Dead spider in tail light
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Nervous, Sep 30, 2012.
  1. Nervous
    Nervous Junior Member
    38
    La Canada Flintridge, CA
    Earlier today I noticed a dead spider in my driver side tail light. It's positioned on outer edge of the main housing near the red section. Is there an easy way to remove it?
    NOTE: The vehicle is a 2012 Prius v 5 with Advanced Technology Package... With only ~600 miles on the odometer.
  2. Nervous
    38
    The fix for this issue turned out to be have the dealer replace the tail light (under warranty). :)
  3. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
    Nervous, was there no other way to get it out? I'm curious because I had a little run-in with my trash can and now have a golf ball size hole in the clear plastic lens on the passenger side of same kind of v (Broken tail light lens | PriusChat)
    Does your receipt/invoice mention a part number btw?
  4. Nervous
    38
    ZPriusV5,
    Since the tail light is a sealed unit, there was no way to remove the dead spider... Thus, the entire tail light was replaced.
    Also, I ended up selling the vehicle back to Toyota (and had to surrender all service documentation with the vehicle). So, I don't have the service records to reference... Sorry.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    You traded back your car after 2 months? May I ask why?
  6. Nervous
    38
    Toyota bought the vehicle back (due to repetitious electrical issues) and I purchased a replacement vehicle. I think it was an isolated case of a bad apple; which would've ended up qualifying for the Lemon Law.
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Wow. Did they buy it back at what you paid? Did you have to use lemon law?
  8. Nervous
    38
    Yes, they bought it back for the same price I paid... The entire transaction was basically a wash for me from a financial perspective.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Wow. At least they owned up to it. Did you replaced it with another v?
  10. Nervous
    38
    Yes, the replacement vehicle was also a Prius v 5 with Advanced Technology Package. The only difference being the new one is Barcelona Red and the buy back was Blue Ribbon Metallic. Now my wife's Prius v is Red and my Prius v is Blue; which is what we initially wanted anyways. :)
  11. ZPriusv5
    74
    Cincinnati, Ohio
    cross posting from Broken tail light lens | PriusChat for reference
  12. Adam Leibovitch
    498
    102
    I have a spider that shows up in my tail light to say hi every once in a while. I am glad he hasn't died in there.
    SGH-T999 ? 2
  13. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Man, Machine, Nature, living in perfect harmony.
  14. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    And if you said you do not keep those paper copies ??? They wouldn't buy it back ?? How would they know if you have them or not ?
  15. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Remove a bulb and vacuum it out
    CCM likes this.
