2007 Prius Touring use to get only 38 to 40 mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by gjsullivan, Jan 14, 2014.
  1. gjsullivan
    gjsullivan Junior Member
    Hillsboro
    My 2005 Prius with 86K miles regularly got 48 around town and 49 to 53 on long trips. I sold it to my son and his wife, they are also getting the same mileage. I bought the 2007 touring used with 41K miles and have never gotten over 41 mpg highway, and around town is 38 to 39 mpg.
    The biggest difference I can see is the power flow display shows it keeping the battery at 7 bars and will be charging the battery when I am driving uphill even with the battery at 7 bars. It has never let the battery get down to 4 or 5 bars even on long up hills.
    - Current car, *** 2007 Prius Touring w/41K miles
    Proposed questions:
    Have you read This Thead Yet? *** Yes I have read all the low mileage threads.
    - What region/state are you in? (if not already set by the user) *** Hillsboro, Oregon ( just outside Portland )
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations) . *** the best was 40.1 on trips and warm days, 38 to 39 around town. Using trip computer and manual calculations they are within .2 MPG.
    - What fuel economy are you expecting and why? *** 48 around town, 49 to 53 on long trips 300 miles. Why? My 2005 Prius regularly got this mileage. I sold it to my son and his wife, they are also getting the same mileage. I bought the 2007 used with 41K miles and have never gotten over 41 mpg. For highway mileage we make trips from Portland to Seattle often and always got 48 to 53 MPG even with 4 people in the car or a load of stuff in the back. Why would my 2007 get about 10 mpg less than my 2005 ?
    I know I am on winter gas in Oregon ( 10% ethanol ), that and winter cold normally cost me 3 mpg. So factoring that in, my 2007, 42 around town, 43 Highway. Compared with my 2005, 48 around town and 49 to 53 on the highway.
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What was its EPA rating and what did you get on the same trips/commute? (EPA ratings can be found at ) *** Prius 2005 with Michelin Energy Saver A/S 195/65/15 tires and new Optima yellow top battery, 48 around town, 49 to 53 on long trips. My best mileage was 63 MPG for a 150 mile drive in south west Washington state.
    - What are your tire pressures? *** checked cold. When purchased it was at 35 / 33, after our second trip to Seattle with poor mileage I upped it to 41 front, 40 back and got pretty much the same poor mileage.
    - What are the approximate outside air temps? *** 45 to 60 normal days, 25 to 45 on a few cold days.
    - How long are your trips? Around town, 5 to 10 miles, *** For highway mileage we make trips from Portland to Seattle often and with the 2005 Prius always got 48 to 53 MPG even with 4 people in the car or a load of stuff in the back.
    - How much of it is city vs. highway? Roughly what's the average speed in overall and of each segment? Is there a lot of stop and go driving? *** Daily around town is 25 to 45 mph, suburban driving with 1/2 to 1 mile between stops. Highway is 55 to 70 based on speed limits. 3.5 hr drive time to Seattle. We make this trip every 6 to 8 weeks.
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.) *** Around town mostly flat, Highway mostly flat with some moderate hills in southern Washington for about 30 miles.
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    *** Moderate acceleration, avoid braking, glide to slow down. ( same style we got 48 to 53 mpg in our 2005 Prius.
    - What modes are you using, if any? "normal", EV, power, eco? *** only has normal mode
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on? *** No start and go, except for the few days when it got down in the twenties and had to wait for it to be warm enough to keep windshield from fogging on the inside.
    - Are you driving using D or B mode? *** D only
    - Is your oil overfilled? (i.e. above the full mark on the dipstick) *** No, right on the full dot.
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to? *** Normally Auto 68, or off
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15). *** Replacement tires came with car, Hankook Ventas V4se, 195/55R16 ( Standard size for Prius Touring )
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute? *** Went from 2005 Prius with 86K miles to a 2007 Prius Touring with 41K miles.
    Have you had your alignment checked? Any pulling or abnormal tire wear? *** No pulling or abnormal tire wear.
    Power flow screen info
    *** I've been watching the power flow screen to observe its behavior and I've noticed that it relies on the gas engine far more than the 2005 used to. For example, when going uphill, it is at 7 green bars and it often is charging the battery, not drawing power from the battery. It has often been maintaining the battery at 7 bars in the green zone.
    My 2005 would draw it down to 4 bars on long up hills and then charge to 7 or 8 on the long down hills.
    Battery
    *** The battery looks to be the original so about 6 years old. I have been checking on the 12 volt battery using the "hold info flash headlights 4 times" display technique and with a digital VOM. For the load, I turn on the headlights, rear defroster, windshield defogger fan and let them run for 2 minutes. While not the highest voltage it certainly is still in the usable range.
    Display DVOM at the battery terminals
    No load Load No load Load
    12.0 11.1 12.3 11.64
    When I turn the car on (engine running) the voltage goes up to 14.5 volts.
    Does the ICE run longer than expected when you stop? *** Once warmed up, at a stop the engine does stop after its normal 7 - 10 second run time.
    Do you upper grill block in the winter? *** No
    What actual brand/grade of gas? *** Costco 87 octane
    What oil weight? *** 5w30
    Have you pulled the engine air filter? is it clean? *** Yes brand new
    Have you taken a look at your MAF intake/sensor. *** Have not checked or cleaned it yet.
    52,350
    doesn't the touring have larger inefficient wheels? i think you need a new 12 volt.
    silverone likes this.
  3. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The touring versions do usually not get quite as good of fuel economy as the non-touring versions due to the wider tires. There's still room for improvement.
    One item to check that isn't in the questionaire is to make sure the parking brake isn't dragging. I've heard of service departments adjusting the parking brake a little too tight so that it drags a bit when it's off. If you have the opportunity, lift a back wheel off the ground and feel how much resistance it has with the parking brake off.
    The Ventus V4 ES H105 is in the "ultra high performance all season" category and may not have the lowest rolling resistance. That category usually uses softer rubber compounds for adhesion and doesn't usually have LRR as a priority.
    I experience better fuel economy by never using the climate control in "auto" mode. In auto, it seems like it's always drawing on the system in some way or another, frequently using the A/C compressor and causing heat demand, which causes the ICE to run more often than otherwise needed. Try only using climate control under manual control, as needed. When it's cold, I usually drive the first 5 minutes or so with the climate control off to allow the drive train to warm up a bit before introducing the heat demand.
    With some pulse/glide, your low speed (41 mph and below) averages should be quite high. ~70mpg or more once warmed up. At higher speeds, higher mpg becomes more challenging.
    Don't forget to reset your mpg average readout if you haven't as it does not automatically reset with the fuel fill-up as the mile counter does.
  4. JC91006
    JC91006 Senior Member
    16,827
    8,600
    so I would just clean the maf Sensor and throttle body. I also have had very poor mileage from Costco gas. I would try something different.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Thanks for filling out the questionnaire! It really helps in situations like this.
    First and foremost, you really can't compare the "touring" to the non touring as it is a well known fact that the two models generally show a lower MPG average overall, with the touring being the lower of the two.
    I am going to add this tidbit that stood out to me in your answers above.
    On your previous Prius you were using one of the best if not the best LRR (Low Rolling Resistance) tires that is available. That being the "Michelin Energy Saver A/S" That alone will boost the average a good three to five MPG for most drivers. Even more for folks who hypermile. The tires that are on your "touring" Prius are not as efficient when looking at LRR ratings as the former tires. Your tires that you have now are more along the lines of "sport and touring" and are really not a LRR type tire which will help to contribute to the lower MPG you are reporting.
    When you consider those facts along with the fact that your 12 volt is beginning to weaken, it sounds to me like your "touring" model is operating normally for your use thereof in it's present condition. 12.0 and 12.3 volts for "no load" is around 50 to 60% of full charge. A fully charged AGM type battery should measure 12.8 minimum with "no load" present. Hooked up (installed) with no load should read about 12.6 to 12.7 as there is a low quiescent draw on the battery when sitting idle and the Prius is powered down.
    I don't think you have any problems with the traction battery. If I had any concerns about that whatsoever it would be to make certain that the flow (turbulence) is good in the inverter coolant reservoir under the hood and that the reservoir is full.
    If I were interested in trying different things to improve the MPG I would consider these options.
    1. Clean throttle body and MAF
    2. Check and realign if necessary the tires on the car.
    3. Consider getting LRR type tires in the future.
    4. Invest in a new 12 volt battery.
    5. Check to make certain that all four wheels are rotating freely and that none of the brakes are dragging.
    6. Consider purchasing fuel from the top tier brands.
    7. Raise your air pressure some more. 51 is the max on most of the Hankooks. Check the maximum pressure rating marked on the sidewall before you set the pressure.
    8. Last but not least, slow down a little on the highway. 60 to 65 will increase the MPG versus 70 or higher especially on those long trips. The time factor won't be much of a difference but the MPG will improve. Don't forget to pulse and glide as much as possible when driving in city traffic. P&G will make a big difference in the MPG with a Prius when it used regularly as traffic allows.
    Best of luck to you.
  6. gjsullivan
    Hillsboro
    Thanks for the excellent answers.
    I will start with 1, 2, 4, 5, 6, 7,
    Re Tires, they are brand new and if going to Michelin AS and I got 4 mpg improvement it would take 1,463 gallons and 64,390 miles to offset the cost of new Michelin AS tires. So I will live with those.
    On Fuel, it is the same fuel I got 49 to 53 miles per gallon with on the 2005, and the same I got my best 63 MPG with. So I don't think it is an issue but when I have a chance I will try shell for a while and see how that goes.
    Re 70 mph. I only do that when on I5 on rural parts of Washinton state. When in Oregon it is 55 to 60 and I get the same 40 mpg. :-(
    The thing that concerns me is the power flow where it is trying to charge the battery uphill when it is already at 7 bars.
  7. dorunron
    3,318
    1,105
    Houston, TX
    Sounds like a plan to me. Of course you should not scrap new tires, that is why I said "in the future". When you do look for new rubber, consider the Bridgestone Ecopia 422 - The Michelin Energy Saver A/S is difficult to find in the size that fits the "touring models". The Ecopia is a very good LRR type tire and comes highly recommended by many Prius owners.
    I have read on a few other post's here on PC that some with the tires you have found once they went up to 45 or so, that the number improved.
    Remember the "touring" traditionally gets LOWER mileage than the non touring models.
    One of the reasons is the tires. They are wider and also a lot heavier.
    Also back and forth arrow movements on MFD even at 7 bars is not unusual. As long as you not generating any codes or malfunctions you really can't do anything. Every mechanic out there will tell you that there is no problem with the car and try to give you advice on how to improve MPG.
    I looked again at your answers above. You might also consider turning off the "a/c compressor" and make sure you are NOT recirculating the cabin air. That too will cause a slight drop in MPG, not much but it does make a difference. The temp is Ok, but what is getting you is in "auto" mode the electric a/c compressor is running. When it is cool or cold outside the engine will also run more to supply heat to the cabin. You did mention the temps which are cool to cold this time of the year.
    Hopefully once the warmer temps returns your numbers should improve. Please read the attached pdf file.
  8. gjsullivan
    Hillsboro
    Thanks folks,
    I just put the tires up to 45 lbs all around ( max is 51 )
    Put a note in to not use "Auto AC" , ( my wife also drive the car )
    Ordering an Optima yellow top battery
    Will clean MAF and check brake and tire free wheeling this weekend.
    Then see how things go after a couple of weeks.
  9. bisco
    52,350
    'my wife also drives the car'. say no more, my wife has my car right now, 'oh, the humanity'!:p
  10. gjsullivan
    Hillsboro
    Installed the New Optima Yellow top battery
    --------- on MFD---------------- on DVOM at the battery
    --------- No load-- Load------------No Load
    New ----12.6------ 12.1---------------13.6
    Old -----12.0-------11.1---------------12.3
    * put the dashes in, to keep it from compressing the lines like last time
    Also cleaned the MAF
    Jacked it up and:
    Checked the Emergency Brake and it is not hanging up.
    Checked the wheels and they are free rotating with no drag
    I am going to stop here and see how mileage does for a few weeks. Once I baseline the new mileage with these changes I will try changing the gas for a few weeks and see how that affects things. Costco prices are the best around so I would have to see a significant increase in mpg to justify paying the higher price per gallon.
    FYI, I got the Optima Yellow top at streetsideauto.com for just $147 w/free shipping
    Shipped from Pennsylvania, came cross country fedex in 5 days.
    I did not have to work with them at all as everything went fine.
  11. gjsullivan
    Hillsboro
    After reading some info on cleanmpg.com there is info backing up that there are few reasons not to run tires up to the sidewall pressure. Also a person there has determined that 4 psi diff between front and back is optimum. So I now have my Hankook Ventus ( 51 psi max ) @ 49 / 45. This last week I also cleaned the MAF and installed the optima. My mpg is now up to 45.2 , it was at 38. I am thinking that most of that comes from running the tires up near the rated psi. This is without changing driving style and it has been with 3 or 4 people in the car. ( My inlaws were visiting for a few weeks ). Factoring in the normal winter driving drop of 4 mpg this puts the summer mileage equivalent at about 49 mpg and that is in line what I was getting with my 2005.
  12. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    If your car has 185/65/15 tyres it is not a touring version, or someone has changed the wheels. The touring version of the Prius Comes with 16 inch wheels, and the tyres fitted are 195/55/16.
    These are the same wheels as fitted to all UK/EU gen2 Prius, we do not get the 15 inch wheels.
    You can confirm if your car is a touring with smaller wheels fitted by looking under the rear of the car at the shocks. If they have white and pink bands painted near the bottom of them it is not a touring version.
    The difference in fuel consumption between the touring and non touring is marginal. I get an easy 65 mpg
    (UK gallons) in the summer with temperatures around 20/25 C using 205/55/16 tyres.
    John (Britprius)
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi John, in the opening post he said: " *** Replacement tires came with car, Hankook Ventas V4se, 195/55R16 ( Standard size for Prius Touring". So the wheels definitely look right.
  14. Britprius
    5,194
    1,922
    Sorry yes my misreading of all that information.
    John (Britprius)
  15. gjsullivan
    Hillsboro
    2nd tank after putting tires up to 49/45 ( max is 51 on the Ventus ) replacing the battery and cleaning the MAF.
    My mileage is 47.2 :) :) (up from 38 to 39 mpg )
    I used my micrometer and checked the tread depth to 10/1000 of an inch on the inside/middle/outside. I will track that and see if they are wearing evenly over time. Not wearing out the center.
    My son put his 2005 Prius Michelin Energy saver AS tires up to 42/40 ( max 44 ) and his mileage went from 41.7 to 46.7.
    Not bad for winter gas.
  16. gjsullivan
    Hillsboro
    Had Seattle trip. Portland to Seattle with 26 miles around town before trip. Driving speed limit including 70 mph from Vancouver to Tacoma with wife using cruise control. 48.1 mpg. Trip back 60 mph no cruise control 50.8 mpg on winter gas. 20140309_214232.jpg
  17. dorunron
    3,318
    1,105
    Houston, TX
    gj,
    It sounds and looks as if you have a handle on it now! Good job, keep up the good work. I bet you are happier at the pump now than when you began this string two months ago. Summer will be upon us soon, and with that usually even better MPG.
    Best of luck to you, and enjoy your Prius.
    Ron
  18. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    So the question without reading all of the previous links.. 87 or 91 octane to get the best MPG and efficiency.
  19. dorunron
    3,318
    1,105
    Houston, TX
  20. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    Why? Isn't 91 cleaner fuel? All my other cars run better on 91 than 87. I also stay away from Costco gas.
