Fresh Air/Recirculate Mode Broken?
Discussion in 'Gen 2 Prius Main Forum' started by Sung Woo, Jun 9, 2014.
  1. Sung Woo
    Sung Woo Junior Member
    70
    Washington, NJ 07882
    Four Touring
    I own a 2007 Prius with almost 125K miles. I've had AC issues with this car since I bought it with 97K miles, and there's one thing that I just realized. I have a sneaking suspicion that the fresh air/recirculate mode is not quite working right. I have a feeling my car might be stuck in fresh air mode, or if not stuck, that the baffle is not closing all the way when I place it in Recirculate mode. Is this an easy thing for me to check, or does it involve taking apart the dash or something more involved?
    I also noticed that when I have the fan turned on and I go from Fresh to Recirc, the fan does not go into a higher speed. In every other car I've ever owned, this has been the case -- is this not the case with the Prius?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There are baffles that use servo motors to direct air flow. We see a variety of ways in which those baffles can fail. For instance:
    New clicking sound under dash, drivers side | PriusChat
    middle air vents stopped blowing | PriusChat
    First I would recommend that you take a look under the dash, and see if those servo motors are moving. It might just take some cycling of the modes to loosen things, or it might take disassembly of the dash to get to the air controls. The recirculate mode does not change the fan speed in the Prius.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Correct, it doesn't. And in 50+ years of driving.....maybe 30 different cars......as well as driving cars for a rental car company for 5 years......maybe 1000 different cars.......I have NEVER seen one that does that. Never.
    Now, if you push the MAX AC button, it switches to recirc and high fan.
    It may sound like the fan speeds up because it becomes more noisy to the driver as the inside air supply door opens.
    And even on recirc. there still is some outside air coming in; about 20% I think. That is a safety feature.
    What exactly leads you to believe that recirc is not working right ??
  4. Sung Woo
    70
    Four Touring
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,066
    547
    Tucson, AZ
    2021 Prius
    You didn't say which button you are using to switch between recirculate and fresh air modes. There are two buttons, one in the Climate menu on the MFD and maybe one on your steering wheel, lower right quadrant. There is also a confirming graphic, in between the Ready and Auto A/C lights on the dashboard, which lights up when in recirculate mode. This is assuming little or no difference between the 2007 and my 2008 model year. I don't think there is that much difference. When your clockspring begins to wear out, you will lose button functions in this quadrant of the steering wheel button set first. I have to use the MFD fresh/recirculate button to make changes as my clockspring is on its way out.
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    #6 valde3, Dec 7, 2014
  7. JC91006
    JC91006 Senior Member
    16,827
    8,600
    Check your cabin air filter, make sure it's not clogged
