Turtle light on - but battery full - engine won't turn off
Discussion in 'Generation 1 Prius Discussion' started by Oc.dreamer, Jun 10, 2014.
  1. Oc.dreamer
    Oc.dreamer Junior Member
    32
    2002 Prius
    I
    my turtle light is on and even though my battery shoes full, the engine won't turn off. Please help.
  2. messenger
    messenger Junior Member
    30
    Fairfield, IA USA
    You either get lucky and someone else has had this exact same problem or you pull the codes / sub codes.
  3. bwilson4web
    16,353
    You should be out of gas by now. So how long has the key been stuck in the ignition lock?
  4. Patrick Wong
    18,210
    6,512
    If the problem is that the ignition key switch is stuck:
    - try slightly rotating the steering wheel as you turn the key. The front wheels should be pointing straight ahead.
    - if that doesn't help then you'll have to get help to reach the back of the switch and disconnect the wiring harness connector from it.
    Oc.dreamer likes this.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    No, the key is not stuck, he's going thru a "rebalance" cycle (as I've heard it called before). Turn the car off then back on and voila, its fixed. :)
    #5 usnavystgc, Jun 11, 2014
  6. Mendel Leisk
    41,878
  7. bwilson4web
    16,353
    I was going by "the engine won't turn off" which suggested he could not turn the ignition off. <grins>
    But I also noticed there wasn't much gas in the tank, a single bar, so it would have easily run out of gas by the time I read the note. <GRINS>
    Oc.dreamer and usnavystgc like this.
  8. Oc.dreamer
    32
    2002 Prius
    I
    Hey guys thanks for all the input. Luckily later that day, everything went back to normal on it's own :)
    I was afraid my battery was going to explode since it kept charging lol
    bwilson4web likes this.
