What is this (exhaust pic)
Discussion in 'Prius c Accessories and Modifications' started by Priusxrs, Jun 22, 2014.
  1. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    [​IMG][​IMG]
    So I was messing around with my exhaust again and wondered what is this and do I need those hoses coming off it. Reminds me of the 2nd air pump crap that was on my corolla but it was part of the manifold
    SGH-T889 ?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    My guess is catalytic converter. If that's what it is, then yes all the hoses are necessary. In general, they don't put parts on a car that are not necessary........for something. :)
  4. Priusxrs
    61
    Pa
    Well u dont need a muffler but they have them on lol
    SGH-T889 ?
  5. bisco
    52,263
    agreed, i don't think they're necessary. just extra weight.
  6. Stevie
    Stevie Junior Member
    95
    22
    Melbourne,Victoria,Australia
    and too slow down the exhaust gases so the exhaust valves don't overheat
  7. Priusxrs
    61
    Pa
    So straight piping is a problem?
    SGH-T889 ?
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    not if gas mileage is not a concern. If you bought the car to get gas mileage, it is perfect now.
  9. Easy Rider
    982
    210
    N. Central Florida
    You slow down the exhaust gasses to make their exit quieter and to prevent the exhaust valves from over-COOLING.
    A slightly restricted exhaust keeps the exhaust ports on the engine at a more even temperature, slightly higher.
  10. Tideland Prius
    16,597
    mertechperformance likes this.
  11. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    I wouldn't change anything but the axle back...
  12. '04Prius
    '04Prius Junior Member
    51
    Wouldn't the catalytic converter restrict the exhaust gasses enough? I think that the muffler would just make it quieter.
  13. Easy Rider
    982
    210
    N. Central Florida
    Maybe. I don't know.
    I don't think the CAT really provides much restriction.
    If the gasses don't slow down, they don't quiet down either.
  14. mertechperformance
    532
    126
    Nor-caL
    New catalytic converters only eat 4 to 9hp. Not nearly as bad as they used to be. Ps if you go straight pipe it'll be a mellow volume yet nasty rice sound. I tried it. Ended up getting a muffler and glad I did. I wanted to do mid pipe but figured a low in toque might hurt mpg. So went with just the axle back as 1 is easier to go back to stock and not much of anything Matters THAT MUCH that far down the exhaust system.
    SGH-T889 ?
  15. Priusxrs
    61
    Pa
    Ive been running it with no muffler for around 20k miles wanted to see if it got any louder and more mpg with less resistance :/
  16. mertechperformance
    532
    126
    Nor-caL
    Yeah I hated the ricey rasp. With my intake and exhaust my mileage is the Same to slightly better
    SGH-T889 ?
  17. '04Prius
    51
    Did it? I would think that you would. I did some reading, and found that if you went "true" straight pipes (no catalytic converters, no muffler) it would hurt your performance/mpg. These engines are designed to have some back pressure, and I read that no back pressure would screw up the air/fuel mixture. Also some sources said that a performance muffler was better than straight pipes. I just don't know which would provide the most boost in mpg.
  18. pmike
    pmike Member
    237
    81
    Central Florida
    99.9% sure that is the exhaust heat recovery system. The cat is upstream from that.
    Neither. Toyota didn't leave any MPGs on the table. Only thing I have seen that has a measurable difference is grill blocking in cooler weather.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The Prius does not have an Otto cycle engine, so old wives tales don't work. You can piss off your neighbors, but it is just louder, not better in any way.
    In an Otto cycle engine the gasses are still expanding in the exhaust, in a Atkinson cycle engine the cylinder area when expanding is larger than when under compression, so the gases can expand more fully in the engine where it does work. (Not in the exhaust where it makes back pressure)
    (best picture I can find is in German)
    RightOnTime likes this.
  20. olieman
    olieman Junior Member
    Netherlands
    Hallo, my name is Tony from the Netherlands, I have only recently joined this wonderful forum.
    Now, about this funny looking exhaust, it is used to warm the heater water of the Prius C.
    wich is similarly as in my European version the Toyota Yaris Hybrid.
    See the attached drawing.
