2010 Prius radio showing garbled text and ejecting CDs
Discussion in 'Gen 3 Prius Audio and Electronics' started by gobears81, Jul 29, 2013.
  1. gobears81
    gobears81 Junior Member
    San Carlos, CA
    I have a 2010 Prius (model III) that has begun doing this thing (just one month after the 3-year warranty expired) where the radio shows garbled stuff when the Prius starts up. It also starts automatically ejecting the CD. Pressing the buttons doesn't help. To fix the problem, you need to restart the Prius.
    This only happens once in a while, but it is starting to happen more frequently.
    Does anyone else have this problem? A picture is attached showing this problem.
    Tags: on the fritz, triangles, display, muddle, jumble, not working, messed up, unreadable, compact disc, compact disk.
  2. nklb
    nklb Member
    111
    If it really is just one month after the warranty ended, you may want to ask if the toyota dealership will help you anyway. You may be surprised.
    gobears81 likes this.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Ugh...bad timing.
    I would say that the first easiest step might be just to talk to your Toyota Dealership Repair Center. If you're lucky, maybe you could get some support, so close to warranty expiration...or if you are lucky, maybe they have seen the problem before and it's a cheap and easy fix..."maybe".
    If not, you get the "Fun" of investigating replacement options. If it can't easily or cheaply be repaired, I'd definitely take the opportunity to upgrade.
    Every vehicle I have owned for an extended period of time, I have taken the approach that I enjoy the OEM audio system as long as possible, but I take breakdown as a sign from the universe that it is time to upgrade.
    If you like the system as is? You hope to get a few years beyond the expiration of the warranty. That's bad luck.
    The other option of course is simply to live with it as it deteriorates. Kind of takes CD's out of the loop.
    Here's hoping you get some good luck.
  4. bathala
    bathala Member
    128
    30
    Area 52
    I'm like The Electric Me. Wait for anything to break past its warranty and use it to justify the upgrade. I understand that not everyone can afford to spend more on their car. If you're the latter, I wish you luck with the dealer and hope they'll consider your situation. Otherwise, another OEM from ebay or junk shop might be your next option.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Try running a cleaning disc through it and see if that helps. I assume this only happens when a disc is in the drive?
  6. gobears81
    San Carlos, CA
    Thanks for your feedback. I set up an appointment tomorrow with the dealership. I think the discussion will mostly revolve around the photo and video.
    If they won't repair it under warranty, I'll see if it happens again if no discs are ever stored inside. I think there is a circuity problem inside the audio system.
  7. gobears81
    San Carlos, CA
    I was charged $67 from the dealer just to look at the car.
    They are saying I need a new radio that will cost $450.
    This is terrible. I'm most likely never buying a Toyota again after this experience.
  8. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    How about answering the question:
    Does this only happen when a CD is in the drive? If so, try the cleaning disc option. You could be looking at an error with reading the disc, was my point. Recordable discs are well known for giving fits to players. If it happens with no disc in the drive, then yes you might need a new unit.
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    As the car is 3, check the 12v battery, weirder things have been know to happen when the 12v is low on umph and 3 years is about it's tour of duty;)
    If you truly do need a new head unit, crutchfield isn't a bad place to start
  10. Radiospank
    Radiospank Member
    155
    70
    Yeah my radio does this too but I suspect the voltage from my amp has some effect on this.
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Surely another option is to seek a second hand unit from a wreckers? I'm past 100k and my audio unit is still same as new. You can't predict how these things last.
  12. gobears81
    San Carlos, CA
    Great advice, thanks a lot! I don't believe the problem is from how the system is reading CD's. Nonetheless, I'll leave the CD's out of the unit for a few weeks to see if it happens again.
    I like the idea about looking for a second hand unit from a wreckers.
  13. Fore
    Fore Don't look back!
    494
    107
    Unfortunately the same thing happens to me minus the CD ejection, right when it was 3 months out of warranty. The radio works fine but the display is either blank or garbled from time to time. Seems to be worse in extreme temperatures above 80 degrees with high humidity. When it's garbled I turn it off then on, seems to help fix it. When it's blank I lightly tap the upper right hand corner of the radio and it lights up normal. I'll just live with it till it dies then replace it with a used one or after market.
  14. gobears81
    San Carlos, CA
    Thanks for commenting, Fore! Even without any CDs inside, it still fails as shown in my video. I also think it has something to do with heat and/or humidity.
    At least we got a car wash when it was reviewed by the dealer for $67! Haha!
  15. robertk328
    robertk328 Member
    206
    36
    Northern Virginia
    I had this happen with mine before as shown in the video below. It eventually worked itself out and hasn't occurred again. It's been almost 2 years and hasn't had any issues.
  16. gobears81
    San Carlos, CA
    That's awesome! It hasn't happened in a week or so. Thanks for commenting. I hope it goes away on ours as well.
  17. Sioul
    Sioul New Member
  18. Troy Clark
    Troy Clark New Member
    my experience in short terms is that these radios are garbage and yes im speaking from personal experience.
  19. jamrog
    jamrog Junior Member
    I have to same thing happening to my 2010. I live in Mass so I first stated noticing it in the Cold weather, not Hot. My remedy is to turn the defrosters on and that seems to warm it up in about 10 minutes and it works again. I can use the Steering wheel controls to listen to the radio because all the radio buttons just seem to turn the unit on and off. I'm skeptical about the battery voltage suggestion but will put a voltmeter on it and keep and eye on it.
  20. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
    This is happening to me, very intermittent - frustrating and not covered under my warranty. I don't really use any info on the screen so I don't really think it's worth paying $400+ to repair.
    Sucks nice person though :(
