Another DTC question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by emanboulay, Feb 7, 2014.
  1. Patrick Wong
    18,210
    6,515
    Congrats on completing the job. Did you decide to replace the resistor or not? If not do you notice any difference in noise level or braking performance?
    I also noticed that your earlier post mentioned the part would cost $150. Were there any changes to that price?
  2. emanboulay
    emanboulay Junior Member
    33
    Hi Patrick,
    Used part was $150 CAD and works perfectly. Did not replace the resistor and there is no difference in noise level.
    Wanted to add that I partly dismantled the thing and took some pictures...
    As you can see the part is not in good shape and is hard to rotate with a metal to metal noise. If someone has any info on what can cause this and what this part does feel free to add your comments! At first sight, I would say a bad seal.
  3. emanboulay
    33
    So no comments on what that specific part does and why it is in bad shape? Just curious. Take care!
