HID makes fog lights useless
Discussion in 'Gen 2 Prius Accessories & Modifications' started by NedBinCNY, Jun 25, 2014.
  1. NedBinCNY
    NedBinCNY New Member
    28
    Syracuse, NY
    My new to me 07 with pkg 5 (everything but leather ) has the HID headlights, which are great , except when it is foggy out. I do mostly night driving, and most if that on rural 2 lane roads. Last night I had a lot of solid heavy fog, those HID headlights overwhelmed the poor little halogens in the bumper. Adding insult to injury, the fog lights only work with the headlights...
    Anyone know of an upgrade bulb for the stock fog lights? And or is there a hack to change the fogs so they'll work with the parking lights instead of the headlight circuit?
    Barring those changes, I'm going to have to put a set of aftermarket fog lights on, wired up so they'll work when the parking lights are on.
    Ned
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    If you haven't changed the foglight bulbs to a warmer 2500 to 3000k yellow bulb do it. They'll provide more contrast on the road. Don't know if your HIDs will wash them out though.
    You could use a relay harness to wire the fogs directly to the fuse box. You'll need to find a fuse that's only powered when in Ready mode, and you can add a switch in the dash to control it.
    SCH-I535
  3. NedBinCNY
    28
    Syracuse, NY
    I'll get a photo tonight, we've got rain today, and I fully expect I'll see more fog tonight. I can tell that the fogs were on, but the HID's have such a wide field, I was simply annoying any oncoming drivers even more. The HID range is a good thing, I can see all of those suicidal deer and other critters, but when I get into a solid wall of fog I'm driving nearly blind.
    when that happens, I need to be able to turn Off the headlights and put light under the fog, which of course can't happen with the fog lights shackled to the headlight circuit.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I try to find the PIAA ion crystal replacement when I change the fog light bulbs. They produce yellow light.
    SCH-R530M ?
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    They're really expensive though, I've had good results with the Nokya brand.
    SCH-I535
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I only knew about PIAA before. Thank you for the info about the Nokyas. Did you try the bigger bulb versions?
    SCH-R530M ?
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And that is the KEY to fixing your problem.
    The bright headlights and fog is just like shining the lights into a mirror, both for you and other drivers around you.
    It is possible that the low beams are adjusted too high too.
    You are using low beams only......right ??
  8. NedBinCNY
    28
    Syracuse, NY
    Oh yes, low beams only:
    Ned
    Low plus fog lights
    I'm parked btw more later
    Ned
    #8 NedBinCNY, Jun 25, 2014
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Try and find a level area with a flat wall about 20 to 30 feet away to see your cutoffs. They appear to be too high in your posted pictures.
    SCH-I535
  10. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    If anything, fog lights are meant to be seen. It isn't really to see the road. The 3000k bulbs are good.
    iPhone ?
  11. Mendel Leisk
    41,901
    I think that's illegal; the low beams have to be on with the fogs.
    FYI, the OEM fogs on our 2010 are pretty ineffective too, it's hard to see the difference, switching them off/on. At least we don't get much fog, and/or are rarely driving at night in areas without street lights.
  12. NedBinCNY
    28
    Syracuse, NY
    At the risk of being a scofflaw I want safe... If that means rewiring so be it.
    Ned
  13. lesturner
    lesturner Taming the Dragon - Tennessee
    75
    Bremen, IN, USA
    If you are willing to do a little soldering, the instructions are here... Fog lights
    Do keep in mind that in many states, law requires headlights on with foglights. Doubt you will get pulled over in heavy fog for it though. I also erred on being safe and apologizing later.
    Les ---
  14. Easy Rider
    982
    210
    N. Central Florida
    That's what I thought too.
    The low beams in both my new(er) cars have a rather sharp cutoff on the top but they aren't HID either.
    Just when you think you have heard EVERYTHING........
    NOT true at all.
    Fog lights are mounded low to get light on the road without reflecting as much back in your face.
    What caused you to believe that anyway ??
    Reference please.
    I think that is NOT true......as long as the fogs are bright enough.
    A headlight is a headlight.
    I am pretty sure the requirements are NOT that specific.
    #14 Easy Rider, Jun 26, 2014
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    The requirements here are that low beams need to be on as well. It is illegal to have the fogs on without them. That is probably why Toyota wired them that way in the first place. They don't want any chance somebody will point their finger saying Toyota made it so I can turn them on without the low beams. The pictures of the low beams kind of make it obvious the benefit of their independence though. I guess the law makers here have never driven in bad fog, maybe are always being chauffeured around....
    Sorry, I believe it is in the DMV handbook as reference.
    SCH-R530M ?
  16. NedBinCNY
    28
    Syracuse, NY
    I think I'm going to skip modding the stock lights, though I will upgrade to the better bulbs. I'll also find a convenient wall some evening, and 'fix' the beam height.
    I'm going to look for a set of aftermarket fog lights, wire them 'correctly'... and run them when I really need them. On the roads I'll be driving When I Need the fog lights, I'm more than willing to ask forgiveness if a cop ever saw me.
    Even though it is only June, winter will be here before I know it, and I bet that those HID's will be just as annoying when I drive in Lake Effect snow as dense fog.
    Thanks all for the input, I really appreciate the PC forum's sharing of information!
  17. Mendel Leisk
    41,901
    Maybe there's a safety reason for not running fogs alone? I mean, why is this law on the books?
  18. Easy Rider
    982
    210
    N. Central Florida
    Because most common fog lights are not bright enough to properly illuminate the road in non-fog conditions.
    And politicians are not smart enough to word it so that it ONLY applies when there is no fog or heavy snow.
    And some people are dumb enough to do it just because they think it is "cool" even if they can't see the road good.
    If the conditions were REALLY bad, the LEOs would certainly have other things to worry about I would think.
    [soap box on]
    If you get trapped in a fog or heavy snow related chain reaction crash, it is possible that you will DIE without having really done anything wrong.........EXCEPT driving when you should have pulled off and stopped. And that doesn't mean on the shoulder either.
    NO commitment is worth risking your life like that. NONE.
    [off the box]
  19. OGGIE50
    OGGIE50 Member
    94
    42
    San Diego
    I replaced my HID's DS2 with 5000k & fogs with 9006 5k from DDM Tuning: HID and LED Lighting Headlights are just R&R and VERY easy to replace. The Fogs (touring) is VERY EASY and is PLUG -N- PLAY. I chose the 5k combo cause i wanted the WHITEST bulb, 6k is BLUE & 4300K is stock. Makes a HUGE difference. BUT if you want it for the FOG i suggest a 3k for the fogs as they fill in where the headlights can't.
  20. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Coming from a Country that suffers more than its fair share of fog (front fog lights are standard on the Prius), I thought I'd drop my experiences.
    If the fog is bad that your own headlights reflect back at you, so switch on the side/parking lights and fog lights only. Do not switch your headlights on. That way the lower fog lights enable you to see where you're going without dazzling back up.
    The beam doesn't project as far but in thick fog you won't be going fast enough for that to cause problems anyhow. Then as conditions improve you switch your headlights back on.
    The above is useful in heavy snow too where the snow causes that mesmerising tunnel effect in normal or full beam headlights.
    In fog or heavy snow, brighter isn't necessarily better
    Data Daedalus likes this.
