Another Strut Tower Brace Option
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrbigh, Apr 5, 2009.
  1. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Ok
  2. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
  3. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    If you are happy with it as it is then all good, I am much happier now it handles the way I drive it
  4. Sezy
    Sezy Active Member
    437
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Got my tanable strut bar and and it fit well. When tightening it down I broke 1 stud out of the 3 on the front passenger shock. Do I need to get a whole new shock or can just the bolt be replaced?
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    there is a mount plate on top of the strut which you will need to replace. its not hard to do, but if you don't know what your doing it can really hurt you bad. I mean like hospital bad. and if its got any miles on it, the struts could use replacement anyway.
    there is no need to tighten the nuts that much. use a shorter wrench if you don't have a feel for torque (or a torque wrench, which is good to have).
  6. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    69shovlhed may well be right but it is sometimes possible to remove the remainder of the bolt and put a new one in. I would try to drill a small hole through the broken off bolt and use an easyout. This would save a lot of time and money as you wouldn't need to take the whole thing apart.
    Good luck
  7. 69shovlhed
    2,170
    751
    Delaware
    on a normal bolt you can use an easy out but the mount has 3 studs welded to it. you won't be able to easy out the welded stud.
  8. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    My bad I must of been thinking of another car I helped someone with that had welded captive nuts and straight bolts going down into them
  9. Sezy
    Sezy Active Member
    437
    229
    37
    2020 Prius Prime
    Got it fixed... Wish I remembered to read this thread first. I went to the extreme and removed the whole strut. Had to hammer the old bolt out. Put a new one from the hardware store in then put the strut back in the car. As I was tightening the new bolt down it broke! I managed to get this bolt out without taking out the stud so already feel dumb for doing that. Put a different stronger bolt in that is still holding up. Had to get an alignment right away though,it was really off from me taking the strut out.
    Months later now and after going on road trips it's still holding up. Car is much funner to drive now.
    Failed first strut bar that wouldn't clear the cover.
    MISC picture from me taking the strut out and putting the new bar in.
    FROM BELOW
    STRUT out and you can tell which stud is broken.
    As long as it hold,should be good.
    SFO and Mike500 like this.
  10. Mike500
    Mike500 Senior Member
    2,593
    767
    You probably selected a 8.8 grade bolt that broke. You needed a 10.9 grade bolt, which meets with the Toyota OEM requirements.
    Also, the bolt, if it is M10, as I surmise, will be 1.25 fine thread, NOT standard DIN 1.5 thread.
    Hope this helps.
    SFO likes this.
  11. thegoldenhand
    thegoldenhand Junior Member
    44
    California USA
    doesn't the tanabe obstruct access to the inverter coolant? looks to me like it does.
    #51 thegoldenhand, Aug 25, 2014
  12. Sezy
    Sezy Active Member
    437
    229
    37
    2020 Prius Prime
    Sorry for the late reply. Ended up getting Megan Racing Coil Overs so all shocks/ struts have been fully replaced and car is lowered now. Oddly enough had one dealer say if I wanted to sell they would swap my shocks out since I kept the originals.
    It does block the inverter coolant but I had a both coolant exchanges months before doing this.
