Move 'Reverse' beeper to back bumper. Anyone done it?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by davekro, Jan 1, 2014.
  1. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    1) Has anyone found that little F'er (beeper) under the dash? (where and how easy to access?)
    2) And moved it to under the back of the car? The aftermarket back up alarm I installed on my box van is WAY louder than would be appropriate for a small car. I MUST stop that noise in the cabin, but would love to have that beeping be heard at the back of the car, "IF" it would sound subtler at the back of the car for pedestrians.
    I was just very glad to read that the dealer will turn off the Reverse Beeper (usually for free I am told), since I am due for the 5k service next week. But if this Mod has been done to good effect, I'd like to try it first. So any How to's on removing beeper, running wire to rear of car, mounting location(s) and was it worth it, would be greatly appreciated. Was the beep sound no longer obnoxious in the cab? Was it obnoxious for pedestrians?
    For those with Reverse alarm turned off, did it also turn the seat belt alarm off, or is that a separate step? I would love the dealer to turn off the seat belt warning. Anyone had this done or know if it is allowed by law (in Calf. if that matters)?
    TMI: Being a Mac person, I was NOT looking forward to learning to download a CSV file onto an old PC of my wife's and trying to use my Torque App to disable it.:confused: Now excited about the 'possibility' of turning a lemon (cabin beeper) into delicious lemonade (exterior beeper). ;)
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The seatbelt warning beeping is a separate setting.
    SCH-I535
  3. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    FYI, Dealer's will usually change the reverse beeper to 1 beep, not completely turn it off. 1 beep is better than the incessant beeping as you are backing up.
    davekro likes this.
  4. Bingee
    Bingee Member
    210
    62
    Michigan
    After my dealer got my money THEN I found out about the BEEP REVERSE
    Dealer was going to charge me 50.00 to turn it off , sales rep did get it done for free
    But what a hastle
  5. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Hassle and a rip-off. I guess they need to keep the lights on, but....
  6. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    You can add a beeping led light I think they sell them for commercial vehicles?
  7. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I see now the other option is One beep. This is good. Now I'll get to see if Dublin Toyota service dept. will turn it to one beep for free, or if I have to get the salesman involved.
    I still would like to hear of anyone moving that beeper to the back bumper. I'm going to have to check how effective the white noise (in EV) is from the back of the car. Is there only a speaker in front for the white noise?
    This Bak-Talk unit looks interesting, but pricey.
    Bak-Talk Backup Sensor | Vehicle Reversing Aid | Back up with Safety and Confidence | Sonar Technology | Voice Indicator
    It supposedly 'talks' only when there is something in your path. Saying: " Eight feet, five feet, two feet, (under 12") 'Crash'. " Would be good if it really was quiet w/o annoying false alarms.
    Anyone seen or heard of these Bak-Talk units before?
  8. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    If a dealer won't switch it to the one beep for free I'd avoid them at all costs. It's a routine thing.
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Not necessarily. Lexus is the one that offers a one-time "Personalized Lexus Setting" free of charge. Toyota dealers have the liberty of charging or doing it for free, as no such policy exists for Toyota.
    That said, you'll have a much better luck finding a Toyota dealer who'll do it for free if you locate a combined Lexus/Toyota dealership. Those joint dealerships are expected to meet higher standards than your typical run-of-the-mill Toyota dealer.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I love the reverse beep.
  11. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    I would get one that is used on dump trucks. That would irk a lot of people, thinking a dump truck is backing up!:p
    In response to your question, no, I have not done the rear bumper beeper install.
    DBCassidy
  12. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Ditto.
  13. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Called for 5K appointment. They said the Entune 3.1 update and Reverse change to one beep were free (she asked if I bought my car there, which I did). Se was not aware they were able to turn off the turn signal alarm Seatbelt Alarm. I told her it was listed on page 646 of manual. She called back in an hour to confirm that they could indeed turn off the seatbelt alarm (all three for free). Good to know in advance. :eek:)
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Turn signal alarm? You mean seatbelt warning?
  15. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    Dooooh! Thank you! Post edited
  16. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I wanted to see how well I could hear the PiP's white noise speaker from the rear of the car. While my wife was backing down our driveway, the 'noise' was on and off. We figured it turned off as she applied the brake backing down the slight grade of the driveway. Even when 'white noise' is on, it is not as audible behind the car. Hmmmmn. Maybe instead of looking for an aftermarket noise maker, I'll look into mounting a second factory 'white noise' speaker at the rear of the car? I'll do some more listening...
  17. bisco
    52,121
    LOL, i read this and thought you didn't like the sound. i was gonna say, i can't even hear mine!:p
  18. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    It's cheaper to buy the Mini VCI (around $25) and do this yourself. If at any time you disconnect the 12 volt battery the settings will revert to the factory setup and then you will need to go back to the dealer. The VCI will also allow you to alter the lighting programs , reset or program the TPMS, and so much more.
    John (Britprius)
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I've disconnected the 12V battery to swap out the stock steering wheel for JDM piano black and the backup beep didn't reset from single beep to continuous?
  20. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I've disconnected the battery several times and the reverse beeper did not revert.
