Energy screen display
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by metalic160, Mar 18, 2014.
  1. metalic160
    metalic160 New Member
    So recently
    I have noticed that my Prius doesn't use the electric motor when ever I'm on the freeway it spends most of its time charging the battery and I've driven for like 5 miles and it nearly charges one little bar. I did notice though that I run on electricity more on the city
  2. Rich12
    Rich12 Member
    176
    29
    Check your 12V aux. battery. *shakes 8-ball* Outlook not so good...
  3. salguod
    salguod Member
    234
    37
    Columbus, OH
    This sounds normal to me. The Prius runs mostly on ICE power at highway speeds, the electric motors do more work in town.
  4. Tideland Prius
    16,589
    Sounds about right. You only need 10-20hp to maintain speed on the freeway on flat ground. I like the Ford's system where the width of the arrow changes depending on amperage sent back to (or used by) the battery. Toyota doesn't do that but the energy going to the battery is quite low.
