PRIUS REAR WINDSHIELD WIPER MOD REMOVAL
Discussion in 'Private Sales' started by Frankie Alvidres, Dec 25, 2013.
  1. Frankie Alvidres
    Frankie Alvidres Junior Member
    SOCAL
    Installation came out very clean with no modification needed. 321155446746_4.jpg IMG_3290.jpg Selling black nylon plugs for your rear wiper removal filler. Fit perfectly. $6.50 shipped to USA. Paypal. Message me if you are interested. Check out pictures.
    #1 Frankie Alvidres, Dec 25, 2013
    Dylan Doxey likes this.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you ever visit a place with snow or ice, you will wish you left that wiper where it should be.
    Dyjital, gt2000quebec and yellow taxi like this.
  3. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    Looks well. I did it on two of my cars in the past as well. As you love in SoCal, you probably won't expect too much rain!
  4. Diver Allen
    Diver Allen Member
    66
    27
    Cincinnati, OH
    2013 Prius v wagon
    Seeing this makes me think I will try to get my car to run on 3 wheels.
    Allen
  5. Karasmyth
    Karasmyth Junior Member
    49
    Driving 2k a week
    Living in New England I have used my rear wiper a bit. Is the general consensus they are useless? Can't see out or bother with that window anyway.
    PriusGuy32 likes this.
  6. mahout
    mahout Active Member
    655
    116
    NC
    Here, failig to see closing traffic can be dangerous; originally we hatched a double wiprer to clean the whole back window using cheap wipers but didn't like the action(see utube). We finally bit the bullet and use a OEM rear wiper arm and blade to make a double wiper acting together to clear the back window. Just image the circular wiped area duobled in width with a second wiper blade matching the OEM. Much like the windshield wipers.
    The iyems are pretty much the same, usding large suction cup to pivot the new arm and adjustable linkage between the two arms. Clears the back window even in snow conditions. Anyone interested in doing that contact me and I'll show you how or provide the wiper, linkages, and wiper arm for $99 if you want to avoid the ferreting.
  7. pointcrossed
    pointcrossed Junior Member
    49
    San Diego, CA, USA, Earth, Milky Way
    It's a personal preference thing. People take them off because it looks cleaner without it. I say put Louvers on the rear window like the old camaros and Mach 1 mustangs.
  8. Hollywood Cole
    Hollywood Cole Junior Member
    25
    Alabama
    Will this fit Gen 2 models? The 1/3 of the glass that my rear wiper actually clears of rain isn't worth the blind spot it causes when I'm not using it. Plus it obviously couldn't hurt fuel economy.
  9. Tony D
    469
    132
    Dublin, Ireland
    You can do a rear wiper delete on most cars with a rear wiper....as for fuel economy, I can't see there being any difference without it
    Many people do it on Mk3 & 4 Golfs, for the cleaner look
  10. Hollywood Cole
    25
    Alabama
    Oh yeah I'm sure the difference would be negligible. Just sort of thinking out loud. Does look very nice though. I never use my rear wiper, and when I do it only irritates me with how small of an area it clears.
  11. .paul.
    .paul. Junior Member
    lol at $6.50 Lowes plug with silicon mod. LOL DAFUQ
    EGGS likes this.
  12. CTitanic
    CTitanic Member
    153
    22
    South Florida, FL, US
    Something that I'll never do to my Prius.
  13. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    It has rained quite a bit in the few weeks that I have owned my Prius and so far I haven't seen the need for that rear wiper. With how the aerodynamics of the car are, rain rarely builds up on that rear window and as others have mentioned, the blade hardly has much reach to do any good, anyway.
  14. CTitanic
    CTitanic Member
    153
    22
    I prefer to think that is there if I need it than need it and don't have it there.
  15. orenji
    orenji Senior Member
    5,887
    3,488
    It would depend on how much back up driving one does! :)
    Tony D likes this.
  16. davekro
    davekro Active Member
    529
    83
    SF Bay Area, East Bay
    2013 Prius Plug-in
    It never occurred to me to remove the entire wiper motor, but I found this thread because I want to know how to just remove the entire wiper blade assembly (for now ;o)
  17. davekro
    529
    83
    2013 Prius Plug-in
    I decided to remove the motor. :eek:)
    OK, with protruding wiper drive larger than I thought, I just went ahead and removed the entire wiper motor. It was VERY easy to do.
    To remove the plastic back door liners, start with lower first. At sides you will see raised sections to insert a pry tool. pry away and it starts to pop off. Just work your way around popping all 8 or so attaching plastic retainers away from back door. Then starting at the bottom of the mid plastic piece (this one is just below the glass), pry/pop it's lower retainers. Before trying to remove this piece from it's top most area, pull with your hands on the skinny window trim 'just above' where the 'middle piece' joins it on each side. The middle piece is tied into the upper side pieces, so it needs to be moved away from the window enough to remove middle piece from it's 'tabs' into upper sides.
    Remove wiring harness and the three 10mm bolts holding the motor and it is out.
    The remaining hole is 1.40" in dia. This is 35.56 mm, so a 35 mm plug is just right.
    1.375" is 1 3/8" , this should work well too. For now, I just cut a piece of cardboard, inserted into hole and covered both sides with electrical tape until I can get to Lowe's or Home Depot to find a plug.
  18. tweldon2
    tweldon2 Junior Member
    Stockton
    Still got plugs available? I'd rather buy one from you than 25 from Grainger @15.00 ------ contact = twreilly with gmail
  19. davekro
    529
    83
    2013 Prius Plug-in
    I would have loved to have found a black nylon plug 1 3/8" ! I found a metal plug at Home Depot for $2-3, I don't recall. But I had to sand, prime and paint it. When I was cutting away the small amount of silicone sealant that oozed out, I nicked the paint job a bit. Even for $6.50 an already black plug would have been easier and worth it. :)
  20. GregP507
    GregP507 Senior Member
    3,002
    481
    I can't wait to do this mod. Next, I'll cover over the headlights and weld the doors shut.
    :rolleyes:
