Suspension mods underbracing question?
Discussion in 'Prius v Accessories and Modifications' started by rick s., Jul 15, 2014.
  1. rick s.
    rick s. Junior Member
    San Diego ca
    2014 Prius v wagon
    Morning. First post here. Got a question about all the choices when it comes to under bracing and sway bars. I want to try and improve the way the wagon handles. Not street racing the thing but I do enjoy spirited driving. There are tons of different options and I have no idea which ones I need or their order of importance. Any help would be appreciated. In the parts descriptions they all seem to do similar things leaving me a little puzzled. Funds are not endless so achieving a great ride without going too far into debt to achieve it. Traded in our 2nd Gen for this v so it's not like I am used to driving a sports car. Thanks for stopping in.
    -Rick
  2. KazokuWagon
    KazokuWagon Junior Member
    36
    No Bueno Park, CA
    2014 Prius v wagon
    The 2 braces that I think do the most would be the Cusco front strut bar, and the Cusco center brace.
    I haven't installed a front sway bar yet, but that would definitely help with reducing body roll.
    I have the Cusco rear sway bar, and it stiffened up the rear of the vehicle according to my daily spirited commute.
  3. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    The typical order of operations outside of PriusChat for improving a vehicles handling is 1) tires, 2) swaybars, 3) springs and shocks. Chassis bracing is so far down the list of importance because it can't play much of a noticeable role until those items which are far softer than even a rather flexible chassis have been rectified. I have installed swaybars on virtually every car I've ever owned, and recommended them to countless friends who have complained about their vehicles handling. They are cheap, effective, easy to install, and do very little to negatively affect ride quality. If you don't want to change tires, that's where I'd start.
    69shovlhed, Mprius and rick s. like this.
  4. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    Any recommendations for which sway bars are simple and effective for the v? Tires may or may not get changed when it comes time to do so, but given that they are a wear item it would make sense to someone like me to do the mod first, and then see if it gets to "good enough." There are also lots of different trade considerations for tires, so knowing where the baseline is with sway bars seems like a rational thing. Thanks.
  5. Mprius
    Mprius Junior Member
    This is the one installed, i have also lower with Tanabe spring. Like zhenya mention i recommend you try those first before body bracing.
    Cusco - Sway Bars - Nengun Performance
    942 311 B16
    Toyota - Prius ZVW40 16 mm
    Prius - ZVW30
    rick s. likes this.
  6. rick s.
    San Diego ca
    2014 Prius v wagon
    Thanks for all the replies. Cleared up a lot of things for me. Going to start with the cusco sway bar. Should the rear sway bar come next? Going to have to do this in stages so the woman doesn't freak out over the $$. Also does lowering with spring replacement help handling? I would imagine the lower center of gravity would help. Do you have to drive it like one of those lowered Hondas all slow over the smallest bump? If so then I will stay at stock height. Thanks again everyone. I will try and post some pictures of what I have done so far. Just tinting, I dipped the wheels, and added a stealyourface sticker to give it a personal touch. Oh yeah and some black dice valve stem caps. Total cheese ball pep boys junk. Coffee rambling sorry. -Rick
  7. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I would do the rear bar before the front.
    Lowering springs are almost guaranteed to make things ride worse. You may get a bit better handling through corners on smooth pavement, but everywhere else will be a negative. Spring rate really has to be matched to the damper, so if you take factory dampers matched to soft factory springs, and add stiff springs, you'll be way under-dampened which will cause all sorts of ride issues.
    Swaybars work by effectively increasing spring rate but only under cornering loads. That's why they work so well without doing much to ride quality.
    rick s. likes this.
  8. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    Exactly correct. Given the mass distribution of the Prius v, under most circumstances, I don't think rear ones are needed. I'd only bother if front ones and braces left you wanting more.
  9. Greg@SEC
    Greg@SEC Junior Member
    So Flo
    2014 Prius v wagon
    I recently (July 2) also bought a V and have been on a misson to make it a bit better handling.
    So far I have the cusco STB (strut tower bar) and lower middle brace.
    It seemed to help a little. If I had it to do over I would have gotten the rear sway and STB then middle brace.
  10. rick s.
    San Diego ca
    2014 Prius v wagon
    Time for a rear sway bar. Just gotta find a good price. Anyone know of any good deals such as sales, coupon codes, or just a good everyday price?
  11. Mike500
    Mike500 Senior Member
    2,593
    767
    The front under brace that fits on the end of the rails between the ends of the two reinforcing "triangles." I've found from extensive testing, has basically the same effect at the strut tower brace, at half the price and minimal installatio9n labor. Just remove and replace two bolts.
    The space between the two rail ends move in an out in this area like the flailing ends of an inverted "U" as do the area of the mid-under chassis brace.
    Over time, the separation becomes wider and wider and acquires a "SET" that changes the front end alignment of the car and with less effect; the rear.
    The front brace works best under tension, while the mid brace maintains the separation of the rails to close the inverted "U" and works under tension, compression and bending forces
    The best combination is the front "tensional' and the "box beam" mid under brace.
  12. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    zhenya,
    I beg to differ> CHASSIS BRACING should come right after wheels and tires upgrade. A stiff chassis is the basis for improving handling as it permits the suspension to work with minimum body flex. Body flex screws up suspension. That's why race cars have welded in roll cages and weld "stitching" of all body seams. High end sports cars have VERY stiff bodies.
    Counting my Cusco strut tower brace I now have 3 chassis stiffeners with a 4th coming next. I have Tanabe lowering springs and ENKIE 17" X 6" wheels and Yokohama 580 V rated tires. (V rating necessary for the high temps here in 'Vegas and the Mojave Desert.) Last come the front and rear sway bars.
    Do as much bracing as possible and you will see the difference. The Prius v is a "dishrag" as it comes from the factory. It begs for stiffening.
    UPDATE: I had the Tanabe front sway bar installed. It truly helps flatten the car in corners as well as dampening the jouncy feel from the lowering springs overpowering the stock shocks.
    I think I'll install the rear Cusco sway bar myself since it's an easy install. Then I'm finished with handling mods until 50,000 miles when I replace the stock shocks with adjustable ones for even better handling.
    #13 Eric "v", Nov 17, 2014
