Whats Wrong with my prius
Discussion in 'Gen 2 Prius Technical Discussion' started by ruidboi, May 1, 2014.
  1. ruidboi
    ruidboi Junior Member
    45
    Nassau, New Providence
    I was driving my 2005 Toyota Prius and all of a sudden some lights came on the dash. The orange check engine light, The big red Triangle with an exclamation mark on it, the orange VSC symbol, and the orange exclamation mark all at once. I also heard the fans in the back seat kicked in which I never heard before. It felt as though the car didn't have much acceleration. I took it to the dealer and they had it a whole week trying to figure out what it was wrong. They said they got the P3000 INF 123 code from the car which they said the HV control ECM for $2000. Needless to say I don't want to pay that! I found used ECM on ebay for $85 and I bought a scangauge 2 . I pulled 2 different codes out with the scan gauge 2 P0A80 and P3021.
    Do you think the dealer diagnosis is right? What does the codes I read out mean?
  2. LucasElectric
    LucasElectric New Member
    24
    East Lansing, MI
    yellow taxi and ruidboi like this.
  3. LucasElectric
    24
    East Lansing, MI
    This happened to me and I'm in the midst of fixing mine right now. Including the tools and everything needed to rebuild the battery it's going to/has cost me around $250
    dorunron likes this.
  4. flxcon
    flxcon Junior Member
    los angeles
    Your hv battery has block #11 going bad. Probably need one or two modules. If you are I
  5. flxcon
    los angeles
    If you live in los Angeles, ca. Call me 3233502278
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,392
    3,261
    Madison, Wisconsin
    I see you are located in the Bahamas.
    As others noted, you have some weak cells in block 11.
    If you plan to do the work yourself, let me know. I can send parts and talk you through a few things. Or if you have a reputable independent shop, I could help them as well.
    It's unlikely that you need an ecm. But as you noted you can find a used one for much less than new.
    We can talk via email, or if you have Skype we can give that a go. Drop me a line.
    ruidboi likes this.
  7. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    While the Scangauge is a good unit for monitoring while driving, if you want to completely troubleshoot the battery system, you would do well to get the mini VCI (eBay and elsewhere). This gives you as much info as possible. Your dealer appears to be less knowledgeable than the many helpers here on PC. These reports of P0A80 are becoming almost a daily event now, so you are in good company.
  8. bisco
    51,759
    it is amazing how many batteries we've seen the last few months.
  9. ericbecky
    4,392
    3,261
    Madison, Wisconsin
    This is why I changed my shop to full time last year. Prior to this there wasn't enough out-of-warranty work.
  10. JC91006
    JC91006 Senior Member
    16,748
    8,554
    Uart mentioned in another thread today about the failure rates of HV batteries being in the 2% range, surveyed by I forgot whom. How accurate do you think this 2% replacement rate is? What has been your experience?
  11. ruidboi
    45
    This is excellent info! It seems as though my cheapest option is to replace a individual battery module. What is difficulty level for replacing an individual module? And is there a danger of me causing harm to myself or to the battery by doing this? Im no mechanic but Im very tech savvy and can follow moderately complex instructions.
    GT-I9500 ?
  12. JC91006
    16,748
    8,554
    By you asking this question, you might want to get it done by someone else and you watch how it's done. Maybe after that, you can try it on your own if another cell fails.
    YES YOU CAN KILL YOURSELF DOING THIS!
  13. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I can guaranty that if had you have paid them the $2000 that it wouldn't have fixed the problem. I can also guaranty that you would never have seen one cent of that $2000 refunded. Instead the dealer would have steadfastly maintained that there *really* was problem with that ECU and that now there is another *different* problem with the HV battery - and that will be another $4000 please.
    Lucky for you that you did some research yourself on this before letting the dealer cut lose with your wallet.
    ruidboi and CatsAreGods like this.
  14. nh7o
    1,686
    340
    Hawaii
    Battery balancing in its present state of knowledge is something you could do with small investment, but it is time consuming. The car would be out of service for a while. Start with some of the threads on how to proceed:
    Gen II Prius Individual Battery Module Replacement | PriusChat
    Prius Battery rebalance thread | PriusChat
    HV Battery Rebuild - Cell Capacity and Balancing Help | PriusChat
    There are other threads which can be searched out as well. Don't be put off by the voltages, people work with this equipment daily without problem. This is helpful:
    Prius battery exploration
    ruidboi likes this.
  15. ruidboi
    45
    Lol thats the first thing that popped into my head when everyone said it was the battery. They would have made me pay for that. Now i just have to read links you guys provided to see if I can change a individual cell by myself. I also have to see what kind if equitment will I be needing to perform such a task.
    I really need my prius back on the road because I am borrowing sombodys 2009 ford sportstrac which gets 12 MPG. Compared to my prius's 50 MPG
    GT-I9500 ?
  16. VKK05Prius
    VKK05Prius New Member
    I am having the same problems with my 2005 Gen II Prius. They originally told me it was the ECM, so I had them replace it (Cost $2000), then it didn't fix the issue, they said it was the 12V battery, replaced it- Nope, still didn't fix the issue. Today they say it's the Hybrid Battery...UGH. I will not buy another Toyota. I owned a Camry (which was a perfect car), then a Lexus which was in the shop and I spent more on it for fixes than what I paid, now I'm driving the Prius, and I love it, but a new Hybrid Battery is going to be $3,100! Ugh. Time to say goodbye.
  17. JC91006
    16,748
    8,554
    After all that money spent, will it be easy to let go?
  18. CatsAreGods
    CatsAreGods Junior Member
    46
    If someone told me that a $2000 part would fix a problem and it didn't, I'd be telling them to take it right back out or face a lawsuit. Have you contacted Toyota corporate about this, or are you just accepting it as "bad luck"? They are a dealership, and should know better and stand behind their work.
    Nexus 4 ?
    uart and JC91006 like this.
  19. JC91006
    16,748
    8,554
    +1 I would hold the dealership responsible as that is their diagnosis of the problem.
  20. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Sounds like a real crap shoot. :(
    The reality is that ECU's are generally very reliable and rarely fail. Unfortunately for us however, there's a darn good profit margin for dealer in replacing them. Sometimes I even wonder if some of these ECU failure misdiagnoses are no accident. :mad:
