How can I mod the DRL to have it on at all time? (for 2013 models)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by m3rhkp, Apr 26, 2013.
  1. niteryder
    niteryder Junior Member
    39
    Earth
    So, I would like to take this a step further and have the DRL leds dim when the headlights go on. Like Mercedes.
  2. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    You have to get a drl controller and rewire.
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Here's some eBay DRL control modules that might work:
    Link 1
    And this one, looks like you can wire it so that the DRLs flash along with the corresponding turn signals. Link 2
  4. sidgarza
    sidgarza Junior Member
    I will do this pretty soon. Is there a 'under the hood' wire that I can access rather than the bumper DRL wires?
  5. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    I'd like to make this change too. Sure would be nice to just jumper power within the fuse box as some suggested ( but needed to see a schematic).
  6. scooter4n
    scooter4n Junior Member
    27
    27
    HOLD ON YO ALL.
    You guys are taking this way far. Taking bumper off, rewiring from DRL lights to the fuses... Voiding warranty if tech will see that during the service....
    This can be done allot easier, just by adding wire in the fuse box.
    Blue relay is the DRL relay.
    Without bypassing fuses and rewiring, I took BLUE DRL relay out and jumped the 12V plug to the lights from different source.
    Plugged wire from fuse to the center pin of the DRL relay, and here we go.
    DONE DEAL..
    You re welcome....
    NOW, here is something to think about.
    If you still under warranty, and taking your car to service, I would recommend to put it all back to normal.
    Technicians checking all of your lights functionality, checking for bad light bulbs and so on.
    If they find out of your "MOD", this can be a problem for you.
    But for now, enjoy and good luck...
    Drepdom, RMB, bdirwin and 13 others like this.
  7. scooter4n
    27
    27
    Only problem I see with my mod is that DRL lights re ON all the time when car is ON.
    I would like to tap that relay so DRL's can turn off when light switch is OFF, or fid DRL relay so it stays on.
    Now here is what happens, power to the coil of the DRL relay 12V + is always on, only thing switches ( turn relay OFF) is 12V- negative side of the relay coil, if some one has schematic and can trace where the negative wire from DRL relay house is going, we can fix this once and for all, so DRL lights can turn off with the light switch and everything stays on when you want it to.
  8. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    I would definitely be interested in the Rev. 2 mod scooter4n suggests if/when it is discovered.
    (shameless bump of scooter4n's great idea) ;)
    whitmanrf likes this.
  9. priuslifestyle
    priuslifestyle New Member
    So i did this and i got a message on the dash saying "check hybris system stop the vehicle in a safe place"
    Is there a way to have this not come up ?
  10. peterjmc
    917
    189
    Clarksburg, MD
    Anyone know what wires to jump so that the "parking/corner lights" are setup to be used as DRL? I'd much rather use the "auto" lights function on my headlight stalk, but would rather have parking lights on at all times as DRL (which also illuminate the rear tail lights) rather than just the DRL front lights.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    1 of 2 things happened:
    1) U pulled the fuse with the prius still powered on.
    2) when u added the wire in the fuse, the fuse didn't make full contact causing the error.
    If it's done correctly, u shouldn't have had the error.
    U can use a OBDII scanner, tech stream, scan gauge II to clear the error. If it comes back, the wire tap isn't allowing the fuse to make full contact.
    VS980 4G ?
    Wilfredo likes this.
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    The turn signal lights are a better option for DRLs because they are brighter than the parking lights. I don't believe the parking lights would be visible in bright sun.
    The webelectric module is perfect for this. PriusChat member Offline has a writeup in the Prius v forum with pics. I believe he had also uploaded instructions on the webelectric website as well.
    WebElectric DRL-2P installation into 2012 Prius v | PriusChat
    SCH-I535
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    No mod required? Just leave parking lights on at all times. I don't know if all Prius are equipped with delayed headlight shutoff. My 2012 is and that is how I pulled into work this morning.
    iPhone ?
  14. peterjmc
    917
    189
    Clarksburg, MD
    I do just in general leave the parking lights on at all times. I would like to use the "auto" function on the headlight stalk. This function automatically turns on the headlights once it detects low light levels like if you were driving into a tunnel, under a bridge, into a parking structure, or daylight is fading away.
    This is different from the headlight auto shutoff feature when the headlights turn off by a defined timer after the vehicle is turned off.
  15. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    now THAT would be nice/
  16. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    Bump. Any conclusion to this to having drl led lights to turn on and off with the stalk switch along with the headlights?
    iPhone ?
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm working on the schematic. Its taking a lil but I should have something in a week.....I hope.
    VS980 4G ?
  18. xliderider
    8,140
    3,276
    Honolulu, HI
    Easily done with a relay and a wire tap.
    SCH-I535
  19. StarCaller
    1,277
    729
    mind posting a wiring diagram?
  20. xliderider
    8,140
    3,276
    Honolulu, HI
    We'll see what Sean (sfv41901) has. He's very knowledgeable. (y)
    SCH-I535
    sfv41901 likes this.
