Check Engine Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by guzzel, Dec 27, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    The Mini VCI is a single lead with a USB plug at one end "for the computer" and a large OBD 2 Plug "to fit the car" with all the electronics built in at the other. It comes with a driver and minimal instruction CD. I will post a link shortly.
    John (Britprius)
  2. Britprius
    5,194
    1,917
    GrumpyCabbie likes this.
  3. guzzel
    guzzel Junior Member
    UPDATE: Decided to get a second opinion on the code. Turns out the guy at O'Reilly's was looking at the code for another make of vehicle. The P1121 is a coolant flow control valve failure.
  4. Britprius
    5,194
    1,917
    Check the level of coolant in the radiator (not the header tank) as this can cause this problem if low on coolant.
    John (Britprius)
  5. Britprius
    5,194
    1,917
    GC see below for first page of HV battery printout from Mini VCI.
    John (Britprius)
  6. guzzel
    Just did that John. Turned out the coolant was low so i added some.
    Hopefully that's the issue. My motto is always start with the simplest and work out from there.
    BTW, if it turns out to be a sensor, is this an easy DIY, or should this be done by the dealer? If by dealer, any idea as to what the cost should be (parts + labor)?
    - guzzel
  7. Britprius
    5,194
    1,917
    The Prius actually monitors the position of the valve so the valve should be changed if topping up does not clear the problem, but you may have to top up more than once if air is in the system. Also check for engine water pump leak.
    Cost wise I cannot help you with as I am in the UK and we do not have the coolant control valve or the thermos on our vehicles making life much simpler and cheaper.
    I also do not know if this code will clear it's self after a few make ready cycles, but probably will after disconnecting the 12 volt battery.
    John (Britprius)
  8. guzzel
    After the tech connected the OBD reader, the code cleared out. Hopefully no more CEL.
    I did noticed both times with the CEL came on, it was first thing in the morning (about 3 miles after I left the house).
  9. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    That is my understanding, but I could be wrong. If you are happy with Torque, use it. I am in no way discounting or discrediting the product. FWIW, I was implying that the OP may not be able to read the code with a generic scanner. As it turned out, it appears to be a simple engine code which is a good thing for the OP.
    Getting back to the OP's problem, I am glad to see that the problem has properly been diagnosed. Let us hope that he/she is able to get the system refilled properly and is able to get all of the air out of it.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Incredible that people come to this site...join...post...before even actually opening the hood.
  11. hormosapiens
    hormosapiens Junior Member
    44
    north Jersey
    John (Britprius)
    I am in front of my laptop with my credit card in hand. where can I buy this VCI? any link would be much appreciated. any link where I can do my home work and read or know everything about VCI?
    thank you
  12. Britprius
    5,194
    1,917
    You do not give me a clue as to where in the world you are. This can be very helpful. If you go onto Ebay and do a search on Mini VCI with Techstream you should find lots.
    John (Britprius)
  13. hormosapiens
    44
    north Jersey
  14. hormosapiens
    44
    north Jersey
    I am reading amazon reviews about this and it seems a little confusing. but Ill keep reading around until I know what I am doing.
    I have 2 Priuses. mine 2gen 04 and wife's 3gen 010. it will be a good investment.
    thanks for any additional info.
  15. Britprius
    5,194
    1,917
    I suggest you put that in your avatar, as this can greatly affect the help you get here on PC. Sometimes this is as simple as guiding you to local workshops or supplies, but often there are differences in Prius systems especially in the areas of fuel tanks, cooling system, brakes, and wheels/tyres.
    John (Britprius)
  16. Britprius
    5,194
    1,917
    The VCI once up and running on your car is fairly intuitive to use, there being different sections to enter on the main screen such as, engine, transmission, AC, HV battery, and body. I am sure there is more these were from memory. If you can find your way round a computer you can use the VCI.
    It is easier to set up if your laptop runs XP or Vista, but it can be made to run on windows 7 or 8. The first time you use it it will pay for it's self.
    To a degree on the gen2 but more so on the gen3 you can set up or turn off items that you now have to pay the dealer for, EG reverse and seatbelt beep and light timings.
    John (Britprius)
    hormosapiens likes this.
