h&r springs install / tools
Discussion in 'Gen 3 Prius Accessories and Modifications' started by StarCaller, May 29, 2014.
  1. StarCaller
    StarCaller Senior Member
    1,280
    732
    Cedar Crest, NM, USA
    I'm pretty much ready to order h&r springs from tirerack, I just don't want to be surprised of not having the right tools once I start taking everything apart.
    so the big nut, do I need a #22 or a #23 socket? (some say 22, others say 23...)
    for compressing the springs, was neone able to make use of the spring compressor from harbor freight? (someone mentioned that the tool's too big for the prius springs)
    BION
    StarCaller
  2. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
    I went with this to cover all bases
    TEKTON 4885 1/2" Drive Deep Impact Socket Set, 11-32mm, Metric, Cr-V, 14 Sockets:Amazon:Home Improvement
    I also rented the free spring compressor from autozone, worked fine
    FWIW: I hate my H&R springs. While the ride height is perfect... the ride sucks. I've had my fair share of lowered cars on various springs, this is my first H&R kit. It feels like the spring rates between front and rear are different.
    WHEN I feel up to it, I'll be swapping them for eibach
  3. StarCaller
    1,280
    732
    meaning?
    now I'm not so sure nemore about the h&r's....
    what makes you think the eibachs are better?
  4. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
    When going over any dip in the road at speed, the front feels like a low car with weak springs while the back feels tight and predictable. The front feels lousy to me, almost like I cut the factory springs.
    I bought the H&Rs here from another member. They were brand new and never installed. They weren't my first choice but it was a good deal. In retrospect I should have gone with new Eibachs for a few dollars more.
    Many others compliment the Eibach ride quality but dont like ride height. After 5k mi on the HR, I'll deal with less than optimal ride height for a high quality ride feel.
  5. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I thought Eibach owned H&R?
  6. Chris S
    Chris S Active Member
    323
    111
    Gilbert, AZ
  7. StarCaller
    1,280
    732
    what was the problem?
    BION
    StarCaller
  8. Chris S
    323
    111
    Gilbert, AZ
    No matter how much I compressed, I could never decrease the tension on the top plate and I was too nervous about taking the strut apart and shooting it across my garage. I couldn't believe the spring would compress in the middle inside the tool but not outside of it. I combined blame between a cheap tool and my fear.
    iPhone ?
