10mpg increase
Discussion in 'Gen 2 Prius Fuel Economy' started by WNY-HYBRID, May 18, 2014.
  1. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I am assuming that nitrogen filled tires hold their psi longer because the nitrogen is a larger gas particle. This makes me think that the smaller gas particles of oxygen will leak out faster because it is easier for them to escape the tire. so it would be logical that you would have a larger concentration of nitrogen in the tire over time due to the different leakage rate, and at some point the nitrogen should be highly concentrated. The elevation should not stop this affect, I guess if the air at higher elevation has a smaller % oxygen then that would speed up the process.
    I think the benifit of filling tires with nitrogen is make believe. air is mostly nitrogen and over time you tire is going to be have a higher concentration anyway. Do what you like but I wont have a hard time sleeping because I just use air to fill my tires. Like I said before all my tires seem to fail because of what happend on exterior of the tire. :)
  2. fuzzy1
    10,603
    Yes, nitrogen will tend to become more concentrated, if the diffusion rates mentioned in previous threads are correct. But those figures are not hugely different, so the rate of concentration should not be high. And the terminal point with infinite time should be well short of 99%.
    Elevation factors in because it sets the partial pressure outside the tire, thus limiting how low the inside partial pressure can fall.
    I'm also challenging KhaPhoRa's suggestion that, even with a drastic difference in diffusion rates, 99% could be achieved in just two top-offs. Not a chance.
  3. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Wow that took me back.. Partial pressures, Dalton's law.. You are right. So remind me, would that also mean that even using pure nitrogen eventually oxygen would diffuse in? Either way the result would be the same?
  4. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Relax, son. It was just a for-fun napkin calculation. You are correct about partial pressures.
  5. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Not new, 3rd hybrid.
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It would be highly unusual to obtain +10 MPG (or about 25% improvement) from the states pressure increase alone. Fuzzy1 is absolutely right to be looking for other factors.
    My hunch is that the dealer disconnected the 12V battery during the service, which often alters the reported MPG for a some times afterwards. If you search the forms here there are literally dozens of posts complaining of large drops in MPG immediately after a dealer service. In most of these cases the tires and the oil check out fine and no other problem can be seen, but mysteriously the MPG in significantly reduced. Then in a week to a few weeks the problem magically sorts itself out as the ECU re-establish their historical data.
  7. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    They didn't disconnect anything. I asked. The car was at the dealer 3 weeks ago and the only service performed was an alignment. 10lbs low on each tire is a lot, not surprised There is significant improvement
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I've never seen anyone else report such a large increase in fuel economy from tire pressure increase of that magnitude (30 PSI to 40 PSI).
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Easy enough to test - just drop the pressure back to 30psi and run the car that way for another tank.
  10. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I'll do that and report back !!
    ftl likes this.
  11. Okinawa
    Okinawa Senior Member
    1,333
    320
    I agree with you. I live in a suburb of Chicago. I have 140 miles on my car since the last fill. I am getting 57 mpg. No highway miles. I have no explanation for it. It normally does not do this good. Must be the weather.
    fuzzy1 likes this.
  12. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    As stated, The alignment was done weeks ago, before I bought the car. I always got lower mileage, since I bought it. Never over 45.
    I always pulse and glide when possible.
    Update- So I had to drive from buffalo to Syracuse and back today. That's 200 miles each way. Took tires down to 29psi. ( where they were) drove there. 43.25 average MPG.
    Put 42 psi in each tire, drove home. 49.90 mpg average. Took I-90- mostly flat both ways, drove the same speed, 67 mph.
    So... Any more insight on this?
    ftl and CatsAreGods like this.
  13. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Re: N2 - Yes if tires filled with air (78% N2), over the years your %N2 will climb possibly to about 90% N2. So that's part of the reason why its hard to make a stronger recommendation for N2 in car tires. I like Costco approach of putting N2 in new car tires....but I'd just refill with regular air after that.
    Re: Effect of Tire Pressure- I have previously shown this chart (below), based on some equations, but I did not have actual Prius MPG data so it's the shape of the plot that's important. As you go to too low pressures, the MPG decrease worsens. FuelEconomy.gov say impacts is: "You can improve your gas mileage by up to 3.3% by keeping your tires inflated to the proper pressure. Under-inflated tires can lower gas mileage by 0.3% for every 1 psi drop in pressure of all four tires." But other sources say the effect much larger than EPA says it is...so I do not know.
    I've noticed with my Gen2 sometimes I am getting 50 MPG on the display, then stop to get gas... then it won't go over 45 MPG on the display. I tend to feel real MPG is best calc'ed via hand at fill-up. But then we have (in Gen2) that flexible guess tank so we have a hard time with these sorts of measurements.
    Here's some MPG data from Edmunds:
    uart and WNY-HYBRID like this.
  14. bisco
    52,502
    the only reason i mention it is, i started out running recommended, then went to 42/40 and never perceived much improvement.
  15. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    If you've seen your posts removed or edited, that was me. The bickering was distracting.
    Personally, I am convinced enough of the correlation between tire pressure and mileage that I run at 52f/50r. I've been there since about 2007. I saw immediate gains when I started over-inflating. Went from 35 to 40 to 45 and then 50. Above that, the gains were negligible. When I struggle with my mileage, it's the first thing I check and usually the culprit.
    Someone said that they have never seen people report large gains based on tire pressure. Similar reports have been made around here for years.
    Perhaps it's time we put up or shut up: Priuschat Tire Pressure / Mileage Experiment | PriusChat
    WNY-HYBRID likes this.
  16. bisco
    52,502
    mff-mff-mff:censored:
  17. northcoaster
    northcoaster Junior Member
    32
    northcoast
    wait wait AFTER you paid off the car THEN they sent you a title w/them as the leinholder? So which title is most current? Would you have to get them to sign off if you sell the car?
  18. KhaPhoRa
    KhaPhoRa Member
    168
    37
    After I paid off the car they sent me a title that listed them as the lien holder, they of course signed the line releasing the lien as the loan was paid off. I used that one when I moved to texas and did a title transfer..
  19. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    That's really weird. Nobody's contacted me about it, and I'm not going to say anything.. It's fun to have it "paid off" already!
  20. bisco
    52,502
    wow! 4.5 mpg increase over a 30 psi change! amazing!
