Outdoor charging station ideas?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Larry Barnett, Aug 11, 2014.
  1. Larry Barnett
    Larry Barnett New Member
    Berkeley, CA
    Hi all,
    Just received my 2014 plugin. Here's the deal: I don't have a garage. I'll be parking the car in the driveway next to the house. My previous car (a 2004 Prius) was recently stolen out of that driveway. So, you can imagine that I'm a tad paranoid about leaving the $1500 charging cord out at night.
    Here's my question: I'm soliciting ideas for buying or building an outdoor charging station that attaches to the house. It should: 1) Secure the cord to the house; b) provide some weather protection when the cord is stowed; c) not be a hassle to deploy and stow the cord; and d) last, but not least, not be so expensive that it obviates the car's lifetime gas savings benefit! Anyone seen or done anything like that?
    Thanks!
    #1 Larry Barnett, Aug 11, 2014
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    Haven't seen anything specifically, but you might consider incorporating a steel cable parallel with the charging cable, which could be locked to the car in some way. There is a small hole in the charging plug trigger which can take a small luggage lock, but it's not good for much more than preventing someone from casually "lifting" the cable.
    There are threads in this forum which have dealt with this issue. You can search for "charging cable lock." if you wish.
  3. Astolat
    Astolat Member
    229
    73
    Guildford UK
    At the risk of making you jealous, here in the UK there was a scheme to install these free, so I got a Chargemaster:
    Home Units
    The reason for saying it is that the nearest for you seems to be the ClipperCreek:
    HCS-40, 30A, 240V Charging, 25 Cord | ClipperCreek EV Charging Station | ClipperCreek Vehicle Charging Station
    My experience of having the Chargemaster is that it is fine outside on the wall under the eaves without any real additional protection. The safety features built in to the system mean you don't run any risk of electrocuting yourself. If you wanted, you could just screw a little waterproofed ledge over the top of it to keep the worst of the rain off, but mine has coped with everything, and the ClipperCreek looks as if it is built on exactly the same principles.
    But anyway, I just looked at where you are based. I think if it can cope with our level of rain, it can certainly cope with yours...
  4. bisco
    52,386
    are you handy with carpentry tools?
  5. Larry Barnett
    Berkeley, CA
    Adequate, but since I'm also a cheap b*****d I'll probably go the luggage lock route.
  6. bisco
    52,386
    all the best! but if they stole your car, did you leave the fob in it?
  7. Larry Barnett
    Berkeley, CA
    Back door (to the house) was unlocked. They grabbed the first thing they saw which happened to be my bag ... which contained the fob :-(
  8. bisco
    52,386
    bummer.
  9. Bill Collins
    Bill Collins Junior Member
    East rutherford N.J.
    2013 Prius Plug-in
  10. Bill Collins
    2013 Prius Plug-in
    Here's a picture of my charge Station on the edge of my driveway. Been installed now over a year and still looks as the day it was installed. Been rained on , covered with snow and never a problem and no one is going to steal it The 220 volts of juice will see to that
  11. GregP507
    3,002
    481
    Fob 1 stays in my pocket. Fob 2 stays in a well-hidden location in my house.
  12. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Mine is semi-permanently installed under my carport. I don't have much worry about theft in my neighborhood, but my method was to screw two large eye bolts into a stud of the carport, and use a heavy duty lock through those and the plug end of the charging cord between the box and the plug end. Cheap and effective.
  13. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    I believe it's "only" $500. Maybe less as people start to total their cars.
    When I bought my Clipper Creek charger it came with a cord permanently attached to the unit. You would have to saw it off to steal it.
    My unit is built to be out in the weather. It would not be too hard to build a little closet around it.
    For me it came to about $1,000 to buy and have installed the unit, however I got a few extras. The wiring is sized for 40 amp service, I had a parallel dedicated 120 volt/20 amp outlet run at the same time, and I got a long cord for the charger.
    $1k is about 250 gallons of gas, which is what, 12,000 or 13,000 miles?, however I plan to have the car a while, and I am doing most of my driving on electric. "Most" in fact to the point where I had to figure out which button opens the gas door...
    #13 kenmce, Aug 12, 2014
  14. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)This is my outdoor Level 2 charging setup at work. Including the cost of the modified EVSE, no more than $450. I was able to reroute a unused 220v line which saved on cost.
    SAronian and Chazz8 like this.
  15. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    This thread shows exactly what you're looking for.
    Thinking of Adding Charge Station
    Greenwave likes this.
