HOW TO DIY: JDM Folding Mirrors with Signals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sfv41901, Jul 1, 2012.
  1. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:Don't all models after a certain year have the same number of airbags? Regardless, it's still best to tap the "blue" wire in the left "A" pillar. I have a 2012 PIP Advance, couldn't fully remove the plastic trim piece. Frustrated, I spent hours unsuccessfully trying to find the blue wire under the dash. With determination, I was able to tap the blue wire in the "A" pillar.
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    gotcha
  3. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    The trim problem lies in a short squarish black "tendon" for lack of a better name that IMHO is meant to secure the A Pillar cover from flying off at speed as the side air bag deploys. I found a way to take the A Pillar cover off by gently rotating the flexible middle of the "tendon" 90 degrees with a super-long needle-nosed pair of pliers. Then the head of the "tendon" popped right out of its cover slot. Ditto for reassembly. But that trick by itself took at least 30 minutes to figure out. In addition, there is less space inside the A Pillar to find the blue wire because of the folded-up air bag. Then of course the air bag itself is a fun item to work around, not knowing where the sensors are and anticipating a fast deployment around your fingers at any bump :-(
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    All model Priis have side Curtin airbags. @DadofHedgehog hit it on the money.....once u get the a pillar loose, u can rotate the black hook 90degrees. It's to keep the pillar from hitting the driver in the head. Once it's rotated, u can pull the a pillar out of the way.
    VS980 4G ?
  5. DadofHedgehog
    681
    282
    northern Virginia
    [/QUOTE]Let's see a pic of the new install...:)[/QUOTE]
    Here are the pix. Unfortunately most of the night ones came out badly because the camera on my Galaxy S II (or the cameraman) has a hard time focusing onto flashing turn signals at night in dimly lit parking lots.
    The night puddle lights are surprisingly useful. You can also judge for yourselves how very useful the folding JDM mirror feature is in a tight parking situation.
    DomCue, Burna J and sfv41901 like this.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  7. DadofHedgehog
    681
    282
    northern Virginia
    Awesome with use of your install video... and a cold beer or two out on the driveway on a warm summer weekend ;-) although I did curse the car gods when tryin' to sneak the wire bundle from the left side to the right side, upside down on my back under the dash... reminded me of working on my '66 Mercury Comet back in the very early 1980s.
  8. Accordlayingkit
    1,616
    1,747
    377
    He has a video of this install???
  9. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    Who needs a video, when you can have the master installer (sfv41901) do it in your garage. :rolleyes:
    DomCue and sfv41901 like this.
  10. Accordlayingkit
    1,616
    1,747
    377
    ^Who don't have the money to FLY him to Va?! ME!!!! haha
    sfv41901 and Burna J like this.
  11. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    I wish I had the guts to tackle something like this :) I'm going to find where @DadofHedgehog lives and drop my car off in his driveway. ;)
  12. DadofHedgehog
    681
    282
    northern Virginia
    Central Arlington. ...but I'm never home 'cause of the day job... :-(
    This mod's intimidating only because of the apparent number of parts and wires. After the mirror pairs' guts are prepped and swapped and remounted and the new wires are run through the door hinges, the mirrors are OEM functional and the rest of the job can be split into little logical sections.
    robertk328 likes this.
  13. DadofHedgehog
    681
    282
    northern Virginia
  14. Accordlayingkit
    1,616
    1,747
    377
    Yea me and u both need to find someone in VA man!
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Can I suggest a nice scenic road trip along PCH watching the beach :)
    Burna J likes this.
  16. Accordlayingkit
    1,616
    1,747
    377
    If only u were 30 mins away I'd give u $200 jus to wire me up! haha
    sfv41901 likes this.
  17. Robert Bo
    Robert Bo Junior Member
    Seattle, WA
    2013 Prius v wagon
    Hello I am a newbie- seeking info on this mod for my 2013 V. Anyone able to direct, or share any details?
    Bo
  18. Accordlayingkit
    1,616
    1,747
    377
    Toyota Prius 10 14 LED Mirror Cover Turn Signal Light Lamp White Color Painted | eBay
    ^They sell the power folding part of this as well and I believe its another $583 shipped last time I checked with them.
    Install instructions
    Balancing Act » Blog Archive » DIY: How to install JDM Prius power folding side mirrors
    ^if you just buy the mirror with the lights in them jus scroll down in the instruction link until you see "If you've purchased a 3-in-1 combo welcome winker LED kit"
    sfv41901 is the pro on the install if you would like to message him, hes really good and very smart about the install on the mirrors and the folding part if you buy that part separate!
    DomCue likes this.
  19. ncases
    ncases Senior Member
    609
    672
    Chicago
    Where to buy the auto folding mirror. I tried to use the link, it has no add to cart. Might be out of stock? Any other source. Thank you for your input.
  20. Accordlayingkit
    1,616
    1,747
    377
    send the same seller a message about them and they'll get Ya strait
    Seller info mitaccessories1 (2620)
