Oil Pressure Light
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by rcturner, Dec 22, 2013.
  1. rcturner
    rcturner Junior Member
    53
    I have had my Prius v for almost 2 years and just recently realized that I don't understand why the oil pressure light doesn't come on when the engine isn't running. Is there something electric that provides pressure when the engine isn't running ?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The engine doesn't need oil pressure when its not turning. When it IS turning, it has pressure. When the ICE starts up, it is first spun up to 1000 rpm before fuel or spark is applied, thus providing lubrication.
  3. rcturner
    53
    True, it doesn't need oil pressure when it is not running but, why doesn't the oil pressure light come on ?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Aside from pissing off all the drivers of hybrids, what would be the point to having the oil pressure light come on when the engine is off?
    What good would it serve? How would that be a familiar behavior? (Our alternator light should be on ALL the time as Toyota did not install an alternator!)
    cwerdna likes this.
  5. rcturner
    53
    When you start the car, the oil pressure light comes on for a couple of seconds. It then goes out even though the ICE has not started. My question is as simple as what the mechanism is that turns the low oil pressure light off even when there is no oil pressure. By the way, it is quite normal in the outside world for the oil pressure light to come on when an engine isn't running. However, in the case of hybrids, it could be very confusing.
  6. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    The answer is pretty simple.
    That is that our Prius is smarter than we are.
    The Prius knows what the proper oil pressure should be at all times. If the ICE is at 0 rpm then 0 psi is the proper oil pressure and so... no light.
    Realize that the oil light in all modern cars is controlled by the computer. The day of having a light connected directly to a pressure sensor is gone.
    Thanks,
    Dan
  7. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Perhaps the simple way of answering this question is that in a normal car when you turn the engine off the oil light does not come on. This is because you also turn off the supply to the warning light.
    Now when you make the Prius "ready" you are not turning the engine on, you are only turning on the computers. It is these computers that turn the engine on, or decide if the the engine needs turning on or not also controlling the warning lights associated with the engine.
    John (Britprius)
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes, it is traditional on all cars to do a lamp test during power up, so drivers expect it.
    So far, it only seems to be confusing you. The rest of us expect that when there is no issue, we won't get warning lights about that issue. Thus we do not need to panic because we got a "check engine' light when in EV, and we are saved from getting an alternator light on a car built without an alternator. We trust that when we get a warning light, it means something has gone wrong.
    I am going to jump out on a limb here and guess that just because everything else on this car is controlled by software, that the computers know not to give false warning lights as well.
  9. rcturner
    53
    It is interesting that some of you have read into my question that I am experiencing something that I suspect could be a problem. Wrong. I have no problem with the car. Also, I have worked on cars, motorcycles, boats, trucks, etc with internal combustion engines for decades. I do know how they work and what is needed to keep them healthy. I was just asking a question about what mechanism might be involved in not giving a low oil pressure light when the engine is not running. The speculation that the computer is controlling the light by determining when oil pressure should be present seems reasonable. However, I was looking for a more definitive answer. The question was prompted by curiosity, not need. However, thanks to those who provided input.
  10. Britprius
    5,194
    1,922
    I understand why you asked the question, but it is not speculation regarding the the control of the light being the computer. That is fact.
    The driver has limited say or input as to if the engine is running or not, and "ignition on" the normal control of the oil warning light is part of the sequence controlled by that computer.
    John (Britprius)
  11. bisco
    52,408
    sometimes, the question is more elusive than the answer.;)
  12. rcturner
    53
    True but, I think the question was pretty clear.
    From the original post:
    "Is there something electric that provides pressure when the engine isn't running ?"
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    No.
  14. Mendel Leisk
    41,933
    This is on the hatchback, but I'd assume the v is similar:
    If you're stopped at a red light, the mpg indicator is going to tell you you're doing infinitely good mileage. Even if the engine comes on, it'll continue saying this.
    Nothing could be further from the truth, but in that situation the gauge is irrelevant, so it's just shut down.
  15. Air_Boss
    Air_Boss Senior Member
    4,225
    1,188
    New Yawk
    The v displays that, ICE on or not, MPG at rest is zero.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    To simplify, when the Hybrid computer switches the engine (ICE) off, it switches the 12v feed to the oil pressure light off, equivalent to switching the engine off on a non-hybrid.
  17. bisco
    52,408
    then where does the pressure come from when the ice is off?
  18. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Who's on second?
    kithmo likes this.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    What makes you think there is any pressure when the ICE is off?
    The computers simply don't send an electrical signal to the low pressure lamp
  20. Air_Boss
    4,225
    1,188
    New Yawk
    When the ICE is running as a pump/brake, it must have lubrication, even if combustion is not called for.
