Dealer wants to replace both auxiliary and hybrid batteries
Discussion in 'Generation 1 Prius Discussion' started by Tashfeen Ekram, Jan 23, 2014.
  1. Patrick Wong
    18,198
    6,464
    It is not typical for the cables to corrode. You should visit the dealer and look at them, before authorizing the repair, so you can satisfy yourself that the problem exists.
    The cables will carry high current, so the connections must be perfect.
    Tashfeen Ekram likes this.
  2. Tashfeen Ekram
    Tashfeen Ekram Junior Member
    29
    Fremont, ca
    2001 Prius
    Great. I am leaving to go check them out. Should there be no corrosion on it to be normal?
    What if these is some but not a lot?
    Here are some pics on the site below with corrosion on the leads. Is that considered a lot?
  3. Patrick Wong
    18,198
    6,464
    Ask if the corrosion can be removed, for example, by sanding with very fine grade sandpaper.
  4. Tashfeen Ekram
    29
    Fremont, ca
    2001 Prius
    Sounds good. Will ask to do that!
  5. AlexY
    AlexY Member
    160
    45
    UK
    They should never corrode, one end is closed in the battery other in the inverter, all along is secured with plastic cover, I suggest ask them show you damage, take good photo (macro, with good light) and post it. Rust on connector increases resistance, at current used from this battery (range 60-80A) power dissipated equals to R*I^2 where R can be under 1 ohm if there is really rust (so it could be up to 6400W but rather something around 500W lost on rusty connection). There is no risk of fire, only risk of another failure. Possibly there is only patina (not sure this is correct word) which can be cleaned with metal brush. The problem is this is dealer so only one option of repair is replacement.
  6. PriusInParadise
    180
    91
    Hawaii
    The three cables that are being recommended are likely from the battery to the negative SMR, battery to positive SMR, and battery to the service plug assembly. These are inside the battery housing, and one end of each are attached to a battery module.
    Electrolyte leakage from a battery module terminal can corroded the cable terminal in a manner similar to corroding the bus bar. The difference is that the electrolyte can creep into the cable where it is crimped to the terminal. It would be very difficult to remove the corrosion and neutralize the alkali electrolyte if it has gotten under the insulation of the cable.
    You might be able to get away with cleaning only the cable terminals, but the residual electrolyte can cause the corrosion to return.
    The dealer has to guarantee their repair, and so they recommend replacement.
    bwilson4web and Tashfeen Ekram like this.
  7. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    716
    Boulder Hybids, Boulder, CO
    The dealer is trying to pad the invoice. The only cables that corrode are part of the busbars between modules inside the battery, and if you buy a new battery (or Dorman rebuilt) they come with new busbars!
    The two ends of the pack and the middle terminals that go to the orange disconnect plug (4 connections total) can easily be cleaned. New dealer batteries even come with 4 shiny new nuts for these connections.
    If you want a new battery installed in the East Bay run from that dealer and talk to Hybrid Battery Repair | Hybrid RepairKensington Service Station
    Tashfeen Ekram and yotatoter like this.
  8. Tashfeen Ekram
    29
    Fremont, ca
    2001 Prius
    So, I went there and looked at them. I stupidly did not take pictures. When I looked at them, it did not seem like a lot and asked them to clean as best as possible. Below are pictures from Art's Automotive's website (not from my battery). It was definitely less corrosion than what you see below. It was corroded on the end of the bus bar and the two cables. I guess if Art's Automotive did not replace them I am hoping that they could be cleaned.
  9. d4m8mvolt
    d4m8mvolt New Member
    Sioux City
    2001 Prius
    Replace the battery yourself. You can buy battery and new cable ends for an Optima battery online. Simple switch.
  10. Patrick Wong
    18,198
    6,464
    OP is talking about the traction battery, not 12V.
  11. AlexY
    AlexY Member
    160
    45
    UK
    This is what I meant saying "patina" usually can be cleaned with finger. IMHO cleaning is enough.
  12. Tashfeen Ekram
    29
    Fremont, ca
    2001 Prius
    I may have tried them had I known about them but I had already taken it to the dealer. In case anyone out is looking for a decent price from a dealer, Hayward Toyota replaced it for $2650 our the door. Though that Kensignton place looks good!
  13. Tashfeen Ekram
    29
    Fremont, ca
    2001 Prius
    The car seems to running well after the HV replacement.
    1. Do I need to replace the auxiliary battery? It is at least five years old. Autozone said it seems fine.
    2. Does driving short distances like 1.5 mile harm the HV battery?
  14. AlexY
    AlexY Member
    160
    45
    UK
    1. No. How often car is used?
    2. No (in normal condition). Problem can be with petrol engine being cold.
  15. Tashfeen Ekram
    29
    Fremont, ca
    2001 Prius
    The car is used daily. I just was not sure if the auxiliary battery can effect the HV system.
    Also, can replacing the HV battery make DTC P3191 go away? Per an earlier post, it had to possibly relate to the throttle?
  16. Patrick Wong
    18,198
    6,464
    DTC P3191 means that the engine does not start. A dirty throttle body is the likely cause.
