Traded in the PIP for a new 2014 Volt...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ny_rob, Mar 22, 2014.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Oh, you're mean, Rob. I won't say the range I'm getting with temps here in the 60's.
    But I can't resist reporting that I just drove the Volt the last 2 miles home, the ones I used to drive in stealth mode in the PiP. And I looked like this: :D
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I know how you feel Bill...
    I'm not going to keep a spreadsheet any longer like I did w/the PIP.. it's not necessary- I'm pretty much all EV now.
    Today the drive home was even better than yesterday....
    I drove 28mi and had 17EV mile left on the batt when I got home- giving me a range of 45 EV miles now!
    I only have to add 11 EV miles (costing about 80 cents) to get back to work tomorrow morning.
    Finalized the building of my L2 JuiceBox kit tonight- plugged it in and it worked perfectly. L2 240V charging at home for under $300!
    Chazz8 likes this.
  3. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    " Finalized the building of my L2 JuiceBox kit tonight- plugged it in and it worked perfectly. L2 240V charging at home for under $300! "
    so can a non-handy man put that together ? need an electrician ? price is nice !
    and getting 45 miles in your Volt - will you get your $ back ?
    I'm thinking it might be more helpful to me and my PiP given a much lower range.
    Those EPA numbers are wrong btw - I took pics at 10 minute intervals if anyone needs proof.
    Fully charged at home in 1:55 using a normal plug, fully charged at The 99 in 65 minutes
  4. ny_rob
    1,968
    813
    L.I.- NY
    Well, if you can solder- you can do it.
    IIRC there's 10 solder connections to be made, and some crimps. I soldered my crimps as well- but that's not required.
    I did all the soldering yesterday, and assembled the components last night.
    When I tested it on the Volt (which draws about 3300 watts vs the PIP which draws 2200 watts) nothing was even warm. FWIW- the JuiceBox is rated at 60A / 15kW Level 2 charging so my tiny 3.3kW draw is hardly a load compared to it's 15kW rating.
    Honestly, for the PIP- the EVSE Upgrade for $250 is the best of both worlds, I wouldn't build a JuiceBox for the PIP- but there are PIP owners who prefer a L2 charging station- so for them the JuiceBox at half the price and more than double the capacity of entry level commercial L2 stations is something to consider...
    Here's some photos (not of my build- but mine is identical) from a completed JuiceBox and one without the heavy input and output wires...
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I'm a DIY kind of guy so when I first heard of the juice box and other DIY kits I was chomping at bit to get one. Until someone pointed out that they are not UL rated/approved so if they ever caused a fire and were proven to be the cause, insurance would not cover the damages. Since I could get a clipper creek for only $195 more with a 3 year warranty, the gamble wasn't worth it to me personally.
    I'm not trying to spread any FUD here; just explaining my purchase decision.
  6. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Also, for those in NY there is a 50% tax rebate on the installation of an EVSE, which makes the commercial stuff quite inexpensive...
    fortytwok likes this.
  7. ny_rob
    1,968
    813
    L.I.- NY
    Probably not- but my unique situation (free L2 charging @ work) gives my 45mi out of my 56mi workday commute for free five days a week so I only need to pay for 55 EVmiles for the week. At 8 cents/mile the total for my weekly commute comes to $4.40.
    With the PIP's 10 mi EV range- I added about $30 in gas 2x per month plus $14 (70 cents/day for electricity x 20 days) for a total of $74/month vs $18 for the Volt's monthly commute. Again- if I didn't have access to free L2 charging at work which provides me with 80% of my daily at no cost- I calculated the the Volt and PIP would be almost identical costwise for my commute.
  8. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    nice thanks for all the info
    When I was house hunting awhile back and brought a contractor type with me I can't tell you how many times we'd see this or that and he'd say - whoa that's not legal ! or that's not up to code...
    So I think I'll pay if I can justify the expense but that won't work if MA doesn't have a tax break for those
    I'm at 90% EV, bought just $72 in gas last year so while its a neat gadget I'd gain maybe $7 here
    ny_rob likes this.
  9. ny_rob
    1,968
    813
    L.I.- NY
    I understand your concern!
    Here's how I decided to go with the JuiceBox...
    IIRC- Valery Miftakhov (ElectricMotorWerks & JuiceBox founder) stated on the Leaf forum he is in the process of getting the JuiceBox assembly UL approved. He's stated all the internal components are already UL approved, but not the completed device. As it is supplied today- the whole device is housed inside a very heavy sealed metal cast alloy enclosure. The high voltage high amp component- is a 80amp! rated commercial relay with very simple/robust 2 wire in, 2 wire out hookup going from the 120/120 mains to the 240cJ1772 cable... nothing experimental or using a component at or near it's design limit or for a purpose it wasn't designed for. All in all- it seems like a very robust design.
    I guess if I was going to house the JuiceBox inside my garage, hanging from a wall I'd think hard about it- but I'll be using my JuiceBox plugged in about 5 ft from the house on a cement slab outdoors- and most likely only on weekends.
    $72 in gas for the whole year? Awesome!
    Did you do the EVSE Upgrade for the PIP?
    That upgrade helped make my weekends in the PIP almost 100% EV for 18 months- which I couldn't do with the stock Toyota EVSE at 120v. The nice thing is the PIP draws very little even at 240 volts- 9.5amps IIRC, so you don't need a super heavy 60 amp circuit for it! I used 12-2 awg wire for my 240 circuit but derated it by using 15 amp breakers just to be safe. I'm still using the same circuit for the Volt (draws about 13.2amps) and still don't have a problem with the 15 amp breakers.
  10. inferno
    inferno Senior Member
    1,072
    405
    Whoa, looked at your car info and what a jump! Why from 2010 Prius to Volt and then yet another to an energi?! I can understand PiP to Volt, but less electric range to an energi? Is it the 5 seat idea?
  11. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    "$72 in gas for the whole year? Awesome!
    That upgrade helped make my weekends in the PIP almost 100% EV for 18 months- which I couldn't do with the stock Toyota EVSE at 120v. The nice thing is the PIP draws very little even at 240 volts- 9.5amps IIRC, so you don't need a super heavy 60 amp circuit for it! I used 12-2 awg wire for my 240 circuit but derated it by using 15 amp breakers just to be safe. I'm still using the same circuit for the Volt (draws about 13.2amps) and still don't have a problem with the 15 amp breakers."
    no upgrade and I'm embarrassed to say I'm not sure what that is ! but I'll check
    and yes - I filled up twice in 2013 with about 8 gallons each time and I'm down about 5 gallons right now.
    Just like 2013 I think my next fill-up may be forced due to the 6 mo old gas rule.
    I'm not special - just coach at the high school in my town and drive my wife to the train and back so all my daily drives are under 13 miles.
    I'm starting to figure out that I can't justify the cost of any faster charging toys since I'm already at 90% EV
  12. fotomoto
    5,639
    3,815
    So. Texas
    Short version: yes, room.
    Long version: The very first hybrid I ever drove was a pre-production Volt during a nationwide test drive campaign. I was in the "ready to buy today" mode but it wouldn't be available for nearly a year and the early adopter pricing frenzy would last even longer so I got the Prius; however, the EV bug had bitten hard. Once the prices came down during the 2012 model year, I got my Volt, driving it with a 90% EV ratio on L1 and all was well with the world.
    Then our family world changed and I became Mr. Mom saddled with all the kid hauling duties. After much deliberation, I reluctantly traded it in for a CMax hybrid to get more back seat room and a level hatch opening for the kids band instruments and my work gear. Thanks to all that I learned here on PC, I could easily get 50+mpg in the CMax. We liked the car so much that I gave it to the wife and got a CMax Energi too. Now I'm back to EV driving and don't plan on leaving it again! BTW, even with the smaller battery/range, I'm still over 90+ % EV due to diligent L2 charging even though I typically drive 40-60miles per day. (y)
  13. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    I can't get over how ugly the CMax is. I do kind of like the Sync system, though.
  14. inferno
    1,072
    405
    But your fuelly mpg...doesn't reflect the 90% EV...or did you stop keeping track?
  15. fotomoto
    5,639
    3,815
    So. Texas
    Fuelly was for the hybrid which my wife now drives. I haven't registered my Energi there as the last time I checked they couldn't handle plug-in's correctly. FWIW, it's at 112.5 MPGe or 402 MPG with nearly 6k miles on the clock.
    Apologies for the threadjack. We now return you to regular programming.
    Zythryn likes this.
  16. ny_rob
    1,968
    813
    L.I.- NY
    MPG becomes irrelevant with plugins with bigger batteries...
    I've got 900 miles on my Volt now- I've burned 0.6 gal of gas (I just wanted to verify the ICE actually worked!) so that works out to something like 1,500 mpg!
  17. inferno
    1,072
    405
    Yes you're right mpg becomes irrelevant. MPGe I don't think is accurate either. I want to see MPG for gas/hybrid mode, and then a separate MPGE (MPG Electric) to show Miles per KW. That's more meaningful especially where the industry is headed anyway. For Hydrogen would it be MPGH (Miles per Gallon of Hydrogen?) lol... then maybe MPGe (lower case) to help determine the equivalence of each car.,
  18. El Dobro
    El Dobro A Member
    7,088
    3,270
    I guess the gov't will come up with hGallons. :D
  19. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I can understand why they want to make a number equivalent to MPG, but MPGe is so incredibly stupid. I wish they would just publish miles per kWh, as that's really the best comparison between EVs, and makes the most sense as you care about how far you can travel per kWh as you would per gallon in an ICE or hybrid.
  20. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    I disagree. Miles/kWh will minimize the differences for the general public.
    For EVs Wh/mile should be used.
    As for MPGe, it isn't great, but I do feel it is useful when comparing vehicles that use different energy carriers.
    Cents/mile, or dollars/100 miles is also good, but that can vary widely depending upon region and utility.
