If you've lowered your Prius, then this thread is for you...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by JFrentzen-closed, Jun 29, 2012.
  1. jameszhc
    jameszhc Junior Member
    China
    My 2012 GIII with TEIN Street Advance,Tanabe bars ... etc.
  2. peterjmc
    917
    189
    Clarksburg, MD
    Nice. How do you like the street advance? I'm hoping full soft setting is close to stock. Still haven't gotten around to installing mine yet.
    Nexus 5
  3. jameszhc
    China
    Thanks. I haven't actually checked the "full soft" setting but set it at about 2/3 hard which allows me enjoy its handling. As it is 16 section hardness adjustable, you would like to do a lot of test drive to find the setting suits your driving style most. It is simply preference.
  4. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    I am wondering why coil overs aren't being used to lower these cars and control the rebound better? My fear of using stock struts with lowering springs is that the cars end up prematurely wearing the struts out and the cars then tend to bounce. Thoughts?
  5. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    That was my thinking...
  6. WE0H
    WE0H Senior Member
    3,247
    528
    Me too. Coil overs would be the best approach with adjustable compression & rebound dampening. My reason to have what I have today is I wanted to order something bone factory stock and not have to turn a wrench on it other than maintenance. I have had my fill of mod cars and wanted to get something decent without out all the work.
    Mike
    Jay J likes this.
  7. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I have coilovers on mine; its quite a bit stiff but I like my ride to be more dampened vs oversprung.
    WE0H likes this.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    A person could run with any spring rate that suits them from soft to stiffer than a board :D
    Mike
    Jay J likes this.
  9. Xterra72
    Xterra72 Senior Member
    1,437
    1,682
    20141010_074133.jpg Finally decided to drop the Prius with the TRD Springs. Letting the springs settle. I will have the alignment done next Tuesday. The car drives straight and no play on the steering wheel. I am still worried about the alignment. I hope everything are within specs and can be adjusted to within specs if not within range.
    peterjmc and WE0H like this.
  10. GregP507
    GregP507 Senior Member
    3,002
    481
    My Prius is low enough. I keep scraping the front spoiler and I'm really concerned about getting around in the snow this winter. I'd like to have an easy way to raise it, actually.
  11. Xterra72
    1,437
    1,682
    Definitely a concern. I live out in California. We are currently in a drought and as long as I stay out of Lake Tahoe in the winter when snow comes down , I will be okay. With the TRD, drop was minimal but enough to fill in that annoying gap.
    WE0H likes this.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    I drive a Kia Soul in the winter. Plenty of ground clearance ;)
    Mike
  13. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I can't recall if I posted this video here yet but here is my '13 Prius before and after lowering:
  14. Xterra72
    1,437
    1,682
    Hello. So How are your springs holding up? Are your struts still holding up okay with the extra stress of the lowering springs? Are your alignment still within specs after you lowered the car? Any alignment problems? You did not have to use any kind of camber kits or shims to correct any alignment issues if you had any did you? I would like to know what I am getting into. Let me know. Thanks.
  15. mediahound
    903
    155
    None of those issues at all so far. The Prius Plus kit is made to work with the stock struts etc.
    WE0H likes this.
  16. Xterra72
    1,437
    1,682
    Thanks for the quick response. Did you wait for the springs to settle before getting the alignment? If so how many miles did you drive it before getting the alignment. Also did you have everything retorque to specs before getting the alignment done? I have searched but the answers I found were not consistent. Thanks.
  17. mediahound
    903
    155
    I didn't worry that much about it. I think I did alignment a few days after having the springs installed. The shop said they usually just do it that same day even.
    WE0H likes this.
  18. Xterra72
    1,437
    1,682
    Thanks. Good to know. I have already installed the TRD Springs. I am having the alignment done this coming Tuesday. I am crossing my fingers that everything can be adjusted back to or close to the alignment tolerance specs. Good to know we have a few northern california prius owners modding their priuses. Maybe we will all see each other on the road someday and see our mods in person. Thanks again for your help. I'm sure the video you made has helped a lot of people make up their minds if they want to lower their car or not, including me.
  19. Dr.E777
    Dr.E777 Junior Member
    I installed the TRD lowering springs and the TRD rear sway bar and what a difference! Totally worth the money!
  20. Xterra72
    1,437
    1,682
    Finally had my alignment today. Front alignment were within the given tolerances. Left rear was also within tolerance. The right rear toe was outside the higher end tolerance of .28 degrees. It was at .29 degrees and obviously it was non adjustable. So right rear toe off by 100th of a degree. Dealer says it was nothing to worry about because it was minimal and insignificant. They believe it came out of the factory this way. They said tires should still wear normally.
    #160 Xterra72, Oct 21, 2014
