06 Prius Ghost door Lights / courtesy light
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Sezy, Aug 19, 2014.
  1. Sezy
    Sezy Active Member
    434
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Look what came in the mail.
    Pry off the factory door light. Yes I have LED bulbs.
    UNPLUG
    Top is the NEW GHOST light
    Bottom is OEM
    The GHOST light has 2 small blade like connectors that plug into the OEM socket.
    Quick sample
    Make sure it's snug
    I'm paranoid so decided to electric tape mine all the way up to the plug.
    DONE
    NIGHT TIME
    Lights up the door better than the factory bulb does still. 20140812_225725 (Medium).jpg
    Yes it does shine back onto the door.
    Cost about $13 eBay so we'll see how long they last.
    Justdidit and Data Daedalus like this.
  2. JC91006
    JC91006 Senior Member
    16,759
    8,562
    You would pay to advertise for Toyota?
  3. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Lol, that's a misnomer. It is a 2D not 3D image that's projected. ;)
  4. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Custom ones are available for anything including super heros and sports teams. "It's not what you want, it's the consumer" - Joe Dirt
  5. bisco
    51,801
    pretty sweet, thank you sezy!(y)
  6. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I'm positively green eyed with envy! I definitely WANT.....!!!! :D
  7. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I've already ordered mine, but why are they nearly double the price in the UK at £14-99 ($24).
    John (Britprius)
  8. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    John (Britprius)[/QUOTE]
    That I'm not sure. Mine was off ebay and came from China. It was literally the cheapest one I could find and I BID on it VS buy it now.
  9. Britprius
    5,194
    1,921
    That I'm not sure. Mine was off ebay and came from China. It was literally the cheapest one I could find and I BID on it VS buy it now.[/QUOTE]
    That probably explain it. Mine are being delivered from stock in the UK, so the markup is someones profit.
    I did find a cheaper version that required a hole drilled in the bottom of the door card.
    John (Britprius)
  10. Britprius
    5,194
    1,921
    My ghost lights were delivered today. I found out why they were double the price. It's because they send a set of four, but the UK Prius only has lights on the front doors. However I have worked out a simple way of fitting the extra lamps on the rear doors.
    Pictures to follow.
    John (Britprius)
  11. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    The US prius only had fronts too. where did you run the wires for the rear door ones? Do you have any pictures, that would be awesome.
  12. sturgidson
    sturgidson Junior Member
    35
    FL
    this is silly and terrific. I think I want.
  13. Thomas Loke
    Thomas Loke Junior Member
    Auckland, New Zealand
    2012 Prius+ MPV
    I'm interested in learning how you are able to add lamps to the rear doors as I need them for my kids. Hope to hear from you soon.
  14. Prius408
    Prius408 Junior Member
    34
    San Jose, CA
  15. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Just order a set for my dads and another for mine. May try to put it in the trunk. Once it arrives I'll make another write up. ;)
  16. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
  17. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Got a wild hair and put one in my trunk. Wired into the trunk light power so only comes on when the hatch is lifted and the OEM light can still be switched off. Started out mounting on the hatch aiming down but looked crummy. This is the darkest spot in the trunk so put there instead.
    Drilled a hole with the provided bit.
  18. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    To stat with this I had to open up my ghost light and add some glue because the logo was loose and would turn anyway it wanted. After this I silicone every part I could. So far it's held up.
    In the trunk there is a wire already going through a gasket to the lower bumper so I poked through there with my wires.
    Ran the wires to the left and up through the pillars. There are 3 clips on the headliner rear that pop out easily. Run the wire through there and to the dome light.
    Kept getting different results trying to tap into the 3 wires on the dome light so I shoved my leads into the mounting tabs of the bulb then added lots of solder. Basically tapping right into the leads for the dome light.
    This is where the wires comes out of the trunk and into the bottom bumper area.
    Find a good spot with some clearance and drill a hole with the drill bit that came with the ghost lights. Should go through 2 layers here. Thread the holding nut on the backside to hold the light in place. Connect and insulate your ghost light wires to the wire we ran to the dome light.
    Had finished pics but my SD card ate them so I'll take more tonight.
  19. djneo92nl
    djneo92nl Junior Member
    Love it, want it
  20. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
