Dear Spider, Y U NO DIE SOMEWHERE ELSE?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Blu-ray, Jul 7, 2014.
  1. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    So yeah. I have a dead spider in my taillight. Of course I can't get to it! Any thoughts on how to remove the corpse?
    Ugggg!
    #1 Blu-ray, Jul 7, 2014
  2. ETC(SS)
    7,461
    I don't imagine he caught very many meals in there.
    Evolution in action. :)
    The way I see it (pun almost unintended) is that you have 2 choices:
    1. "Canned air": Try to find the hole that the 'pider used to get into the tail lamp assembly. Stick the nozzle into the same hole and try to move the body. He'll still be in there, but you won't be able to see him as easily.
    2. Drive in LA. California isn't a financially well run state. They have streets that will shake rust off of a screen door. You can try to use a rumble strip or some speed bumps to shake the corpse to the bottom of the tail lamp assy.
    3. If you're really OCD and you just can't take it any more: Spend the $114 and replace the lamp.
    TY1114-U000L / 81561-47111 | TY1114U000L / 8156147111 | TO2818146 | NEW Toyota Prius 2010 Driver Left Tail Light Eagle Eye 81561-47111 | New-Part.com
    Sell the used one in PC or on eBay for $50....."No extra charge for the "Spider-Man" edition!!!!"
  3. bisco
    52,703
    drill a small hole and a hypodermic needle?
  4. Blu-ray
    471
    198
    TampaBay, FL
    1 and 3 I'll have to try, well 1 first and then if not 3.
    2 has been tried for awhile now. I drive over speed bumps at home and work. I also drive over a really nasty stretch of road which they are finally going to repave. I'm talking about this road with it's pot holes and fixes are a death trap with the right conditions waiting to happen. If you're not hitting a pot hole you're hitting a too high 'fix'. Serious, it's 50MPH through there and all of a sudden it's like you're on a back country road somewhere that's never been paved!
    Thanks for the advice.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Yuck? It's just a spider, and a dead one at that. Chill out!
    Air is the only way. It will probably come out if you insert an air hose in a lamp socket hole (remove the lamp socket(s) of course). Canned air is less likely to do the trick. You need lots of air. As in a compressor. Remove all lamp sockets, install a short tube on the air nossle and insert as far as possible in the housing. Move it around as much as possible while it is blowing. If that doesn't work you could try removing the housing from the car and turning it upside down and tapping it gently to get the body to drop into an area of more room where you can blow or pick it out.
  6. Blu-ray
    471
    198
    TampaBay, FL
    Where there is one there are more! I'm gonna have to fumigate the car!
  7. priusrc
    priusrc Junior Member
    53
    lower pennisula, Michigan
    I would drop a nuke from high orbit!
  8. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    CSMgms and Tideland Prius like this.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Just leave it alone. It will dry up and turn to dust and you will not even notice!
  10. Sierra Mark
    Sierra Mark Junior Member
    30
    Mission Viejo, CA
    Just get a new personalized license plate "Spiderman".
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Oh whew, I thought this thread was about me. :)
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Whew! Your safe! That was close!:p
    spiderman likes this.
  13. ETC(SS)
    7,461
    We're not supposed to know about those..... :whistle:
  14. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I thought they made the taillights out of spiders, this may be one that didn't get melted down.
