The Windshield Sprayers are AIMABLE!!
Discussion in 'Gen 2 Prius Main Forum' started by TonyPSchaefer, Jul 3, 2005.
  1. patsparks
    10,664
    569
    Adelaide South Australia
    Check there is nothing blocking the pickup in the reservoir and unblock with a pin and squirt. If you use air don't blow directly into the nozzle as you might pop a tube off or split one. Blow across the nozzle to create a vacuum. Most times a nozzle is blocked it's either dirt in the reservoir or car wax and polish.
  2. mdh
    mdh New Member
    48
    tks much... will try
  3. Pay2Play
    Pay2Play New Member
    BUCKEYE Country
    My problem was similar, what I found was the hose is routed next to the hood hinge and when the hood was closed it would pinch the hose. Once that was fixed the washers sprayed correctly.
  4. mdh
    mdh New Member
    48
    BINGO... that gave me back the water pressure... now i just need to adjust the jets.... super!!!!
  5. patsparks
    10,664
    569
    Isn't it true, a problem shared is a problem halved.
  6. Syclone
    Syclone Member
    540
    Speaking of windshield washers, a couple of weeks ago I was removing snow from my hood with a plastic snow removal tool and "shoveled" off one the spray heads.
    Is there any non Toyota source for a replacement. I just hate to lay out $25.00 for a little piece of plastic. :(
  7. mdh
    mdh New Member
    48
    now i need to figure out what is the correct position for the hose so i don't crimp it every time i open and close my hood???? Any pictures?
    tks all,
  8. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    I think most modern cars have adjustable washer jets. I remember while in high school, we used to aim the passenger's side jet to spray as far to the right as possible. That way, we could slow down, drive a little closer to the curb and squirt the girls walking on the sidewalk as we drove by.... great fun!
  9. Tideland Prius
    16,681
    Ever tried it with an STI? It has a button you press to spray water into the intercooler. Some have rerouted that hose =Þ
  10. Chris Dragon
    Chris Dragon Junior Member
    22
    The official Toyota repair manual says "Using a TOYOTA 4 Way Nozzle Adjustment Tool (part number: 95060–10010), insert the bumpy potions of the adjustment tool into the bumpy potions of the nozzle jet and make the adjustment. ... Do not use a metal pin or other such tool as it may damage the nozzle jet."
    Unfortunately I can't find anyone selling a 95060–10010 tool so it seems we're stuck with the pin. It also has a diagram (attached) showing where all the streams should impact the windshields. Since it shows positions for the rear windshield, that sort of implies you can aim the rear nozzles as well, but it doesn't actually say if they're aimable.
  11. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I have been using a long needle with success.
    The washer reservoir holds exactly four litres of fluid and I seem to romp through it on our PiP. It seems to use twice as much as our old gen 2 did. I suppose the headlamp washers use some more but I feel I am using double the fluid amount.
  12. Alan Claver
    Alan Claver Junior Member
    79
    Central Pennsylvania
  13. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    So let me get this right - I stick a pin (needle) or some other very thin rigid object INTO the washer nozzle and just move it? Its that simple?​
  14. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Only since the 1960s...
  15. PriusGuy32
    1,417
    514
    Dang...they dont call me Moonbeam for nothin'... after Im done groovin' I will take a look at the car. Peace, love, and aimed nozzles. :D
  16. Air_Boss
    4,259
    1,197
    New Yawk
    It's usually a once-in-a-lifetime factory aiming effort, so don't sweat it!
