Auto ventilation setting forces recirculation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tropicseed, Aug 11, 2014.
  1. Tropicseed
    Tropicseed New Member
    Hi all,
    I used Carista to prevent the auto climate control button from forcing AC on, worked great! However now I noticed that whenever I turn on the AC, it forces air recirculation. Worse, if I manually set it to fresh air, turning the car off and on again resets it to recirc, annoyingly.
    Is there a way to change this? I want the default to be fresh air.
    Thanks
    Patrick
  2. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    Are you driving in "eco" mode? That seems to force the system into recirculation mode and also slows the fan a bit, all in the name of economy.
  3. Tropicseed
    Good point, but no, I'm in normal mode.
    Patrick
  4. Mendel Leisk
    41,826
    As far as I know ours never forces AC, if I hit Auto with the AC button off.
  5. Tropicseed
    Well, my '13 Prius Three did force AC with Auto. The manual confirmed this and says the dealer can change it. I got Carista, and it can change this setting, and many others. But no mention of recirc vs. fresh air settings.
    Perhaps this behaviour varies with model or year?
    Patrick
  6. Mendel Leisk
    41,826
    Yeah that's what I'm thinking. Or different setup since I'm in Canada.
    Step backward, my 2 cents. Our last car behaved as you describe: first order of business after hitting Auto was to turn AC BACK off.
  7. fuzzy1
    10,589
    Did it not do this before the change? Both my Prii did this from the start.
  8. Tropicseed
    I'm sure it did! I think these are independent settings - if indeed the fresh/recirc is even settable.
    Patrick
  9. Former Member 68813
    3,524
    983
    US
    I had to change the setting about the auto recirc when AC on via TIS. The default is very annoying feature for some of us who like fresh air.
  10. Tropicseed
    What's TIS? I looked through Carista's settings, there wasn't anything relevant I could find there.
  11. Tropicseed
    Posted to soon! As usual google is my friend. TIS = Technical Information System. Everything you might want to know about Toyotas, evidently much of it available only if you're in the biz.
    I'll ask the dealer about it next time I go for service.
  12. Former Member 68813
    3,524
    983
    US
    "unofficial" ones available at about $30.
