2007 Prius base milage
Discussion in 'Gen 2 Prius Fuel Economy' started by Autoconfig, Aug 1, 2014.
  1. Autoconfig
    Autoconfig Junior Member
    Bay Area
    Yes, i am trying to gt appointment next week from shop, here in SD most of toyota dealers don't have good reputation, lot of local shops have very good name, i am confused if i can go to local shop or else only toyota dealer.
  2. vskid3
    vskid3 Active Member
    773
    228
    What was your previous car and what kind of mileage did you get with it? As others have said, it looks like you do quite a bit of regen. The regen isn't the bad part, but it can indicate that you're wasting fuel only to have to slam on your brakes. If you didn't get that great of mileage in your last car, your driving style might be partially to blame.
  3. Autoconfig
    Bay Area
    Today went to 60 miles short trip(mostly on freeway), got 37.8 mileage, i was using Suzuki car(manual transmission) in india.
  4. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Has someone removed the original OEM Iridium Spark plugs from your Prius and replaced them with cheaper none iridium spark plugs? That may well account for the reduction in MPG.
    The Prius 1.5 Litre Atkinson Cycle Engine was designed to use one of the following OEM Spark Plugs:
    Denso: SK16R11
    NGK: IFR 5A11
    Anything else - especially NON IRIDIUM might (probably WILL) affect your MPG readings. You might want to get that checked out by a reputable dealer.
    Iridium Spark Plugs obviously cost a lot more than ordinary spark plugs - some previous mechanic might have been trying to cut costs.
    On the other hand, what's the mileage on the vehicle? Perhaps the originals were never changed out.
    Remember, this car runs on standard fuel - don't put higher 97 or 98 octane premium fuels like Optimax or V-Power in it. Waste of money and a reduction in MPG. The engine is optimised for 95 octane (UK anyway). Depends what that is in your corner of the world.
  5. vskid3
    773
    228
    What PSI do you have in the tires? I feel like there's something wrong with your car. I bet I could drive like a madman and still break 40MPG in my Prius.
  6. Autoconfig
    Bay Area
    I am
    Thank you , car was good, before resetting mileage buttons, I have seen in same car previous owner getting 43 to 44, i am not sure how to check PSI, i will try to find out .
  7. Autoconfig
    Bay Area
    before i got car, previous owner has given to car detail shop.
    #27 Autoconfig, Aug 17, 2014
  8. Autoconfig
    Bay Area
  9. Autoconfig
    Bay Area
    I am filling shell regular gas, is that fine..?
  10. Data Daedalus
    1,025
    1,185
    Wembley, London
    That should be okay. I used to use Shell Regular, and I did get 66.0mpg using it last year. Then I switched over to a different fuel. I went for ESSO instead, and seemed to get better mileage out of that. So I've stuck with ESSO Fuels.
    Here's another thought - what is the Ethanol content of that particular Shell Regular Fuel that you're using? Maybe it's actually 10% Ethanol content? That might affect your MPG too.
  11. Autoconfig
    Bay Area
    I have no idea about ethanol content level.
    Need opinions is it good idea or bad idea to install EV mode for short trip(not more than 1 mile close to my house lot of grocery stores and restaurants/gas stations )
    #31 Autoconfig, Aug 17, 2014
  12. dolj
    dolj Senior Member
    8,502
    4,314
    Wellington, New Zealand
    It's a bad idea if you think it will decrease your consumption. It will not and will shorten the life of your HV battery by causing it to cycle more often.
    Autoconfig likes this.
  13. Autoconfig
    Bay Area
    tomorrow i am taking reputed local service center, hopefully they will try to find the issue.
  14. Autoconfig
    Bay Area
    I've taken car to local car service center for 105000 service checkup in miramar(Elite they are pretty popular) and they told me no issues with car and they did dig check but no issues reported, here is attached screen shots, now i am getting around 39.2 and 39.1.
    105000 service,and dig check,no error codes reported and battery looks pretty good ,correct me if i am wrong. my latest mileage around 39.1 and 39.2.
    with in one month, i am car mileage increased from 31.1 to 39.1
    i was getting 31.1 mileage when i bought car.
    now i am getting 39.1, is this good mileage i am getting right now.
    #34 Autoconfig, Aug 25, 2014
  15. vskid3
    773
    228
    Have you checked the tire pressure yet? I can drive my Prius pretty hard and still exceed the EPA ratings with no mods besides LRR tires at 51PSI.
  16. Autoconfig
    Bay Area
    Yes, service center advised me to set 36 PSI for all tires,please check the attached car service information paper. service_elite - Copy.jpg
    #36 Autoconfig, Aug 25, 2014
  17. Autoconfig
    Bay Area
    I think no issues with battery, please check the battery dig check. service1.jpg
  18. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The aux battery report looks fine.
    You might try increasing your tire pressure. Try 44 psi front, 42 psi in back.
    39 mpg is better but it should be doing better still, especially in warm weather.
    There is still quite a bit of regeneration in your last screen photo. Have you worked on finding that spot in the go-pedal stroke where the energy flow is zero (or close)? Use the energy flow screen to help find it. If you coast with the go-pedal all the way up, the car activates a certain amount of regenerative braking, slowing the car (and usually reducing fuel economy). For coasting (unless you're trying to slow down), you should be holding the go-pedal down a bit.
    You might check your engine oil level to make sure the shop didn't overfill it. It usually only takes about 3.5 qts for an oil change, so it's easy to overfill.
  19. Data Daedalus
    1,025
    1,185
    Wembley, London
    And there's your problem right there methinks. I'm running my tyres presently at 40 psi front and 38 psi rear.
    Methinks 36 psi isn't enough to give you higher MPG readings.
    With this setting which I did within three miles of filling up with a fresh tank, I presently have 65.7mpg on my MFD (I got to 66.4mpg at one point after a run to work). I actually discovered that I have a slow leak in one of my tyres (rear right), and noticed this when the MPG of my new tank sank to 60mpg (in the first 3 miles) despite excellent hypermiling. I also noticed my tail wagging a bit during small course corrections and deceleration. Also, the engine screamed going up hills and and the vehicle wasn't so eager to transition to electrical propulsion mode.
    So yeah, get those tyre pressures up, and you'll see a further rise in MPG pretty much guaranteed.
    Winston Wolf and Autoconfig like this.
  20. Autoconfig
    Bay Area
    Thank you very much for information, sorry to ask you, where i fill Tyre pressure (in gas station or any local shop) ..?
    #40 Autoconfig, Aug 26, 2014
