Tire PSI
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CdotK, Nov 27, 2013.
  1. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    47 isn't that bad...
    It got cold here and I'm lucky if I hit 40 right now.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    Teens degree f weather! getting only 47? You are doing really good. If you have any hills I would think less mpg, using heat also makes a diffrence. Just enjoy your car.:) When you get around 10k to 15k miles on your car you will see a small increase in mpg as things loosen up on the car and you learn the car better. You will see 50+ next summer.:D
  3. CdotK
    CdotK Member
    376
    46
    im at 11K already :cool:
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y) I have 4 coffee friends and in teens degrees temps,
    1. 47mpg 2. 39mpg 3. 42 mpg 4. 44mpg as of today. Thats one 2011 and three 2012's.
    Enjoy! :)
  5. CdotK
    CdotK Member
    376
    46
    sweet.. so yeah like you guys said, im not doing too bad! And considering all the extra weight from the built up Ice and snow on the car
  6. mroadster2k
    mroadster2k A little bit of awesomeness
    31
    I have mine set at 42F and 40R fr both my 15s (winter) and 17s (summer). Ride is stiffer but the MPGs are optimal
  7. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    42 psi front/40 psi rear I found best is for wear, stability and mpg. Go 40/38 if you are sensitive to road vibration or your lady needs to put on make-up while you drive.
  8. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    I went to 42f 40r on my winters the other day and it's intolerable on most of Dublins wonderful roads!
    I'm going back to 40 / 38 for a slightly softer ride...I'll suffer the mpg loss for some comfort
  9. CdotK
    CdotK Member
    376
    46
    i just checked my PSI this morning.. dont know if the 2 degrees temp was the cause BUT my gauge was only reading 35PSI... I set it to 42 PSI a week ago on a Saturday in the morning before i drove the car.... :confused:
  10. Tony D
    469
    132
    Dublin, Ireland
    I'd be checking those figures again somewhere else, that's too much of a difference in a week, even considering the cold
    sdtundra likes this.
  11. vskid3
    vskid3 Active Member
    773
    228
    How cold was it when you checked them at 42PSI? According to Tire Rack, every 10F changes the PSI by 1. Some tires just don't seem to hold air that great, either. Were they all the same, or did you just check one?
  12. CdotK
    CdotK Member
    376
    46
    i filled them up and it was probably 30-40F.. i checked them the other day and i was only about 5F....
  13. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Oh for Pete's sake you just want to see if I can find my previously posted graph.
    This is generic, using some rolling resistance equations given in a prior thread.
    Focus on the shape of the curve, the MPG drop off is 2x as bad under 35 psi.
    Unrelated to psig, keep in mind rolling resistance is higher when tire is colder.
    Takes the tires about 20-minutes to warm up.
    retired4999 and jdcollins5 like this.
  14. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    My new snow tires have a max inflation of 44 psi. I would think setting the cold psi to 40/38 would be ok, allow room for heat up
  15. CdotK
    CdotK Member
    376
    46
    Nice graph!
    Thanks for sharing!
  16. fuzzy1
    10,603
    That max inflation label typically is a cold pressure, and already includes margin for heating up.
    retired4999 and vskid3 like this.
  17. jdw
    jdw Junior Member
    2019 Prius
    I went to from 35 f/r to 42f/40r a week ago and gained about 15% on my average MPG. That's a win in my book. The ride is a bit harsher, but worth it.
    SCH-I605 ?
  18. Danger
    Danger Member
    175
    22
    Frisco
    I think mid 40s should be a good average MPG. I set mine to 45 all around and I get 47mpg mostly on freeway. Now I get 44 MPG most likely to winter blend.
