  1. David2sav
    David2sav david2sav
    107
    171
    San Jose, California
    Yeah they are static, they don't adjust with the wheel movement like my friends '14 Escalade :unsure: But at least I get way better MPG, haha.
  2. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    Yep, screws right on. Same threads and everything.
  3. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    Thanks. Just ordered one in blue.
  4. Warp4
    Warp4 New Member
    Richmond, Va USA
    Today I covered the front and rear toyota emblem so that they are now a black background with the chrome toyota symbol.
    I ordered the carbon fiber look film online and simply covered the blue/black original plate behind the chrome. It ended up being VERY easy and no disassembly of the car was necessary. I think getting the blue off the car was a good thing.
  5. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I installed my TRD rear sway bar today.
    20140605_130824.jpg 20140605_130846.jpg 20140605_133658.jpg 20140605_133320.jpg
    A couple of notes:
    1) The instructions suggest using a bungie strap to hold the bar up during install. Great idea.
    2) The instructions suggest removing the lower shock mount bolts to give you better access for inserting and tightening the endlinks -- I found this wasn't necessary because I was able to gain access with my 15mm end wrench from above.
    UPDATE: I wasn't extremely optimistic that this sway bar would make a huge difference. Now I've had a few days to try this out. There were a few turns on my morning commute where I could easily scare myself with the roll. This TRD sway bar has eliminated that. No more scary rolls!
    #4265 Dylan Doxey, Jun 5, 2014
  6. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    You will definitely notice an improvement on your handling. Its fun and scary at the same time, but it feels so right :rolleyes:
  7. Dylan Doxey
    1,389
    3,459
    92
    There is one particular freeway overpass on my daily commute that calls for this. This might be first time I've looked forward to going to work in the morning for a long time.
    KeepitSimple and RightOnTime like this.
  8. David2sav
    David2sav david2sav
    107
    171
    Is there a big difference between cusco vs trd rear sway bar? Debating on which to get...
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm not sure if either 1 is better than the other. I do know the Cusco gives u more ground clearance.
    VS980 4G ?
    David2sav likes this.
  10. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    Do you have the emblem in the front that is covered with the clear plastic cover... I have a 2012 prius base hatch five edition and not sure if that's why. But its like the emblem is closed in this plastic closure. How did you get the front off? Its screwed on the behind right? I see you from Richmond and im from colonial heights
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Do you have the advanced technology package? That Prius uses a different front badge & it cannot be pulled apart & plastic-dipped.
    iPad ?
  12. Accordlayingkit
    1,618
    1,748
    377
    Yup...sucks too I kinda scratched a little around it too trying to pop it out then realizing its screwed on from the back side! ill get that fixed though but do you or anyone else know anymore options with this emblem? I hate it after plasti dipping all the other emblems on the car!
  13. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    A fellow member successfully plastidipped over it without interfering with radar operation. You'll just be covering it with no design.
  14. Accordlayingkit
    1,618
    1,748
    377
    is the radar operations inside that emblem or something?
    Dylan Doxey likes this.
  15. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yep, the metallic coating on standard emblem would interfer with it. The flat radar-compatible emblem retails for $900!
  16. Tommy_Prius
    Tommy_Prius Junior Member
    24
    Installed TRD lowering Springs, TRD Sway Bar, SSR GTV02 wheels, JDM window visors, Valenti 3rd brake light (smoked), Rear Bumper Applique, Dash Cam and quick car wash.
    Grren4ever, fatdawg, WilDavis and 5 others like this.
  17. Tweaksalot
    Tweaksalot Member
    Huntington Beach
    2019 Prius Prime
    wow looks great! your prius definitely got some love today!
    Tommy_Prius likes this.
  18. Prius-Paul
    Prius-Paul New Member
    Love the dash cam !!! Two thumbs up !!!
    Chris S and Tommy_Prius like this.
  19. Prius-Paul
    Wife's car. One week old
    Washed , vac
    Plasti-dipped emblems
    30% tint all around. Need to return to tint shop " tint front windshield complete & Clear bra "
    sfv41901 likes this.
  20. Accordlayingkit
    1,618
    1,748
    377
    Tint the front windshield?? your asking for trouble haha.. I from Colonial Heights and I'm sure I'll get pulled pretty soon as I just did 20% all the way around! Give us some details on the dash cam. How it powers up and where u got it from etc... 20140604_170124.jpg
