FR-S Wheels on the Gen II Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TampaPrius.com, Nov 22, 2013.
  1. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I just got a set of Scion FR-S wheels and tires and put them on a 2008 white Prius. What do you think? IMG_7151.JPG IMG_7152.JPG IMG_7155.JPG IMG_7159.JPG IMG_7151.JPG IMG_7152.JPG IMG_7155.JPG IMG_7159.JPG IMG_7162.JPG IMG_7151.JPG IMG_7152.JPG IMG_7151.JPG IMG_7152.JPG IMG_7155.JPG IMG_7159.JPG IMG_7162.JPG
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    sure looks better than oe, but how much they weigh?
  3. TampaPrius.com
    461
    300
    Tampa, Florida
    I didn't weigh them but avg MPG went from 60.4 last 2,000 miles to 52.4 this tank.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    look nice. what is the ride like?
  5. DonSol
    DonSol New Member
    Nice! looks really good on the white Prius. I just scored some as well last week on Craigslist for $350 with the Michelin Primacy's included (y) They ride very smooth and the car feels more stable when cornering. I've been noticing about 3-4 mpg less the past 5 days and thats with a loaded car with a bunch of music gear. Just make sure you get a pair of 3mm spacers up front.
    Daves09prius likes this.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Nice! No clearance issues? The Gen3 has clearance issues with the brake caliper holders, need a 3mm spacer.
    SCH-I535
  7. DonSol
    DonSol New Member
    No not that I've noticed. Yep, I had the guys at Cruisin Gold here in Melbourne add 3mm spacers to clear the calipers. I get about 45-48 mpgs but Im a slow driver ;)
  8. TampaPrius.com
    461
    300
    Tampa, Florida
    I had mine on without spacers but couldn't get the front caps on. Ride is very similar, maybe a little bit stiffer. I sold the car yesterday without the wheels so I will put them on a different one with spacers this time.
  9. DonSol
    DonSol New Member
    Yes they won't fit without a minimum 3mm spacers at least for Gen II. I honestly don't feel the weight of these wheels and tire combo upon acceleration but the 3-4 mpg loss is definitely there but is pretty insignificant with the better handling and looks of the car.
  10. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    what did you do about the vss sensor reading differently now that you have larger wheels on? Those wheels are very light and are a much better upgrade over stock.
  11. ChadInOKC
    ChadInOKC Junior Member
    46
    Moore, OK
    I just picked up a 400 mile set of these for my 2nd Gen car. So I for sure need spacers? Everyone says 3mm and what lugs are you guys using? Prius lugs or did you order a new set of lugs? I don't think mine are coming with them.
  12. TampaPrius.com
    461
    300
    Tampa, Florida
    Yes, use the stock lug nuts.
  13. SunDevilDrake
    SunDevilDrake Junior Member
    58
    Gilbert, Arizona
    Any long term reviews on these in regards to mpg? My current 15" OEM wheels and tires have a few thousand miles left and looking to change soon.
  14. 69shovlhed
    2,170
    752
    Delaware
    I put a set of 16x7 motegi traklites on last week with 215/55r16 bridgestone ecopia ep422 tires, and my mpg hasn't gone down at all. might have actually improved cause the ecopias are almost an inch taller than the junk integritys.
  15. SunDevilDrake
    58
    Gilbert, Arizona
    Since the 16" Traklite weighs just 12.5 lbs you are upgrading a wheel size over the OEM 15" but not increasing the weight. Good move. Pic?
  16. 69shovlhed
    2,170
    752
    Delaware
    my pleasure!
    SunDevilDrake likes this.
  17. SunDevilDrake
    58
    Gilbert, Arizona
    Nice! The green lug nuts are a nice touch. Did the center caps not fit?
  18. 69shovlhed
    2,170
    752
    Delaware
    I got the motegi caps but I don't like them. so I ordered some plain jane plastic caps from ebay. I'ma paint em flat black when they show up. can't wait. the green lugs are very small "tuner" lugs. I was gonna go with aluminum lugs but then I was concerned they wouldn't catch enough threads to be safe. so I got tiny steel lugs-- anything to keep the weight down.
  19. SunDevilDrake
    58
    Gilbert, Arizona
    Can't wait to find a set for mine. Found a FR-S set local for $680 with tires. Want to see if he'll drop the price.
    Also found a Gen3 set with tires for $450 with the double 5 spoke black wheels under the wheel covers. But I read the Avid s33 tires are crappy.
  20. Sezy
    Sezy Active Member
    443
    233
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Subraru WRX wheels fit just fine too. ;) I did see a FRS at the track and his tires were the same size as mine and thought neat.
