Terrible Mileage 2013 level 3..third prius
Discussion in 'Gen 3 Prius Fuel Economy' started by Eve, Mar 1, 2014.
  1. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    The weather plays a big part of my fuel rating on a 2011 with 55k miles.
    Warm weather 50's, 40 mile commute, high speed 55-65ish (cough, cough) I get 52mpg on Scan Guage II.
    Cold weather 30's, same commute I get 45mpg with lower/bottom grill blocking.
    I do warm up the car on cold, below 32 degree days.
    my2cents.
  2. Eve
    Eve Junior Member
    59
    S.Florida
    priusmpg.jpg priusmpg.jpg Bob Wilson I did what you said; reset for a short hop there and back...mpg looking more hopeful
    But my over all still around 40 ..so I guess I need to drive this car like a Prius:ROFLMAO: and not like I'm driving a Indy car..sigh
    retired4999 likes this.
  3. Eve
    Eve Junior Member
    59
    S.Florida
    rrg thanks for your 2 cents..BUT I live in South Florida:) I have to worry more about how high I have the air conditioner set...
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y) :D
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Bob, I've seen this chart before and always find it a bit confusing. There seem to be triangle and diamond data points with more than one meaning and those meanings aren't defined. Is the blue MPG what you would expect get or is it the PC cal? Perhaps that's the difference between HSI and actual. Its nice to see a little bump at 60 mph compared to the trend since that is a good highway speed. I suppose the car computer could be doing something different at that speed but the physics, drag etc, wouldn't be expected to have a sweet spot.
  6. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    I believe the blue curve is the indicated mileage, the green curve is calculated. Not sure about the other points.
    Rob
  7. Eve
    Eve Junior Member
    59
    S.Florida
    bp.jpg update.according to my dash read out my mileage is improving..
    BUT according to the gas pump it is confusing ..
    ANY thoughts.
    MOBIL that I used to trust ..now Im questioning.
    went to a different station across the street BP
  8. Eve
    Eve Junior Member
    59
    S.Florida
    bp.jpg sorry I don't know why the dash from BP is upside down
    but the mileage is 126.2 CONS 48.3 put in 2.78 of gas
    so that would be 45.39.
    why are there such a discrepancy in values??
  9. CaliforniaBear
    1,180
    289
    Northern California
    The actual mileage is usually 2 to 4 mpg lower than the HSI display.
  10. Eve
    Eve Junior Member
    59
    S.Florida
    California Bear - Ok thanks.
    also I want to say since they reset the computer and did the recall...this car drives totally different. Most of the sluggishness seems improved ..but still not like my 2010,and I am not so inclined to stomp on the gas off the line.
    Also I have put it in power mode in local drive and that seems to help.
    Does the computer really learn how you drive???or is that BS?
  11. bisco
    52,417
    bs.
    Eve likes this.
  12. Eve
    Eve Junior Member
    59
    S.Florida
  13. vskid3
    vskid3 Active Member
    773
    228
    Just a note, unless the engine air filter is extremely plugged, it doesn't make a difference.
    Remember that with small tanks, you're increasing the margin of error. If the pump stops a little earlier or later than usual on a 2 gallon fill, it'll make a lot bigger difference than on an 8 gallon fill.
  14. bwilson4web
    16,387
    • Dark blue line - connects the indicated MPG on the original tires on the first tank of gas from the dealer. There was no effort at any optimizations but the car as handed over at the dealer.
    • Light green line - this was put in later that year, within a few months, after we had enough tanks to figure out the calibration offset.
    • Other points - were spot checks from other credible Prius owners and subsequent tests by myself to see if the points were reproducible . . . quality spot checks.
    Now the car has 50,000 miles and on a second set of now, well worn, Sumitomo T4s at 51 psi. The transaxle oil was changed at 5K, 20K, and 50K miles.
    Using information gleamed from that chart, I made a thread-log, July 2013 over a three week period:
    Using GPS for the calibration constant, 100.4 miles (GPS) / 100.0 miles (indicated), gives a 100.4% calibration constant. So the true values were:
    • 1,004.8 miles
    • 92.2 MPG
    To the best of my knowledge, this was the first, 1,000 mile tank reported in PriusChat by a member who announced the goal, documented, and achieved it solo. Not the first with a 1,000 mile tank, our Japanese friends have a 1,000 mile club with a dozen or more members. Other USA, Prius, 1,000 mile tanks have been team efforts and often as one continuous effort. This solo, three week effort was terribly boring but mistakes were made:
    • 1.3 gallon, shorted fill-up - the indicated MPG shows only 10.9 gallons burned but I have gotten 12.2 gallons in the tank with a proper fill-up. In a hurry, I had inverted the nozzle when I filled up. I should have filled up, driven a mile around the block, and topped it off properly for this effort.
    • increase to 1.5-2.0 hour minimum drive segments - the key is to normalize the warm-up costs by driving more than 10x longer than the warm-up interval.
    • Costco E10 - Shell, Chevron, and Exxon have measured higher energy content in our area before the area was E10 captured. I have access to E0 gas but I have not done a proper energy content study to select the best fuel.
    • Tighter cruise control, 25 mph - I was often running 26-27 mph to provide margin on undulating routes.
    • Cheats (some could be cited) -
      • max sidewall pressure plus 10% in the tires
      • partial radiator block
      • moon-cap wheel covers
      • rear-wheel well covers
      • aggressive tire "mud guards;"
      • remove wipers in dry weather and use rain-X or equivalent
      • space heater to pre-warm windshield for dew control
      • strip interior of anything with weight (keep spare, jack, tire tool)
      • reduce driver weight
      • stow side mirrors in low-profile mode with after-body taper
      • headlight with cabin current dimmer
      • detail exterior with quality, low-drag polish
      • oversized front tires
      • taped, front seams
    • Bragging - vanity tag: "1000-MI", "IOOO-MI", "IK-MILE", "C92-MPG", "IOO-MPG"
  15. bwilson4web
    16,387
    The last photo in your previous post shows the car was turned upside down:
    BluetoothEdsel and Eve like this.
  16. Eve
    Eve Junior Member
    59
    S.Florida
    :p bob that always happens when I take pictures standing on my head:giggle:
  17. neez
    neez Member
    194
    37
    It's not BS on any other throttle by wire car i have or had. If i unplug my battery in my 2008 impreza and plug it back in it will constantly stall the engine coming to a stop for the first 20-30 miles until it learns the enginespeed vs fuelinjection mapping and adjusts the table accordingly. I'd say, for the first 50-100 miles it's still remapping and learning.
  18. bisco
    52,417
    both my '04, '08 and now pip, drove the exact same, and got the same mileage today and the day i sold them, as they did the day i drove them out of the showroom. perhaps i'm misunderstanding the question, "does the computer really learn how you drive?" i suppose i don't even know what that means.
  19. Eve
    Eve Junior Member
    59
    S.Florida
    I was referring back to my original conversation with the service manager.When I complained about the fuel consumption he said :" wait until the 5000 service as the car is still learning how you drive" :LOL:
  20. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I haven't seen an update from OP on the above suggestions, specifically:
    1. Size of tires vis-a-vis the 2010 (s)he had.
    2. Jacking up the car and making sure the rear wheels turn smoothly.
