Prius throttle not moving after battery switch removed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by azur, Dec 16, 2013.
  1. azur
    azur New Member
    2002 Prius
    Hey guys, i took off the battery saftey switch yesterday as i was working on some stuff, now when i put the switch back, and try to turn the car on, the throttle motor does not move, no matter how much i try to press the gas.. is there some sort of rest on the motor like in the audi's? Thanks
  2. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Did you remember to slide the switch up after inserting it?
    JeffD
