Oil filter cap caution
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by spiderman, Feb 15, 2014.
  1. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    i am a muscular kind a guy being a you know a super-hero and all but there is no way i put that kind of torque on it last time. hmm.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,718
    1,758
    Bay Area
    Hey Mendel,
    This is what I used for removing my Honda Oil filter :D much better grip haha
    2" to 4-1/4" Oil Filter Wrench
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Thanks for sharing you trouble. I will be inspecting my oil filter housing more carefully from now on before I reinstall it.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    You don't even know your own strength! WOW! (y)
    DadofHedgehog and spiderman like this.
  5. sooperedd
    sooperedd Junior Member
    48
    Colorado
    Did my first oil change today and found out that the dealer had the housing on way too tight. I had a heck of a time getting it off. I have the right wrench but I chipped a piece of the housing off because I had to tap it with a hammer to break it free. Learned a few things to make it go faster next time.
    Oil was a little dirtier than I would like to see it so I might go to 7500 mile OCI.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, I would highly recommend using a block of wood between the cap and the hammer. What piece broke off?
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I did want to clarify that the reason for this thread was to point out how brittle the oil filter cap seemed to be, not how tight it was. The cap seemed more susceptible this time around then in the past. The material just crumbled.
    The cheapest replacement I found was $30.
  8. sooperedd
    48
    Colorado
    One of the plastic flanges. I was using a large Torx screwdriver to tap it off.
  9. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I glued my filter wrench to the cap,problem solved
    garglo and retired4999 like this.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    One thing is for sure!
    You will not lose your wrench, maybe both wrench and cap, but you will not lose your wrench! :p
  11. gliderman
    gliderman Active Member
    751
    225
    I did that too. Now I have a good wrench as spare cap just in case.
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Spiderman,
    I changed my oil and filter this weekend at 75k miles. My oil filter cap looks new, nothing like the one in your picture. Could it be the weather up there and the salts, etc. on the roads?
    Yes, we are getting on up in the mileage now. It seems like yesterday we were all new Gen III enthusiasts comparing notes on our new vehicles.
    Dwight
  13. Mendel Leisk
    41,780
    I've got one problem with this: I need the that socket for our son's Civic (same filter size), LOL.
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Same here, mine fits my wife's Honda Accord.
  15. tankyuong
    1,555
    662
    Central MO
    Caps are cheap at harbor freight
  16. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Curiousity Question: Is that Oil Filter cap the same as the one used on my 2009 1.8L Pontiac Vibe? Sure looks like it is.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    P
    Probably since it is a toy engine.
  18. Mendel Leisk
    41,780
    Very possible. It is a Matrix under the skin, and parts get swapped.
  19. Mike500
    Mike500 Senior Member
    2,593
    767
    The Pontiac Vibe uses the same Toyota engine as did the Corolla of the same year.
    Both were made at the joint venture NUMMI GM-Toyota plant in California.
    The plant closed down with the GM bankruptcy, and the joint venture ended.
