wiring tru the bulkhead easily
Discussion in 'Gen 3 Prius Accessories and Modifications' started by edwardob, Jun 2, 2014.
  1. edwardob
    edwardob Member
    227
    33
    ireland
    i notice when folks are adding accesories etc that need to bring wire into cabin area......use all kind of contorsions and twists and turns all over the place,......when in fact its quite simple
    check picture below
    all i did was force coat hanger wire tru rubber[quite safe]...once it went tru i tape my accesorry wire to coat hanger and pulled tru further from inside cabin[torch is helpful]....and voila undo the tape ...now my wire is inside
    and there is room for many more.......the rubber is "self healing" and will tighten round the wire nicely...sealing it
    jzchen likes this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Which grommet is this?
    If it is the one that comes through near the brake pedal, those of us who know about the oem foglight installation know about it.
    Your picture doesn't look like it though.
    P.S. Is that a horn? What's it doing all the way back there, by the firewall/strut tower?
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    I prefer "insulation hangers." They are stiffer and less likely to bend like coat hangers. I make a very small loop on the end and double over the end of the wire that I'm pulling.
    I've used them as locators to drill through wood and sheetrock structures in house walls to locate places to drill larger holes for running in-wall wiring, too.
  4. edwardob
    edwardob Member
    227
    33
    ireland
    right hand drive car. .. i brought wire through passenger side. ... so that is passenger side. .. maybe left hand drive is different. ..
    hardly much different?
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    Still, what grommet/hose is that? The AC evaporator? The heater?
  6. edwardob
    edwardob Member
    227
    33
    ireland
    bunch of wiresfrom engine area going into cabin. ...not pipe or ac stuff.....
  7. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I believe it is the main wiring harness.
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I'm going to be running one wire through soon. There is a "nipple" that I'm going to try to deal with. Fog light instructions say to cut it off. I don't seem to see it in the picture. It seems like a very difficult reach until I read your coat hanger idea. Thank you so much!
    SCH-R530M ?
  9. edwardob
    edwardob Member
    227
    33
    ireland
  10. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Confused me for a minute, then I realized "torch" = flashlight on this side of the pond.:D
  11. edwardob
    edwardob Member
    227
    33
    ireland
    had few moment's like that myself...ie. ..trunk/boot...Google translate doesn't work for these!
