prius 2007 head lights
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Autoconfig, Aug 10, 2014.
  1. Autoconfig
    Autoconfig Junior Member
    Bay Area
    Hi All,
    Yesterday night went to short trip of 100 miles(first time in night trip with this car), I was not able to see the clear road, lighting was not clear visible for me,today morning i checked with my friend( he knows better than me about cars :) ), he told me everything seems good,but i really don't like head lights visibility, please suggest me nice head lights which is having good visibility.
    Note: I am new driver.
    #1 Autoconfig, Aug 10, 2014
  2. Autoconfig
    Bay Area
  3. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
  4. cnschult
    cnschult Active Member
    772
    95
    Michigan
    if you have HIDs than your headlight level sensor has gone bad, they usually rust out from the winter so i don't think that applies to you in San Diego unless you bought a used car that has spent many winters in the snow belt. When the sensor (between left rear hub & cross beam) goes bad it sends the HID into default mode which points them straight down and you can't see squat. But this also throws a couple of warning lights to come on your MFD.
    so you probably have halogens and your lights may be hazy from the sun, buy a headlight cleaning kit, hopefully you have a drill as I like those kits the best. 3M and Mothers and Meguiars make good ones, sold everywhere, easy to follow instructions. This may get you halfway to your goal, now buy yourself a nice expensive pair of Sylvania Xtravision or GE Nighthawks. Philips may have a higher end bulb of their own, bottom line you'll get what you pay for buying nice WHITE bulbs instead of cheap ones.
    never ever ever touch a headlight or fog light bulb with your bare hands, the oil on your fingers will greatly diminish their life. You can touch all the other bulbs in your car with your bare hands, such as parking, turn signal, brake, tail, license plate, and all interior lights; just not the headlights you just spent big bucks on.
    avoid ebay, avoid anyone selling blue or purple or green bulbs, they'll advertise it with a kelvin rating like 4000k, 5000k, 6000k, even 10000k. These are just tinted glass which allow less of the light to pass thru, not only are you breaking DOT laws you will be able to see even less. Any packaging that says, "for offroad use only" means they are not DOT road legal. If you want to see illegal bulbs just look at EVERY pontiac grand prix and most grand ams at night. They're all driven by stupid white trash punks trying to pretend their car is an Audi. It isn't, you can stare at them for 1 minutes straight without turning away; you can only look directly at an HID bulb for a split second before damaging your eyes. Don't be like them, if I were a cop i would impound every car with those ebay garbage bulbs.
    You can buy an HID conversion kit but that requires some skills and if you wanted HIDs you should have just bought a Prius that came with them from the factory. 2004 and 2005 are the best because the d2r's last much longer than the d4r's. Clean the lenses and replace the bulbs with quality legal bulbs and you will be a happy driver.
    Data Daedalus and Autoconfig like this.
  5. Autoconfig
    Bay Area
    Thank you very much, how much it cost HID conversion kit.
  6. Daves09prius
    680
    161
    Gettysburg, PA
  7. Autoconfig
    Bay Area
    Thank you very much.
  8. Autoconfig
    Bay Area
    Hi Daves,
    which color i have to select (6000k diamond white or OEM white)
    one of my neighbor suggested me one set of bulbs, please check it and let me know if this bulbs are ok for prius.
    Dual Headlight Bulb Front 2 x Halogen Super Bright 2 in 1 9003 HB2 H4 Hi Low | eBay
