Horn honking when locking and unlocking doors
Discussion in 'Gen 3 Prius Audio and Electronics' started by snarfo67, Apr 10, 2014.
  1. snarfo67
    snarfo67 Junior Member
    Muscatine, Iowa
    2020 Prius Prime
    Apologies if this has been answered elsewhere already...
    I have a 2010 Prius IV and set the doors to all unlock when I touched the driver's door handle. Annoyingly, now when I touch the raised spot on the handle (either driver or passenger side) to lock all the doors the car does the beep but also briefly toots the horn. The horn also toots when I touch the handle to unlock.
    My old 2005 Prius VI just did the beeping (which my neighbors and I can live with) but the addition of a honking horn, however brief, is pretty annoying. I can't seem to find a place to disable this unwanted feature... little help?
  2. JC91006
    JC91006 Senior Member
    16,800
    8,589
    The horn sound just started after you set the doors to unlock all doors? Didn't have a horn sound before?
  3. snarfo67
    Muscatine, Iowa
    2020 Prius Prime
    I'm not sure--- I did the 2-button keyfob press on the lot before I even sat in it since I knew beforehand that it defaulted to opening just the driver's door on touching the handle. I thought I had done my research and due diligence but assumed I missed something that was making the horn honk along with the familiar beep.
  4. JC91006
    16,800
    8,589
    so if you go back to unlocking just the driver's door, would the beep go away? I'm thinking you have a secondary alarm added that's making the horn honk.
  5. Ivan Garcia
    Ivan Garcia Junior Member
    El Paso
    can you please tell me how to set all doors to unlock with driver's handle? Mine only unlocks the driver door. Thank you!!!
  6. JC91006
    16,800
    8,589
    Hold the lock and unlock button at the same time on your remote for 5 seconds. It should change from one to the other.
    Phil Wheeler likes this.
  7. snarfo67
    Muscatine, Iowa
    2020 Prius Prime
    I tried switching back and forth between unlock modes but either way the horn toots briefly. So I take it this is not normal behavior... when I go in for my next oil change I'll ask them to look into it.
    I had intended to keep my 2005 Prius until the 4th-gen was released but a semi ran me off the highway and reliable old silver was totaled at 153,000 miles. I only got the 2010 as an interim car and found the horn thing to be a bit obnoxious. Other than that, the lack of interior storage space (compared to 2nd-Gen), and the absence of a display for the average mpg on a tank of gas, so far it's actually nicer than I thought it would be.
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    sfv41901 likes this.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  10. RRxing
    RRxing Senior Member
    2,552
    1,825
    NEPA
    Trip A and Trip B each have MPG (labeled as CONS:, for consumption). Just reset before each fill up.
  11. snarfo67
    Muscatine, Iowa
    2020 Prius Prime
    Thanks for the alarm ideas--- there is a little mystery gizmo under the dash just inside the driver's-side door with a blue light on the front. I reached under it and it does have a button to depress (which I did numerous times in varying combinations but there was no change in horn behavior) so at some point this week I plan to take it to my car guy and see if it's one he's familiar with.
    RRxing: Yeah, saw that. I just liked the convenience of having the display always there and having it automatically reset when I added gas to the tank. Your point is well-taken, though... maybe I'll get into the manual reset habit eventually.
    Thanks again for the suggestions!
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That is definitely part of the dealer installed alarm which they charged u ~$600 for when u bought it.
    VS980 4G ?
  13. snarfo67
    Muscatine, Iowa
    2020 Prius Prime
    Nah, no specific charge for it. I got the car used after my 2005 was totaled. I had intended to skip the 3rd-gen Prius and get a 4th-gen as my next car but a careless semi driver decided otherwise for me :)
    If it's a common brand/model alarm though, I am hopeful that I can get that maddening honking disabled ASAP.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Even better u didn't pay for it.
    I just sent u a PM
    VS980 4G ?
  15. snarfo67
    Muscatine, Iowa
    2020 Prius Prime
    And the offending device removed and all is well in the world! Thanks, all.
    KSElric likes this.
  16. Phil Wheeler
    Phil Wheeler Junior Member
    78
    Thanks! I had the same question today and the manuals were useless. Searched here and got the answer from you. And it seems to have worked :)
    Phil
