Surprise in cabin air filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chrisasst, Apr 14, 2014.
  1. chrisasst
    chrisasst Junior Member
    29
    Cortland, New York
    So wife reported that there was a very bad odor in the car.
    Pulled the cabin air filter and found the following
    iPhone ?
  2. JC91006
    JC91006 Senior Member
    16,802
    8,591
    now look for the mom and pop.
  3. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    Wth? How did they get in there?
  4. bisco
    52,219
    i love surprises.:)
  5. JC91006
    16,802
    8,591
    this must be a dealership infomercial to have your cabin filter changed by experts. no need for surprises.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I have seen worse. Best advice is to get a good activated charcoal filter and then clean it out once a month. Will work wonders and keep your car fresh and clean. Did that on our Gen II and it smelled great for the three years I drove it. Never had to replace the filter. Just kept it clean, tapping out the dust, leaves, pollen, etc.
    Lucky, no mice or rats here. Too many cats in our neighborhood.
    If you have a major problem with mice infestations, read up on how to block off the entrances they find. Info posted here on PC that talks about this issue and where the openings are.
    Best of luck to you,
    Ron (dorunron)
  7. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    I recommend a screen over the end of the engine air intake.
  8. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Not a bad idea but that is NOT where the cabin air comes from.
  9. CTitanic
    CTitanic Member
    153
    22
    South Florida, FL, US
    Wow, I'm impressed!
  10. kenmce
    1,549
    522
    NY
    Ack, he's right! Never mind... (looks sheepish)
  11. Patrick Wong
    18,210
    6,511
    Wouldn't hurt to remove the engine air filter and look inside the air filter housing to see if the mice got there, as well.
  12. cyberpriusII
    1,157
    1,822
    Mars Hotel
    That is Mom and Pop (probably). No big deal.....come to my place and I will show you "surprises" in the cabin filter.
    As Patrick said, you had better check the engine air filter....if they go in the cabin filter, half the time, they also have been storing supplies in the engine air filter box....
    dorunron likes this.
  13. cyberpriusII
    1,157
    1,822
    Mars Hotel
    Actually, I was being a bit flippant when I said that half the time mice will make the engine filter box a storage pantry. Maybe about 15 percent of the time....
    Wonder why those mice were dead though.....In the old days they got chewed up by the fan, but the Cabin Filter usually keeps them out of the fan....and in this case, there is no hole chewed in the filter...
    Strange. In my experience, from now through June is the worst time for the rodents. So, if you are getting some now, odds are, you will get some later.
    Mine, earlier this year:
  14. chrisasst
    29
    Cortland, New York
    There were two holes in the filter.
    iPhone ?
  15. cyberpriusII
    1,157
    1,822
    Mars Hotel
    Aye, can't see the holes in your photo....check my photo that I just edited into my post above yours to see how they treated my engine filter area this winter.
  16. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Still a good idea. When I had mice dragging things into the cabin filter, they were also filling the engine air cleaner box. :)
  17. chrisasst
    29
    Cortland, New York
    Yep they in the air filter also.
    iPhone ?
  18. cyberpriusII
    1,157
    1,822
    Mars Hotel
    Yep, at least you found it before it caused any issues. Patrick Wong gave me a tip of disconnecting the hose at the box and using a shop vac to get any debris that still might be "in-line."
    Takes a few minutes to disconnect and connect, but at least I felt confident that I got rid of anything in the system.
    Cleaning out Engine Air Intake | PriusChat
    Screening that engine air intake is a little fussy, but if I can do it...
    And, yes, once again. BIG THANKS TO PATRICK WONG!!:)
  19. dorunron
    3,318
    1,105
    Houston, TX
    I am proud of you Kris. Fixed something like you did, and now you are sharing with others. Prius Chat is going to make you a level 2 Prius technician before you know it. ;-)
  20. cyberpriusII
    1,157
    1,822
    Mars Hotel
    I have simple wants. All I want is enough Prius Trophy points to pass that Poodle of the Prius Rufaro.
    And, the points don't matter... | PriusChat
