2006 Prius Traction Battery Acting Strange
Discussion in 'Gen 2 Prius Main Forum' started by Chris ZB, Aug 1, 2014.
  1. Chris ZB
    Chris ZB Junior Member
    Southern California
    2018 Prius
    Three Touring
    My Prius has been great so far with general maintenance. I currently have about 115K miles on it. I noticed that when I drive home with full bars on the traction battery (sometimes in the green) I get into the car the next day and it starts up with full bars, then within minutes it drops significantly at least by half. If I park with 4 blue bars, it's down to the purple after being parked for two hours. The car drives fine and there are not lights on the dashboard indicating any problems. I did the test procedure and my 12V battery and the battery is at 12.2, 11.9 under load and charges at 14.5. Is this a 12V battery problem or traction battery problem? I'm confused because sometimes I see that the recommendation is to replace the 12V battery. Are there any other tests that I can do?
    Also, what shop is recommended in the Long Beach/Orange County area of Southern California? I once took my car to a dealer in Long Beach for the water pump replacement recall and was told that a headlight needed to be replaced to the tune of over $300 after they washed my car. I got there and there was nothing wrong with the headlight. I have no headlight problems on my car. The dealers in my area are sometimes questionable. Maybe they saw something that I didn't but the headlight has been working with no problems.
    Thanks for your help,
    Chris
    #1 Chris ZB, Aug 1, 2014
  2. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    It may be a sign that the traction battery is losing capacity. Continue to monitor it. Rapid state-of-charge changes and the HV cooling fan running at high speed (vent is in the rear, passenger side seat bolster) are common signs of a declining traction battery.
    If you're up for a road trip North, Lucious Garage in San Fran may be the holy grail of hybrid shops in the country. I'm sure they could also help by phone. Luscious Garage | Hybrid Specialists
    I do everything I can to keep cars away from the service department. I've been managing so far with Youtube how-tos and online parts.
  3. Chris ZB
    Southern California
    2018 Prius
    Three Touring
    Darn! My son's Prius has over 200K on it with no battery replacement yet and that's what I was hoping for.
    I haven't noticed the back seat fan running recently. On the rare occasion of an extremely hot day here where I'm 3 miles from the beach I've heard it a couple of times in the past but not with this problem.
    Thanks for the response and I'll see if anybody knows of a reputable local shop.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    You can probably keep driving on it, especially if the cooling fan isn't screaming. Has your fuel economy dropped?
    The HV battery life seems to be pretty inconsistent. Some go 300+k. Others quit before 75k.
  5. JC91006
    JC91006 Senior Member
    16,827
    8,600
    You should be hoping for a battery replacement. You have a 10 year/150k miles warranty in CA. You WANT a new replacement.
    Chris ZB likes this.
  6. Chris ZB
    Southern California
    2018 Prius
    Three Touring
    Thanks, JC. I thought that I read that somewhere but couldn't locate the information.
  7. Chris ZB
    Southern California
    2018 Prius
    Three Touring
    I just dropped my car off at Toyota to let them run their tests. I needed an oil change so I'm giving them $30 worth of business and Ill see what they find, if anything. My mileage was averaging 45 and it has dropped into the low 40's but it's hard to determine the cause. I retired so I'm not doing that much freeway driving anymore. When the car is in the purple bars, it drives a bit different. Louder and working harder is how I would describe it. I'll know tomorrow what comes up on the scope.
  8. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Avi's Advanced Automotive is the only Prius independent in your area I see referenced.
    If you do hear the battery cooling fan running at all, that is not a good sign. Avoid parking in the hot sun, use window reflectors and the rear cargo area cover. Use A/C to keep the battery air cool. Heat is the enemy of battery life, and it is a statistic that batteries from hot climates generally don't last as long.
  9. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    So, are you saying some of the A/C is diverted to cool the traction battery? Or, just that keeping the cabin cooler helps the battery?
  10. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I don't think that is entirely true. That fan runs at different speeds. Sometimes it's running at low speed silently - and in very hot weather without A/C in use, it can be heard running that bit louder - depending entirely on the surrounding temperature and how much the traction battery is being utilised or charged.
    When my UK Gen 2 Prius (T Spirit) is very quiet at standstill, usually after I have arrived home and parked after my 18 mile "spirited" commute home, I can often hear a faint hum coming from behind the dashboard, and an equally unobtrusive whirr coming from the traction battery fan. I have exceptionally good hearing (for my age), and so can pick this up crystal clear at that moment. I don't hear it when in stopped traffic. Considering that the last (less than) quarter mile home is up a steep hill in 27c summer heat, this alone might account for the fan running quietly - but run it does; and indeed, it's supposed to.
    You are absolutely correct about using the A/C on hot days to do this. This is something I have always done since I bought my Prius 13 months ago.
    I've also noticed that chilled A/C air cooling the HV battery results in the Prius running for longer (and stronger) during those few moments when I'm running on the battery only. So running the A/C is always a good thing for the HV battery, 1 - 2mpg loss be damned.
    These days, I tend to pulse and glide a lot, so I no longer run up to a mile on battery power only, like I used to last year. This is also to preserve the life of the battery. It only gets used mostly in pockets of crawling traffic, which thankfully are quite minimal.
    It is also worth noting that during summer last year, I achieved my "66.0mpg @ 605 miles" personal record while running the A/C on minimal settings during my commute home in the afternoons. Ditto with my "66.5mpg @ 628 miles" this year. In the mornings, at anything from 12c to 18c, I tend to use just the cabin fan for ventilation. If it gets hot and / or humid, the A/C comes on.
    To recap, that HV cooling fan is always running once the Prius gets underway (charging and discharging of the HV battery). I believe it was designed to do that. Within optimal surrounding (read cabin) temperatures, it will run quietly. In very high temperatures (or with a battery overheat / failure in progress), it will likely run at full tilt. Keep the cabin cool and prolong the life of your HV "Traction" battery :)
    p.s. If I got anything wrong here, someone please correct me - I'm here to learn just like everyone else ;)
    iPad ? HD
    #10 Data Daedalus, Aug 2, 2014
  11. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    The latter: keeping the cabin cooler helps the battery.
    FuelMiser likes this.
  12. Data Daedalus
    1,025
    1,185
    Wembley, London
    The HV cooling fan sucks air directly from the cabin space to cool the HV battery. Ergo, the temperature of the air in the cabin area is what goes to cool the battery. This is more critical on some hot days when the temperature in the cabin can easily climb to 40c+ in relevant locations.
    Reduce the temperature in the cabin by winding down the windows initially once you get moving, close the windows then crank up that A/C and keep the cabin temp down. Good for the driver, passengers and THAT HV battery :)
    iPad ? HD
    Britprius and FuelMiser like this.
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Chris. Your HV battery is showing some signs of aging, as are many others approaching 10 years old. Take heart though, my 2005 has had very similar symptoms to what you're describing for nearly 3 years now, and is still going fine. I'm currently at about 135k miles, and this issue has been noticeable to some extent for at least 40k miles now. Also, I have discovered that there several things that you can do to mitigate the issue and keep your Prius running well.
    Firstly, it's important to understand that it's very much normal (all Prius) to use the HV battery very heavily in the first few minutes. It's a combination of several factors (including high initial DC-DC converter load and also aircon compressor load, both of which that feed off the traction battery) but mostly due to the fact that the car tries to use electric propulsion in preference to engine power until the cats reach operating temperature.
    When your battery is new you may not notice this large amount of battery usage in the first few minutes because the SOC display is decidedly non linear, with 6th (and 7th) bars on the display being noticeably broader than the others (see attachment). Once you drop to the 5th bar or lower however, the amount of energy corresponding to each bar is much less, and this definitely gives the perception of much more rapid reduction in SOC (can almost feel like the battery is "collapsing" sometimes).
    Now lets look at ways to mitigate the problem.
    1. Make sure that your battery cooling is in good health. This is primarily to prevent/limit further battery degradation. Check the rear vents and battery cooling fan for dust clogging and keep these as clean as possible. It's a fairly easy job and you'll find a lot of "how to" info here if you search on it. I include this as a regular part of my maintenance now.
    2. Try to prevent your SOC dropping too much at start up. The simple method which helps a lot is just to let the engine warm for about 40 to 60 seconds any time you're doing a cold start. Leave the transmission in "P" (and give the accelerator a tap to kick off the engine if needed) and just let it sit there idling and charging the battery for a minute or so. This has two positive effects, firstly it slightly pre-charges the battery, but most importantly it warms the cats so that the car uses engine power much sooner when you start driving. Trust me that this makes a huge improvement to the problem!
    (Note: you may not need to do this if your starting SOC is good and your first minute or two of driving is slow on level terrain. If you have hills or need rapid acceleration however then it's much more important. Just watch for when you are and aren't losing SOC at startup and you'll soon get a feeling for when this is or isn't required).
    3. Try to reduce the aircon compressor load in hot weather by delaying a/c usage for a minute or so and using the windows down to flush out the hot air first. Don't forego aircon usage altogether though, as it's vital to keep your cabin cool in order to keep the HV battery cool (as it ducts air from within the cabin space).
    4. Try to park your prius with a reasonable SOC level (eg 6 bars) whenever possible. Try not to EV glide too aggressively near the end of a trip, and it may also help to turn off the aircon (and just use fan) for the last minute or two, particularly if that involves slow manoeuvring (like parking) where you're only running on EV.
    5. In hot weather try not to park in direct sun whenever possible. When this is not possible, then definitely don't do it when the battery is at full 8 bar SOC. (The battery can easily overheat in this state). Literally just leave the prius ready and aircon on full blast for a minute or so until it drops to 7 bars if you ever find yourself in this situation.
    6. Try to avoid getting full 8 bars SOC when possible. It may help to use "B" mode on larger descents if this is an issue. When you can't avoid hitting full 8 bars SOC, then be aware that the SOC may drop unexpectedly rapidly as it comes back towards 5 or 6 bars (for example you might get a very sudden 6 down to 3 bar drop if your running EV). This seems a fairly common issue with older batteries and may be due to the battery management overestimating the amount of charge available under this scenario. I try not to allow it to use EV (full electric) too much after it has dropped from 8 back to about 6 bars.
    BTW. By following these tips I'm still getting really good MPG despite this issue. :)
    #13 uart, Aug 2, 2014
    Aaron Vitolins and wjtracy like this.
  14. nh7o
    1,686
    340
    Hawaii
    Yes, certainly. My fan motor voltage reads about 7-9 volts when the batteries temp sensors are less than 50 degrees C. My hearing is good, but I don't hear that speed of fan unless I put my ear close to the vent. It's the fan on maximum that signals the overheating condition, which is what most people are going to hear, given the normal ambient sounds.
  15. Chris ZB
    Southern California
    2018 Prius
    Three Touring
    I just picked up my Prius from the dealer and everything checked out okay. They said that there was nothing indicating any type of problem.
    We are having an abnormally hot (and dry) summer here in Southern California and along with my driving conditions changing due to retirement, maybe that could be what has made everything so noticeable. I was driving 50 miles a day round trip and now it's mostly street driving with an occasional freeway trip.
    Toyota did tell me that heat is not the enemy to these batteries, but the cold is. However I can understand that hot cabin temperature provides warm circulating air to the battery pack.
    I will follow your tips, uart. Everything you say makes sense.
    Thank you all for your input. I was a member here when I first purchased my Prius back in 2006 and due to my Prius being the perfect vehicle for me with absolutely no problems, I have drifted away. It's nice to see that the forum membership has stayed the same with helpful people but boy is it different to navigate through now with so many different Prius' now!
    Thanks again!
    Chris
    Oh, as an afterthought on the battery fan, I wasn't aware that it had different speeds, so maybe it have been on but I just didn't notice the sound at the lower speed, only on the high speed.
    #15 Chris ZB, Aug 2, 2014
  16. uart
    uart Senior Member
    4,220
    1,211
    Australia
    That's good. But just remember that the dealers never check the cooling fan or ducts for clogging, so do make sure you do check those out. It's not a difficult job, and trust me heat is the enemies of these batteries if that rear vent cooling system isn't in good health. Overheating my battery due to a clogged fan was originally what caused my battery get into the same state as yours now appears to be.
    Also, loss of battery capacity is somewhat normal with aging and is NOT something that the dealer would pick up on or even test for. As long as the battery doesn't develop other problems, like shorted cells or a high resistance cells, then it can keep going with reduced capacity without triggering any errors. The dealers never test for amp-hours and they honestly just wouldn't have clue about loss of capacity.
  17. Chris ZB
    Southern California
    2018 Prius
    Three Touring
    I removed the vent cover on the rear passenger seat and the duct has a very small trace dust on the duct. My Prius has been driven with the windows up, air on and on freeways (until about a year ago) but not through extremely dusty and dirty areas where the wind blows up lots of dirt. I have a little italian greyhound dog that doesn't have any fur. He occasionally goes in the car with me but mostly in the front seat. I highly doubt if there is a clog in the line because almost perfectly clean. I'm kind of a clean freak about my car. I even wipe down the engine every time I hand wash it. Today when I drove home from the dealer, the SOC was in the green in no time. On my next trip out, I will see how it's doing and use your advice.
    Thanks again, uart. I'll keep you posted.
  18. nh7o
    1,686
    340
    Hawaii
    Not so! Cold will cause the battery ECU to limit the current through the modules, until they warm up a bit, which happens pretty quickly. There will be a limit to acceleration initially as a result. But there is no harm done. Excess heat causes electrolyte loss, which is irreversible. The dealership techs are not the last word, at least when it comes to the Prius.
  19. artistdr
    artistdr Junior Member
    30
    Oklahoma
    Where on the rear seat is the vent cover? Alan
  20. Chris ZB
    Southern California
    2018 Prius
    Three Touring
    It's located on the passenger side back seat near between the door and the vertical back of the seat.
