Bra or masking tape methods of protection would probably be better for that although I THINK the mesh will catch a lot of them, especially if I go with 1/4 inch mesh rather than the 1/2 mesh I have now. But I really have to test the effect on mpg and make sure the assembly does not interfere with lights and signals as another poster mentioned.
    WE0H likes this.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    Those are not bug's they are small planes! :whistle:
    Robert Holt and WE0H like this.
  5. WE0H
    WE0H Senior Member
    3,247
    528
    I would just spray the hell out of the whole car with that 3M clear spray. Also install some mud/stone flaps to catch the rocks that your tires are gonna kick up. Hundreds of miles of a rock fest dirt road otherwise will eat that paint down the sides of the car :-( Might also be a good idea to bring a full size spare tire and a board to support the jack in case you get a tire cut on sumthin and are sitting on a soft muddy dirt road that your jack will love to sink in rather than lift the car :-(
    You sure have an adventure ahead of you :)
    Mike
    Mobile on my SGH-i717
  6. Robert Holt
    1,313
    889
    Hope to leave July 1, but take our time and really see the country, talk with the people, and try to understand the culture and conditions of Alaska, which in my mind is the last frontier area in USA. We hope to hit a sweet spot of non freezing temps, low bugs, and low rain in the mid-July to mid-August period.
    As to choice of vehicle, I have a 4-wheel drive, tow-package Tundra and had a travel trailer and that was the initial plan. But that combo got 11mpg, and I could not morally justify those co2 emissions when the Prius Super RV can do the same drive at 50-60 mpg and roughly 1/5 the co2 emissions. So bottom line is I am taking Prius because of my religion even tho I would much rather have a V-8, 4-wheel drive, 9-inches of ground clearance , and the ability to leap tall curbs with a single bound!
    Good news is that all the equipment for the Prius Super RV, whilst bulky, does not weigh that much and I do not think I am any lower than when carrying 2 adults in the back seat. That said, it IS low and I foresee possible undercarriage strikes on the frost-heaved and potholed gravel roads. Has anyone replaced the plastic panels underneath with aluminum or stainless steel?
    Your idea of adding a smaller mesh might work, or I could start with a 1/4 inch mesh as the base.
    Thanks!
  7. WE0H
    WE0H Senior Member
    3,247
    528
    That brings up a thought. Make a skid plate to protect the fuel tank as a forum member a long while back had road debris take out where a fuel line goes into the tank or something like that. Put the car on a lift and you will figure it out right away. Aluminum sheet should make some nice plates. Lightweight :)
    Mike
  8. Robert Holt
    1,313
    889
    Good idea about the mud flaps!
    I'm off to purchase the Priuschat versions now.
    Bought full sized rim as you and other posters suggested (used 2012 Prius rim for $100) and will get new tire mounted after Thanksgiving .
    Bring board for jacking in mud, check!
    Intend to test all equipment camping this winter in Florida.
    Thanks for the good wishes and will post as this unfolds (unravels?).
    WE0H likes this.
  9. WE0H
    WE0H Senior Member
    3,247
    528
    Where you camping this winter? We drive down to the Lake Mary area every winter for a couple weeks for the HamCation hamfest.
    Mike
  10. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    Here's what I plan to do in the next 2 months...the total kit is about $350, but if you consider a stray pebble hits your condenser coil, you're looking at a $2000 repair:
  11. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I purchased evestrough mesh. It's aluminum expanded mesh. Cut it to size and used black zip ties to fasten it to the back of the grills. It's hard to get in there to work, so I used some stiff wire to direct the mesh into position and installed the zip ties from the front. Looks good (the mesh hides behind the grills), and is inexpensive. It also stops most bugs of size.
    For the trip you might want to check out a "cold front". It's padded vinyl intended to protect the vehicle in winter in the north. Rocks wouldn't be a problem with one of these on. They have openable flaps that cover the grills, which you would leave open for the summer trip. There are places that make custom ones. I've seen them cover the entire hood and front fenders! Also called a "car bra".
  12. B. Roberts
    691
    212
    Definitely going to be a great trip... one that I wanted to make back when I lived in Montana. Had to move before the kids were old enough to go on a trip like that, so it hasn't happened yet. It's gonna be some haul from the east coast, but well worth it.
    Have some friends who are on their way down from Fairbanks, driving their kid's Tundra and towing a trailer with their belongings to Vermont. It's been a real adventure so far, especially with the snow and "cool" air they've encountered.
    Totally understand your reason for taking the Prius on this trip. We use our Prius for all long distance travel. Hope you decide to recount your trip stories and pictures with us here in Prius Chat.
    By the way, the Grill Craft Mesh inserts that phoenixgreg posted above is a great idea for this kind of trip.
    Robert Holt and phoenixgreg like this.
  13. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Reminds me of an old Mad Magazine Star Trek story. "Raise the screens Scotty!", that's exactly what it looked like. :)
  14. Steve terry
    Steve terry Member
    217
    Oklahoma
    This gives me a good idea. Around here I drive on the highway and have to watch out for deer and coyotes. I hit 2 at one tine last month. They deflected off the edge of car. Now if I could build a train cattle guard and hook it to the tow hooks. :)
  15. Robert Holt
    1,313
    889
    We were thinking Oscar Scherer State Park which is south of Tampa. Had a pow-wow last time we were there but that was coincidence. We have found many of the Florida state parks to be nice and ten to kind of rotate through them. Will look up Lake Mary as that does not ring a bell.
    Now you're talking! And putting a wood boiler with steam generator in the trunk would allow a battery charge using renewal energy! A small, discrete smoke stack at the rear would complement the cow catcher in front. Back to the future!
    Off to google the Grill Kraft Mesh kit! (Sure looks better than my jerry-rig although it does not protect as much of the surface.
    Maybe that plus a Clear Bra.... Or masking tape.... Or foam pads.... To protect the rest of it.
    Will definitely post pics as the adventure unfolds!
    phoenixgreg and WE0H like this.
  16. B. Roberts
    691
    212
    Looking forward to seeing those pictures!
  17. Steve terry
    Steve terry Member
    217
    Oklahoma
  18. phoenixgreg
    1,157
    291
    66
    Phoenix
    http://www.carid.com/2010-toyota-prius-grill/grillcraft-mx-grille-354483.html
  19. Gaëtan Lafrance
    101
    77
    Montréal, Québec
    Technology
  20. Robert Holt
    1,313
    889
    Good job! Had not thought of that method, but I had not thought of painter's tape, either.
