Noise Reduction Options...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gunjee, Jul 16, 2014.
  1. Gunjee
    Gunjee Junior Member
    New York
    Most of the threads regarding sound proofing the Prius date back to 2012. I'm just refreshing the topic to see if there are any newer options available...
    I recently upgraded my wheels from 15" 195/65/15 to 17" 215/45/17. I have definitely noticed a reduction in the outside noise, but, there is still some areas with noise. I hear whooshing through the driver side door as I'm racing down the highway. I sometimes feel some of that whooshing down by the pedals too. I also notice a rattling sound from the hatchback every time I go over an extremely bumpy road...not sure if that's the plastic spoiler on the hatchback...?
    I don't want to go overboard and sound proof the roof, floors, head lights / tail lights, etc. I'm mainly interested in enjoying the JBL sound system, and losing some of the whooshing sounds. So is Dynamat the solution for this, in all four doors? What about the trunk? I'd appreciate any feedback / suggestions from you guys who have dabbled with sound proofing. Thanks...!
  2. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Any soundproofing you add will help reduce noise. From what I hear, doing the four doors yields very positive results.
    I'm planning on doing my doors in the fall.
  3. Gunjee
    New York
    I've been doing some research online, and I see that Thermozite Insulator Padding is a cheaper alternative to Dynamat. I've also read some people's threads that state that they had good results from just padding the cargo area. I might just give this a try - it won't hurt, and I really don't have to take a bunch of panels apart...
    Anyone have feedback on Thermozite...?
    Did you notice an improvement when just padding the cargo area...?
  4. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I don't think the Thermozite Insulator Padding will give you what you want in isolation. It may be a good decoupling device, but will likely do little from a noise-reduction standpoint. The typical full or multipe layers of Dynamat is overkill and you quickly hit a point of diminishing returns.
    Check out Welcome to Sound Deadener Showdown | Sound Deadener Showdown for what I feel seems to be one of the best researched noise reduction methods. Here's a good thread from someone who applied the concept to his Prius: Total Sound Makeover - Sound Deadening, Speakers, Processor, Amp, and Subwoofer | PriusChat
  5. Gunjee
    New York
    mrstop, thanks for the links. As much as I'd like to do a total sound makeover, this is simply not practical for me. I guess I'm just going to have to put up with the noise since there's not that much traction with this thread...
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    Again, this is more than you wanted to do, but I got good results:
    Dynamat 2.0 | PriusChat
    Also, that whooshing noise could be air flowing into the seam between the front edge of the door and the front fender. No one has come up with a good seal for that as yet. My old Caddy had a rubber seal that was attached to the edge of the door and when it closed, it sealed off that gap ending wind noise.
    Oh yes, your hatch noise could be caused by the rain spacers...I'd have thought Toyota would have solved that by now!! I used sticky-backed felt from Michaels to make covers for the spacers and that stopped my hatch noises.
  7. Gunjee
    New York
    Phoenixgreg, thanks for the tip on the rain spacers. Funny thing, as I inspected my rain spacers and closed the hatchback, I noticed that the rattling sound came from my license plate frame. Since there are no screws on the bottom half on the license plate, that seems to be rattling on bumpy roads...
    I guess I'm going to have to look at another type of license plate frame. I did notice that the rain spacers still look like metal on metal contact, so I will add the felt tape just to play it safe - any noise reduction helps...!
    Yes, your Dynamat project seems like a lot of work...! What about B-Quiet - I'm also seeing a lot of thread traffic on this stuff...anyone have comments on B-Quiet...?
    I just happened to be passing by a stereo shop today and spoke to one of the guys. He quoted me $80 per door for sound deadening. I didn't get into specifics - but I believe that includes the material. I checked them out on Google, and they got a lot of positive customer reviews. Is this a fair price...?
  8. phoenixgreg
    1,157
    294
    66
    Phoenix
    I really can't say if $80 per door is fair or not - and it depends on how much material the shop really adds. Once the doors are back in place, you the customer won't know just what they did. I used Dynamat on all of my 4 doors too which make a big difference. Here's a shot of the passenger door exposed:
    Dylan Doxey likes this.
  9. mrbigh
    3,686
    699
    Long Island, NY
    I see that you covered the doors basically completely, didn't you aloud an opening for some humidity ventilation ?If not Dynamat name brand, there are other competitive products in the market with similar characteristics and end results.
  10. phoenixgreg
    1,157
    294
    66
    Phoenix
    Humidity isn't too much of concern here, but I believe there is slot all along the top on the inside where humidity could escape. The biggest problem would be access to PDL and PWR window mechanisms, if they should ever fail. Then you or a tech would have to cut away the Dynamat to get at the device. I hope it never happens to me! I will say the sound-deadening is very noticeable and an added bonus is the improved performance of the OEM door speakers.
  11. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    What about adding some of the material to the inside surface of the outside sheet metal to dampen that also? It sounds like an oil drum lid everytime I shut one of the doors.
  12. phoenixgreg
    1,157
    294
    66
    Phoenix
    One of our members shows doing that - I can't locate the post. It would dampen the sheet metal sound by doing that - adding a panel of Dynamat to the inside surface of the outer sheet metal on the door.
  13. pmike
    pmike Member
    237
    81
    Central Florida
    Its quieter than our 2012 Civic so I think its fine for price class it is in. I am finding that new tires are quieter and they start getting nosier as they wear.
  14. mrbigh
    3,686
    699
    Long Island, NY
    I have made that on my former 2004 and it really does improve the resonance of the door. I remember applying
    several large square pieces on that sheet metal, mostly in the center.
  15. prinut
    prinut Pri Nut
    102
    SouthFlorida
    What about applying a sheet of cork just like the Dynamat?
    I don't know if there is access to the inside surface of the outside sheet metal, but I believe that could help too. Thoughts from anyone?
  16. Mendel Leisk
    41,315
    I'm not sure why that would be. Our Canadian Touring model comes with 215/45R17, and also has some sort of heavy paper liner in the rear wheel wells. I've a vague recollection that the liners were to counteract the noise increase associated with the 17" rims. I switch to 195/65R15 snow tires every winter, not sure, but they might be marginally quieter.
    You're likely going ahead regardless, but just my 2 cents, sound deadening seems like a lot of disassembly (and potential damage), added weight, to resolve a non problem.
  17. mrbigh
    3,686
    699
    Long Island, NY
    This is not a problem, most likely a nuisance issue.
    I went similar route on the former 2004 and it is a real difference with similar product.
  18. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    I did this and the interior noise seems to be now isolated to the front side/engine bay, mostly from the wind. The floor noise is now at a level I'm satisfied. Will follow up on undercoating later.
    What I did here was peel of the carpet, did some selective patching on the tinny areas, applied sound deadener, then rubber matting as a decoupler. On the carpet side I glued another layer of rubber matting to the OEM layer. Take note of the image just above the (right)yellow pin/clip as this is really hollow sounding and very annoying. This was done for both driver and front passenger areas.
    #18 kenniekenken, Apr 6, 2015
    Starbrand likes this.
  19. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    More noise reduction activities today... Got me some recycled denim insulation from my local hardware store. Also did the rear wheel well liners but wasn't able to snap photos as it started to pour so had to rush to put the trim panels back, lol!
    phoenixgreg likes this.
  20. Mendel Leisk
    41,315
    We have some sort of paper liners in the rear wheel wells, I think due to OEM 17" rims with Touring package. Is that what you got? There's studs protruding on the wheel well, the paper liner has corresponding holes, and there's plastic nuts with a metal insert that screw down onto the studs, to hold the liner in place. Plus some REALLY hard to remove fasteners (2 I believe) at the back corner, and one at the front corner that captures the wheel spat piece as well. The latter is a hopeless, rusty POS (thanks Toyo), I've replaced it with nylon license plate nuts/bolts.
