Whats Wrong with my prius
Discussion in 'Gen 2 Prius Technical Discussion' started by ruidboi, May 1, 2014.
  1. kurt oskar
    kurt oskar New Member
    Hello Eric, I have to admit, I am beaten, it seemes nonchellant, but this was the issue, it is a hard way to learn it, my car stood still over 4 weeks, because of that. Now it is running,
    I still have some issues. But I have the miniVCI, so I hope to get rid of it all now.
    It might be too cheep, but thanks for the advice.
    Greetings
  2. kurt oskar
    we do say here the trees do not grow into the sky. My vsc blinks me 51.
    Now I'll connect my (old)laptop an start my miniVCI campagne.
  3. kurt oskar
    MTL_hihy: As Eric wrote, mount it correct, I ran out to see if that could bee the issue, and realiced it to be trouth. What you have attached tells the same story, so this is too a great input for me, thanks.
  4. kurt oskar
    p3000 battery control system
    c1310 HV system malfunction
    b1421 solar sensor circuit (passenger side)
  5. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    P3000 Battery Control System Malfunction
    B1421 Solar Sensor Circuit (Passenger Side) http://tinyurl.com/o4g2rds
    C1310 Malfunction in HV system http://tinyurl.com/op9wkjh
    P0A85 Hybrid Battery Pack Cooling Fan 1 http://tinyurl.com/kawwsae
    B2796 No Communication in Immobilizer System http://tinyurl.com/kpbdv77
    B1260 Transmission Control ECU Communications Failure http://tinyurl.com/lva4lm5
    Hopefully these help you beging tracking down the issues, I'd start with the fan as Patrick suggested (he gave you a good diagnostic tree above). You sould also be removing/disconnecting any non factory wiring just so you can rule that out as an issue while troubleshooting.
    #45 MTL_hihy, May 28, 2014
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,423
    3,296
    Madison, Wisconsin
    Ignore the solar circuit issue for now. It will not harm how the car functions.
    Unhook the 12v battery for 30 seconds. Hook it back up and rescan it.
    XT1049 ?
  7. mprius6x6
    mprius6x6 Junior Member
    Trebnje Slovenia
    I also had DTC on my Prius
    In the end, the problem was on Battery Blower Motor Controller.
  8. James4621
    James4621 New Member
    Minneapolis
    I know this is very old thread but can someone please point out where the "Battery Blower Motor Controller" is? 2008 Prius. I know where the HV fan is though and I cleaned it.
    Thanks
  9. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Let me now quote the resident guru Patrick 'Prius' Wong :
    "Usually the blower motor controller will be located downstream from the fan in the vent ducting. Or as previously suggested, try to trace the wiring from the fan motor to the motor controller."
    Hope that helps! ;)
    James4621 likes this.
  10. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Prius Wong
    SM-N900P ?
