Crasher parts to convert to pip
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Mr.Electric, Jan 21, 2014.
  1. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I'm curious what everyone thinks of this crazy idea. To be honest I'm just thinking this over and will most probably not do it.
    My co worker totaled his pip base model. I have a 2010 Prius 4. I have two auto lifts and a tech stream and a full mechanics tool set.
    Would it be possible to switch the pack , computers etc to make a pip out of a standard Prius.
    Let's assume the crashed car inverter and engine are crunched because it was a front end wreck. I also wonder if the rebuilt car could ever get the clean air sticker.
    Bill the Engineer and drash like this.
  2. JC91006
    JC91006 Senior Member
    16,857
    8,617
    just take his bumper with the clean air sticker and put the bumper onto your car.
    rogerv, fotomoto and chesleyn like this.
  3. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
  4. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    Please see my post (My Recycled Pip) in the "Newbie" forum. While I am totally confidant it is possible I also know, for certain, that it is not financially wise! You'll need to transfer the entire wire harness, that alone means totally striping both vehicles. Without extensive research it's impossible to tell what major sub assemblies can come from your car if the corresponding part on the donor PIP is not usable. It may well be that the inverter, engine and transmission are unique to the PIP.
  5. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    i also think the pip has a bigger and more powerful electric motor because it also can work as a ev
  6. drash
    drash Senior Member
    2,590
    1,335
    Upstate NY
    XLE AWD-e
    If anybody can do it you can. I would say it is possible because the parts are pretty much identical except for the computers, wiring, and battery pack. You'd have to lose the spare tire (your car I'm still talking about here) and do some undercarriage work to make room for the battery as well as find a place for the recharge port. Might need to upgrade the shocks.
  7. davekro
    davekro Active Member
    529
    83
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Yes, I believe the M2 electric motor is bigger on the PIP.
    Besides Priusmpg's comment above, your comment also does not consider the many possible variables mentioned in Jerry's comment below.
    I'd agree there are a many unanswer(able?) variables.
    In theory, all these variables should be answerable.
    In PRACTICE... well just ask your dealer (or Toyota) a simple question about Entune or what alarms can or cannot be reset. The misinformation mentioned on this forum is rampant. I can't even imagine the stonewalling and or misinformation you'd get on this topic WHICH ACTUALLY IS COMPLICATED! ;)
  8. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I think it would be cool if you ended up with a unique car. Like if the pip was not available with solar sunroof which mine has or if there was some other desirable outcome better than the alternative of looking for a dealer with a good price on a brand new pip.
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    The only thing I can think of is like that company who sells battery extender kit for the gen 3 Prius. You could see what's in their kit
    iPhone ?
  10. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    It would be more attractive if you did not need to swap the transaxle and the wire harness. The inverter and rear battery components and hv wiring would be a reasonable project on their own.
  11. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Mr Electric
    Rather than make your car into a PIP, why don't you use your car as a basis to REPAIR the PIP. Of course, this depends on how the PIP was totaled. It is a lot less hassle to get a new PIP, of course, especially if you can get a good price for your old Prius. And then you know what you have and it is marketable later.
  12. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    "The only thing I can think of is like that company who sells battery extender kit for the gen 3 Prius. You could see what's in their kit
    These kits are very simple and DO NOT result in a well integrated, system, or any thing like the PIP's characteristics or performance. While the PIP is a very well integrated, meticulously engineered marvel!
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Sorry, I was just bringing up a cost effective solution
    iPhone ?
  14. Jerry Liebler
    177
    85
    2013 Prius Plug-in
    "Rather than make your car into a PIP, why don't you use your car as a basis to REPAIR the PIP. Of course, this depends on how the PIP was totaled."
    One needs to be aware that some "totaled" vehicles are retitled with "certificate of destruction" titles which make that VIN incapable of ever being licensed again anywhere.
  15. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    The OP is located in California and vehicles that are considered a total loss by a insurance are issued a "salvage titile", which can be re-registered with a simple brake and lamp inspection for around $50.
  16. hill
    8,951
    Is it possible? You're kidding, right? It's been going on for what ... maybe 10 years now? You're a day late & a doller short (ok maybe a bit more than a day ;) )
    Plug-in Toyota Prius Hybrid - A123 Systems Hymotion Conversion Kit | Auto News Blog at InternetAutoGuide.com
    There are literally dozens of companies that have turn hundreds & hundreds of non-plug in Pri into PiP's. So yes ... not only is it possible ... it's been done. A lot. Check out some of the other sub catagories here, as several Pri owners on PC have dont it. Do it !!
  17. ETC(SS)
    7,379
    I think that you're dealing with 2 separate issues here.
    Getting the new FrankenPip out of the hangar, and getting the kindhearted folks down at the DMV to believe that a vehicle with a G3's VIN has been successfully transmorgified into a Pip.
    Depending on how badly the front got chewed up and how much the insurance company is going to want for the hulk, I'd say part it out and get a conversion kit.
    If you're going to just bolt the bumper on your car?
    Attach a charger door and some of the Pip badges as well, or somebody will dime you out. ;)
    Good Luck!!!
    Let us know if you try it!!!
    Not the bumper swap....the Pip conversion.
  18. markabele
    5,084
    1,782
    Nebraska
    You always seem to respond in the nicest way possible ;)
    I'm pretty sure both MG1 and MG2 are the exact same on the PiP and non-PiP.
  19. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Too bad the wrecked PIP is in San Francisco. I would LOVE to get my hands on it for my project!
    Bill the Engineer
  20. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I like the project! What about a Prius drivetrain in an old jaguar saloon or a 40's sedan.
    I've often wondered how the Prius drivetrain would feel stuck in a different car. Like a nice clean 2005 Cadillac Deville loaded with all options.
