Fuel meter/ miles left (range) inaccuracy
Discussion in 'Prius v Main Forum' started by wstt, Aug 7, 2014.
  1. wstt
    wstt Member
    147
    Has anyone noticed any inaccuracy between the fuel gauge and the range (miles left) readings?
    In the past the low fuel light would come on when there were no bars of fuel left on the fuel gauge. Now it comes on when there is 1 bar.
    Several times now, the low fuel light comes on when I've still got 1 bar on the fuel gauge and the range says 16 miles. For these tanks I'm averaging over 54mpg so if I've got more than 1 gallon left, 16 miles can't be the range. (Before someone says it errors to the cautious side and there is a reserve read below). (The tank holds 11.9 gallons so take away 1 gallon for reserve and divide by 10 bars on the meter so each bar represents approx 10.9/10= 1.09 gallons)
    Which should I trust, the gas gauge which is possibly showing too much gas or the "range" which is possibly grossly underestimating the mileage left?
  2. rjparker
    9,827
    6,066
    My one bar comes on at about 16-20 miles of range, with a little soft beep that can be missed sometimes. It's probably learning your driving style with a PID loop. I routinely run down past zero range to the point where it takes 10.5 gallons, once around 11.0 gallons. The manual says capacity of 11.9 gallons. Another owner claims he once put in 12.5 gallons and he was still driving. The speculation is 0.6 gallons is in the filler tube when you top it off. Clearly it IS a safety factor and the reserve is more like two gallons.
    skwcrj likes this.
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    My orange gas pump comes on at 11 to 10 miles left. The mileage count down seems based on the tank average not my current average, so if I am doing well late in the tank I can get to zero with one bar left. Normally I have zero bars at zero miles and put in 10.1 gallons.
    skwcrj likes this.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    1st: there is no relationship between the cruising range and the gas gauge. The cruising range is based on the current average MPG vs the approximate gas in the tank. Its programmed to give you room to spare. Many people have gone 50+ miles when it says 0. For the most part, ignore it.
    The gas gauge bars represent a RANGE of fuel capacity, with one bar representing approximately one gallon in the v. So one bar can represent anything from 2 gal remaining to one. Mine mostly comes on some time after one bar is showing but well before no bars.
    In any case its not a big deal. When the red light comes on - go find a gas station!
    skwcrj likes this.
  5. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Adding to what was said above, my low fuel icon comes on at around 15 miles remaining. Even after going to zero miles remaining (or -5 mi), I usually still have 1.7 (1.6 to 1.8) gallons remaining. I can only think of one time when I drove it to where the last pip disappeared. I think I was trying for my first 600 mile tank. I did remain close to the gas station. I still had 1.7 gals.
    The most important point to be made is that as long are consistent during the last 50 miles as with the first 500, the distant to empty should be reasonably close. In other words, drive like a mad man towards the end of the tank and you will run out well before the distance to empty estimate.
  6. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    By the time the red lights come on (red triangle of death), it's too late.
    Just kidding. I agree with you.
  7. wstt
    wstt Member
    147
    Just to give an update. I forgot to post this after. So the light came on with one bar of gas left in the tank which is strange because it normally comes on with zero bars of gas left. I was also getting great mileage that rank 54+ mpg which would make me think the low fuel light would come on later, than earlier.
    So it came on with 16 miles of range and after 517 miles for the tank. Well, I drove another 23.5 miles, or well into zero range and my fuel meter still showed one bar. So either my fuel meter was stuck at 1 bar, or the range thing was way off. I'm guessing that 1 fuel bar was there for way too many miles. Oh, and the car took 10.3 gallons at the pump. image.jpg image.jpg
    #7 wstt, Aug 25, 2014
  8. bisco
    51,484
    i think your right, thanks.
