Prius c spark change plug
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ufourya, Jul 12, 2014.
  1. ufourya
    ufourya We the People
    1,258
    336
    42
    I passed the 58,000 mile mark and thought I'd take a look at my spark plugs. They did not look bad at all but in checking the DENSO spark plug site:
    Frequently Asked Questions: DENSO Iridium
    I discovered they recommend replacement after 30,000.
    Only iridium plugs available locally were Champion 9002. I got some and began the change. After removing the first plug, I noticed a difference between the OEM DENSO 3485 (also listed as FK16R-A8) and the Champion. I liked the precision look of the DENSO compared to the CHAMPION:
    So ordered some from Rock Auto and returned the Champs.
    To make the replacements first undo the 10 mm bolts holding down the coil sleeves:
    Then using a 5/8 inch spark plug socket, remove the plug. You will need an extension to reach:
    Unscrew. I vacuumed the opening beforehand just to make sure nothing had dropped into it. Then place the new plug into the socket and hand tighten. DENSO has torque recommendations:
    If you use an anti-seize lubricant on the threads (and I did) you are to cut the torque in half. So I tightened to 11 lb-ft. with a torque wrench.
    I forgot to mention a couple of things. The plugs are 14 mm flat seat. And one has to unplug the clip from one of the coil sleeves in order to pull it up. you will have to turn it a bit to get it past the tubing.
  2. Mendel Leisk
    41,640
    Wait a sec, no tearing the car half apart, windshield cowl, wipers and motors? That's progress Toyota!
    Fostel and SageBrush like this.
  3. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Was the inside of the plug hole clean and dry?
  4. ufourya
    1,258
    336
    42
    Yup.
  5. Mr Incredible
    955
    506
    Neb
  6. ufourya
    1,258
    336
    42
    Are you crying or smelling?
  7. Mr Incredible
    955
    506
    Neb
    Just a bit of dust in the eye...
    I don't think I've ever seen a Japanese plug hole without grit and oil. Sometimes LOTS of oil. Granted, my experience with non-American cars is limited, but I would be overwhelmed to find a hole clean, dry, and shiny. I'd have to just look at it for ten minutes or so before I even grab a wrench.
    Kasra, Fostel, ztanos and 1 other person like this.
  8. ufourya
    1,258
    336
    42
    Ha ha. I was amazed that the old plugs look as good as they do. I wonder what I'm doing wrong.
  9. Mendel Leisk
    41,640
    The cables have a cap that overhangs the spark plug well, protects pretty well, coupled with the ornamental plastic valve cover. That said, there doesn't look to be much of a lip on the Prius c spark plug well.
    I've had a motorcycle with deeply recessed wells that had no protection, were full of crap, and some leaking coolant. They were pretty much FUNNELS for junk...
    I took an old plug, hacksawed off just the thread portion of the plug, and expoxy glued and length of slim wooden dowel to the thread.
    I could gently remove the plug, screw in this contraption, and then shoot compressed air in there, without the usual sparkplug in the way, blocking the air jet.
    #9 Mendel Leisk, Jul 14, 2014
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    They look *great*
    For me the main problem with these long life plugs is forgetting about them entirely.
  11. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I could see this happening. Aren't they 120k mile change interval?
    JBurdman7 and Fostel like this.
  12. col127
    col127 Member
    345
    Illinois
    What's the recommended time frame to change spark plugs? My car is at 42k miles... I've just been following the standard Toyota guidelines...
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    If memory serves, either 100k or 120k. Forum gurus have advised taking them out much sooner for an inspection and to apply a dab of anti-seize. There is a concern that at 100k+ miles even if they are working fine they will be hard to remove.
    I accept this reasoning, but honestly if I am going to take the trouble to gain access to remove the things, I'll just replace them.
    ztanos likes this.
  14. ufourya
    1,258
    336
    42
    The sleeve with the rubber gasket (large arrow) apparently does an excellent job protecting the well. I have not pressure washed or even hosed down the engine compartment. So I don't know how the well IMG_3677 (2).JPG could get too dirty or wet. Since we drive hybrids, the mileage on the ODO will not represent the mileage on the plugs. Toyota says 100k and Denso says 30k. I frankly think the ones replaced appear to have many more miles in them, but the new ones were begging to be installed. I learned something. Hope this thread will be helpful to the inquisitive.
    robertmaria and ztanos like this.
  15. UoD
    UoD Junior Member
    96
    Southeast USA
    I hope this isn't a stupid question -- but, it's been over 15 years since I have had to change plugs on a vehicle. This looks like a simple car to change plugs on, so I want to do it myself instead of paying the $250 that the local shop just quoted me.
    Anyhow --- my question is : Do I need to gap the DENSO 3485 plugs? I didn't see anything in the writeup above about that. Or -- are they pre-gapped?
  16. Mendel Leisk
    41,640
    The plugs should definitely be pre-gapped, you shouldn't have to touch that. Some manufacturers even caution against trying to fine-tune, adjust them further.
    UoD likes this.
  17. UoD
    UoD Junior Member
    96
    Southeast USA
    Just changed them out over the weekend. If you ignore the 10 minutes it took me to run down to Home Depot to get a pair of really long needle nose pliers (socket got stuck on the plug and came off of the extension ... forgot to tape it first :) ), the whole job took me about 20 minutes. Thanks for making this thread @ufourya .
    My wife's 2012 Prius C was at 120,500 when I did the change out on Sunday. Plugs came out without any effort, and everything looked surprisingly clean. She puts about 54,000 highway miles on this thing every year , and I am trying to do my best to keep this thing running to at least the 250,000 mile mark. I know with fluids (engine and inverter coolant), they say to change them out more frequently after the 100,000 mark. Is there any reason I should do the same with the plugs? Or, is the recommended 125,000 interval still good for these? Like I said -- the plugs I took out didn't look too bad at all.
  18. Mr Incredible
    955
    506
    Neb
    I always check sparkplugs even though they're pregapped. Just to be sure. The little coin shapped gap gage is the type I like.
    Mendel Leisk and Fostel like this.
  19. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    This is a very informative thread. I have 81k on my C, the car is running fine so will wait until I hit 100k I guess.
  20. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    Very Informative thread I have 67K on C, i think i will wait for 100K ;)
